Catalina Hackintosh on Mobos Serie 100/200/300 / Full DSDT Patched with minimum amount of third-party kexts
neknofelom
CPU: i5-8400
Motherboard: ASRock b360m Pro4
GPU: Intel UHD 630 / GTX 1080ti
Post by neknofelom » 27 Jun 2019, 21:58
27 Jun 2019, 21:44
neknofelom, use iMac18,1 smbios and create one patch with hackintool
I already use patch from hackintool. And can I just change the SMBIOS in clover boot from macmini8,1 to iMac18,1 or do I need to change everything including SMUUID?
Post by MaLd0n » 27 Jun 2019, 22:14
neknofelom, yes, generate one full smbios
neknofelom
CPU: i5-8400
Post by neknofelom » 27 Jun 2019, 22:29
27 Jun 2019, 22:14
Why do you think I need iMac18,1? My system is closer to macmini8,1. I dont like to tinker with SMUUID and SMBIOS because of icloud and Apple :P
neknofelom
CPU: i5-8400
Post by neknofelom » 28 Jun 2019, 09:19
Okay, so I've tried fresh new SMBIOS iMac18,1 without success. I also have hackintool patch for framebuffer and other stuff.
I currently use followings kexts: Lilu, whatevergreen, AppleALC, VirtualSMC, XHCI-unsupported, AirportBrcmFixup, USBInjectAll
I currently use following drivers64: ApfsDriverLoader-64, AptioMemoryFix-64, EmuVariableUefi-64
I have tried:
- changing kext VirtualSMC to FakeSMC
- Fresh vanilla config.plist
- boot args: -lilubetaall
- newest Lilu and whatevergreen
- Clover bootloader version 4942 and higher up to newest
I am guessing there may be something to do in BIOS? It is maybe also worth to mention that I MUST use a patch for my latest BIOS version to work. It is the following :
<key>Comment</key>
<string>Fix AsRock B360m BIOS DSDT Device(RTC) bug</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
oAqTU1RBUwE=
</data>
<key>Replace</key>
<data>
oAqRCv8L//8=
</data>
johnrude
CPU: dual core @ 2.4 GHz
Motherboard: intel
GPU: 32 bit
Post by johnrude » 28 Jun 2019, 10:28
thank you for the reply
Post by MaLd0n » 28 Jun 2019, 12:11
neknofelom, u try without weg kext? why emuvariable?
neknofelom
CPU: i5-8400
Post by neknofelom » 28 Jun 2019, 12:37
emuvariable is to make this motherboard NVRAM working. I will try without whatevergreen!
Post by MaLd0n » 28 Jun 2019, 13:20
neknofelom, olarila patches solve it, u don't need emulate
neknofelom
CPU: i5-8400
Post by neknofelom » 29 Jun 2019, 08:51
28 Jun 2019, 12:11
I tried without weg kext and guess what? It’s working! Thank you very much for this. I will test further on Monday.
Is it bad without weg kext? Do I actually need it for anything particular?
Post by MaLd0n » 29 Jun 2019, 14:13
neknofelom, don't need weg, i don't use it too, cause some problems for me with this kext
gugadj
CPU: i7 8700k
Motherboard: GA Z370 Gaming 5
GPU: RX 580 8 GB
Post by gugadj » 03 Jul 2019, 01:06
fiz o pendrive com o beta3 mas esta parando em voodoops2 mouse
editando o post = reinstalei o clover no pendrive e foi so nao ficou mais com 4 kexts (vanila) agora tive que inserir a fake smc e a whatevergreen
sabbir ahmed
CPU: corei3
Motherboard: H61
GPU: 710 nvidia geforce
Post by sabbir ahmed » 16 Jul 2019, 08:09
mac os A1534
musicazx
CPU: Intel i3-6100
Motherboard: GA-B150M-HD3
GPU: Sapphire AMD RX580
Post by musicazx » 16 Jul 2019, 10:27
16 Jun 2019, 14:47
-Video Processing / HEVC Support--
Now we just need iMacPro1,1 smbios, don't need IGPU enabl
So I just need to change my SMBIOS to iMacPro1,1 and disable iGPU in BIOS? or do I need to re-patch DSDT you've patched for me?
Post by MaLd0n » 16 Jul 2019, 12:58
musicazx, the best is use igpu+dgpu, if ur processor don't have igpu use imacpro smbios
musicazx
CPU: Intel i3-6100
Post by musicazx » 18 Jul 2019, 09:37
16 Jul 2019, 12:58
Do you know why Sidecar is not working on Catalina? I connect my iPad via USB and I have iGPU. Do I need to fix USB first? this is how it look like now [External Link Removed for Guests]
lucasmazevedo
CPU: I5-6400
Motherboard: IPMH110
GPU: MSI RX 570
Post by lucasmazevedo » 13 Aug 2019, 01:47
Estava instalando o Mojave, mas decidir ir logo pro Catalina, instalação OK clover, ao usar a pasta recomendada aqui do olarila tenho KP no AppleFrameBuffer, segue minha pasta do RunME
Post by MaLd0n » 13 Aug 2019, 12:51
lucasmazevedo, esse tópico não é o melhor pra vc, use outro tópico com umas kexts a mais pra facilitar a sua vida
lucasmazevedo
CPU: I5-6400
GPU: MSI RX 570
Post by lucasmazevedo » 16 Aug 2019, 01:15
MaLd0n, Minha Placa de Video (MSI RX 570) chegou Hoje, fiz uma nova instalação do Mojave, usando a pasta recomendada para o chipset series 100, o sistema subiu de primeira, sem problemas! Gerei o SendMe (em anexo)! Queria pedir ajudar com a DSDT e SSDT! Obrigado!
Post by MaLd0n » 16 Aug 2019, 01:36
lucasmazevedo, eu já editei o seu dsdt, use o msm, não precisa editar de novo
Gervasoni
Geek
Geek
CPU: i9900k
Motherboard: Asus - Maximus XI Formula
GPU: GTX 1080Ti - Asus Strix
Post by Gervasoni » 22 Aug 2019, 15:09
Caro MALd0n, bom dia!
Comprei uma expansion card USB Orico, modelo PVU3, PCI express, de 7 portas.
É possível funcionar no hackintosh (Catalina, Mojave...) com alguma kext ou edição de DSDT?
Grato.
MB Asus Maximus XI Formula
PROC Intel i9900k@5.20GHZ
MEMO G. Skill RGB - 32 GB -
VGA Asus Strix - GTX1080TI
HD's 1 M.2 970 (01 TB) - 02 SSDs Samsung Evo 850 (01 TB)
