Mojave / Catalina on Mobos Series 100/200/300 with OpenCore Bootloader
Post by MaLd0n »
ekomy, don't exist all in one solution in hackintosh, if don't work for u u need check what cause problem and solve
steezy
CPU: Intel Core i3 8100
Motherboard: ASUS Prime H310M-D
GPU: NVIDIA GeForce GT 730
Post by steezy »
Hi, MaLd0n, here's my OC send me file, thanks for help :cap
Post by MaLd0n »
steezy,
steezy
Post by steezy »
22 Aug 2019, 00:57
steezy, DSDT.aml.zip
Thanks a lot that was quick, have one question though, my Display only shows 5MB
Post by MaLd0n »
steezy, hackintool
steezy
Post by steezy »
22 Aug 2019, 12:51
steezy, hackintool
Using my clover configurator to Inject Nvidia, graphics info shows completely. I don't know how to do this on OpenConfigurator config to Inject Nvidia, sorry for dumb question :wallbash
Bertrand97440
CPU: I7 6700
Motherboard: Z170x Ultra Gaming
GPU: EVGA 1080 SC
Post by Bertrand97440 »
Hello Maldon please patch DSDT for OC for me. Thanks for help. ^^
augustopaulo
CPU:  Intel i9 9900K
Motherboard: Gigabyte AORUS Z390 Xtreme
GPU: Sapphire Vega VII 16GB
Post by augustopaulo »
Bom dia MaLd0n,
Também queria experimentar o OC no meu sistema ;)
Utilizei o EFI deste tópico e anexo aqui o "Send me iMac-Pro.zip" resultante.
Também anexei o EFI do CLOVER que utilizo para sua referência, com o DSDT.aml que você criou...
Obrigado.
Gigabyte AORUS Z390 Xtreme ♦︎ Intel i9 9900K ♦︎ Corsair H110i GTX ♦︎ Corsair 32GB DDR4@2800Mhz ♦︎ Corsair 1000W HX1000i ♦︎ NVME: Samsung SM961 512GB ♦︎HD: 3 x 1TB + 2 x 4TB ♦︎ SSD: 1 x Crucial CT960M500 1TB ♦︎ Sapphire Vega VII 16GB  ♦︎ 3 x Monitors ♦︎ ABWB 802.11AC WI-FI/Bluetooth 4.0 (BCM943602CS) ♦︎ Apple Wireless Keyboard A1314 + Touchpad A1339 ♦︎ Logitech HD Pro C920
Post by MaLd0n »
augustopaulo,
Arquivo Comprimido.zip
augustopaulo
CPU:  Intel i9 9900K
31 Aug 2019, 18:48
augustopaulo, Arquivo Comprimido.zip
Obrigado pelos ficheiros! ;-)
Coloquei-os em EF/EFI/OC/ACPI, mas perco todas as portas USB ao chegar à janela de login!
Tentei arrancar somente com o DSDT.AML mas o resultado é o mesmo...
Podes, por favor, dar outra olhada ?
Post by MaLd0n »
augustopaulo, use usbinjectall or native usb fix via ssdt oem
augustopaulo
CPU:  Intel i9 9900K
31 Aug 2019, 21:21
Good morning,
Managed to get my USBs back by adding:
  • USBInjectAll.kext into EFI/EFI/OC/Kexts
  • "uia_exclude=HS14" into config.plist/NVRAM/7C436110-AB2A-4BBB-A880-FE41995C9F82/boot-args - to disable CNVW Intel
    bluetooth device
Will try to look into your DSDT.aml to see if I can add the thunderbolt part...
Thanks for help!
Boa sorte,
Paulo
x3tab
CPU: Intel i3 8100
Motherboard: Asrock B365M Pro4
GPU: AMD Radeon RX 560
Post by x3tab »
Hi Maldon,
Please help me patch DSDT for Open Core
Post by MaLd0n »
x3tab,
jaknappatil
CPU: fgr
Motherboard: vvgvg
GPU: ffvv
Post by jaknappatil »
Thanks for sharing......................
Abdulraheem
CPU: 0000
Motherboard: 000
GPU: 0000
Post by Abdulraheem »
sen me DSDT.aml Please
TwistedSystems
CPU: i7-7700K
Motherboard: GA-Z270MX-Gaming 5
GPU: Sapphire RX580 8GB
Post by TwistedSystems »
MaLd0n,
Hey bro, need a patch for Open core now, donation incoming. Thanks in advance.
Post by MaLd0n »
Abdulraheem, u use some ssdts etc, not good
Added in 1 minute 12 seconds:
TwistedSystems, u need extract files with open core running, clover have some diff about regions fix etc
TwistedSystems
CPU: i7-7700K
MaLd0n, Here you go, booted with OpenCore and ran it. File attached :guitar
Post by MaLd0n »
TwistedSystems, here we go
