Mojave / Catalina on Mobos Series 100/200/300 with OpenCore 0.5.3
chhaggerty
Donator
Donator
CPU: i7-8700
Motherboard: Gigabyte z370 Aorus Ultra Gami
GPU: Sapphire RX 580
Post by chhaggerty » 24 Jul 2019, 19:33
24 Jul 2019, 17:56
Thanks, here is a link to the file on Dropbox
When I try to boot using EFI.zip from the opening post, it freezes after selecting boot drive. I'm at work now, but I think the freeze happened after loading of the memory driver.
Post by MaLd0n » 24 Jul 2019, 20:16
chhaggerty,
EFI CLOVER, just replace, have all u need inside folder
EFI Clover.zip
EFI OC
EFI OC.zip
after reboot need extract send_me for dsdt patch
use bios/uefi in default, just need enable intelHDGraphics in chipset tab if u need IntelQuickSync and CSM if u have black screen
chhaggerty
Donator
Donator
CPU: i7-8700
Post by chhaggerty » 24 Jul 2019, 21:45
I'm happy to report I was able to boot my Catalina SSD partition with EFI OC.zip, although it didn't see my NVME Mojave partition. Was able to run "RunMe.app", and here is the Send me file... Thanks, it's cool getting my first OC boot with your help.
Send me z370-Aorus.zip
Post by MaLd0n » 25 Jul 2019, 00:09
chhaggerty, check if work, put in OC/ACPI
chhaggerty
Donator
Donator
CPU: i7-8700
Post by chhaggerty » 25 Jul 2019, 16:01
Works great thanks :-)
yamazaki45
Donator
Donator
CPU: Intel® Core™ i7-8565U
Motherboard: INSPIRON 14 5480
GPU: INTEL UHD 620
Post by yamazaki45 » 25 Jul 2019, 16:08
Good afternoon,
I would like to request the dsts configuration of my hackintosh or at least help to do, and a Dell Inspiron 5480, is still working:
HDMI;
DSTS (ENERGY MANAGEMENT);
3.5MM PLUG DOES NOT WORK AUDIO;
HIBERNATION;
THANK YOU SO MUCH!
FOLLOW MY SEND ME
Post by MaLd0n » 25 Jul 2019, 17:01
yamazaki45, audio check my sig, useful links
yamazaki45
Donator
Donator
GPU: INTEL UHD 620
Post by yamazaki45 » 25 Jul 2019, 18:38
My SIG ?
I did not understand...
but I am wanting the DSTS because I do not know how to do it or if possible someone help me to do it, because I believe that with it I solve the problem of 3.5MM
Send me, may have some information ....
Post by MaLd0n » 25 Jul 2019, 18:44
yamazaki45, sig = signature ;)
yamazaki45
Donator
Donator
GPU: INTEL UHD 620
Post by yamazaki45 » 25 Jul 2019, 18:49
Ok i thought
But now, about dsts, I didn't configure it because I don't know and I don't have it here, it's zero my hack so it's kind of sloppy
:frantics :(
talmazi
CPU: Intel Core i7-8700K 3.70GHz
Motherboard: Asus TUF Z390-PLUS GAMING (WI-
GPU: Radeon RX 590 NITRO+ SE
Post by talmazi » 27 Jul 2019, 02:47
Olá MaLd0n será que vai rodar bem na minha maquina?
Melhor do que o Clover? Já tentei de varias formas inicializar é muito complexo não estou conseguindo.
Poderia por gentileza me da uma ajudinha!!!
Para conseguir rodar com o Catalina tive que mudara placa de video para EVGA NVIDIA GeForce GTX 650ti 2 GB.
Também gostaria de saber sobre a sua placa de video estou querendo fazer um upgrade.
Olá MaLd0n estou querendo instalar wifi na minha maquina o que acha de placa?
Identificador do modelo: iMac19,2
Placa Mãe: Asus TUF Z390-PLUS GAMING (WI-FI)
Chip set: Intel Z390
Memoria: Corsair Vengeance Lpx DDR4 1 X 16 Gb 3000 Mhz
Processador: Intel Core i7-8700K 3.70GHz
Placa de Video: Sapphire Radeon RX 590 NITRO+ Special Edition Dual, 8GB
Post by MaLd0n » 27 Jul 2019, 04:22
talmazi, estou usando a rx590, nativa
esse wifi tb é nativa
Post by MaLd0n » 29 Jul 2019, 19:01
-UPDATE FIRST POST-
Full EFI folder
ygtaldmr
CPU: 8700K
Motherboard: Asus Prime z370-p
GPU: RX480
Post by ygtaldmr » 30 Jul 2019, 23:16
Hello MaLd0n,
Please find attached the send me file and send me the patched files.
Thank you
Post by MaLd0n » 30 Jul 2019, 23:30
ygtaldmr, this topic is about OpenCore
ygtaldmr
CPU: 8700K
GPU: RX480
Post by ygtaldmr » 30 Jul 2019, 23:37
yes I know, I think I will give it a go. what would you suggest? Shall I carry on with clover?
Post by MaLd0n » 30 Jul 2019, 23:44
ygtaldmr, u need use EFI folder from first post and extract send_me with this folder
ygtaldmr
CPU: 8700K
GPU: RX480
Post by ygtaldmr » 30 Jul 2019, 23:46
Yes I did as you said, I put it on a bootable usb and booted from that.
Post by MaLd0n » 31 Jul 2019, 00:11
ygtaldmr, put in ssd/hdd
ygtaldmr
CPU: 8700K
GPU: RX480
Post by ygtaldmr » 31 Jul 2019, 00:41
this is it
