Catalina Hackintosh on Mobos Serie 100/200/300 / Full DSDT Patched with minimum amount of third-party kexts
yapiyapo
Donator
Donator
CPU: i7 8700k
Motherboard: z390 designare
GPU: igpu
Post by yapiyapo »
18 Nov 2019, 01:05
yapiyapo, config.plist.zip
check if work
dont work...same problem..
Post by MaLd0n »
yapiyapo, test other dev ids and ig-platform-ids
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
18 Nov 2019, 01:12
i look the dev ids for 8700k is 923e0000
ok i cheked ig platforms id : 0300923e - 0300913e - 0300983e the others is for mobile ....and dont work
maybe reinstall all??i dont know....maybe smbios??
Post by MaLd0n »
yapiyapo, try fake with kabylake
59128086 and 59120000
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
18 Nov 2019, 02:21
same,only 14mg...
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
18 Nov 2019, 02:21
i Mald0n I'm trying reinstall mac os mojave to start again ,i created a usb installer with your EFI file(EFI CLOVER Z390 DESIGNARE) and i added the config.plist that you sent me yesterday....and now i have again black screen...¿You recommend me use injectintel and intelgfx 0x12345678 only for install mojave?
thx again
Post by MaLd0n »
yapiyapo, yes
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
18 Nov 2019, 23:46
yapiyapo, yes
ok and after instalation ¿i put again your config.plist in my Efi folder?let's see if this works...i check now and i tell you
Added in 50 minutes 1 second:
18 Nov 2019, 23:46
yapiyapo, yes
i installed all correctly,i copied your EFI folder in my ssd...i installed boot clover in my ssd,everything it puts in your guide step by step...and now i reboot and have again black screen,¿I have to all time use injectintel and intelgfx 0x12345678 in boot clover??
Post by MaLd0n »
yapiyapo, u need create ur video patch for video acceleration
jbrival
CPU: Core i9 9900k
Motherboard: Gigabyte M Gaming Z370
GPU: AMD Vega 64
Post by jbrival »
Hello MaLd0n. I have same configuration as yours. Just my graphic card is Vega 64. Is your efi comptabile with it? Thanks.
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
19 Nov 2019, 01:16
ok,this is my steps:
1 - i boot with clover boot option(clover 5098) with "injectintel" "fakeid:0x12345678" and platform-id"0x12345678"
2 - in hackintoo(v2.8.3)l i checked "patch/apply current patches/system configs/gigabyte/and designare z390(cflv1) apply patch
Image[/url]
3 - i export bootloader config.plist in desktop
4 - i copied with xcode the properties line and i paste in my efi config.plist.(i erased properties line created in your config.plist for me)
Image[/url]
5 - save and i reboot my computer and i have black screen.... :wallbash :wallbash :wallbash
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
MaLd0n, i did it yuhuuu!!!
You know me....new problem jejeje it does not end....now when shutdown the computer reboot...and when go sleep the computers freeze and not sleep...
Post by MaLd0n »
yapiyapo, just use my folder + ur video patch + my dsdt full patched
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
20 Nov 2019, 15:55
Ok!When i will arrive at home a send you my runme file!thx!
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
20 Nov 2019, 15:55
here is my "iMac Send me" file¡¡
thx¡¡¡¡¡
Post by MaLd0n »
yapiyapo,
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
20 Nov 2019, 20:07
yapiyapo, DSDT.aml.zip
its work¡¡¡¡¡ thx MaLd0n¡¡¡¡¡thanks for having patience¡¡¡¡ :crazy: :crazy: :crazy: :crazy:
Post by MaLd0n »
yapiyapo, ;)
lagbooger
Donator
Donator
CPU: i5 7600K
Motherboard: GA Z270XP-SLI
GPU: Radeon RX 570
Post by lagbooger »
Howdy,
I am trying to instal to NVME drive and it constantly has kernel panic in preboot stage when it shows 11 minutes remaining. I can install Linux without issue, so I don’t think it is the drive. I originally had install on SSD working fine. Tried using CCC to clone to NVME and it would panic as well.
Half the time when I try to erase the disk it will panic as well. I have unplugged everything from the system and still face issues. Does anyone have some suggestions?
lagbooger
Donator
Donator
CPU: i5 7600K
GPU: Radeon RX 570
Post by lagbooger »
23 Nov 2019, 16:00
Update: Tried several variations and finally reverted back. I did get this panic log.anic(cpu 0 caller 0xffffff7f9ad5a4a7): nvme: "Fatal error occurred. CSTS=0x1 US[1]=0x0 US[0]=0x1c VID=0x144d DID=0xa808
. FW Revision=1B2QEXM7\n"@/BuildRoot/Library/Caches/com.apple.xbs/Sources/IONVMeFamily/IONVMeFamily-470.11.1/IONVMeController.cpp:5258
Backtrace (CPU 0), Frame : Return Address
0xffffff82dc3eb9e0 : 0xffffff801853f98b
0xffffff82dc3eba30 : 0xffffff8018676c15
0xffffff82dc3eba70 : 0xffffff801866861e
0xffffff82dc3ebac0 : 0xffffff80184e6a40
0xffffff82dc3ebae0 : 0xffffff801853f077
0xffffff82dc3ebbe0 : 0xffffff801853f45b
0xffffff82dc3ebc30 : 0xffffff8018cd2d89
0xffffff82dc3ebca0 : 0xffffff7f9ad5a4a7
0xffffff82dc3ebcc0 : 0xffffff7f9ad4547a
0xffffff82dc3ebe20 : 0xffffff8018c46659
0xffffff82dc3ebe90 : 0xffffff8018c46579
0xffffff82dc3ebec0 : 0xffffff80185811d5
0xffffff82dc3ebf40 : 0xffffff8018580d01
0xffffff82dc3ebfa0 : 0xffffff80184e613e
Kernel Extensions in backtrace:
com.apple.iokit.IONVMeFamily(2.1)[8D30E968-D445-311C-9797-06383FCC1237]@0xffffff7f9ad37000->0xffffff7f9ad79fff
dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[C01BAB4F-741F-3DDF-AC18-E4352A30AE3E]@0xffffff7f99516000
dependency: com.apple.iokit.IOPCIFamily(2.9)[E6E855AD-A5B2-3518-A997-1384B4360708]@0xffffff7f98f0f000
dependency: com.apple.driver.AppleEFINVRAM(2.1)[B17C6BF2-4CE9-35A9-ACDC-E070E82CDF7E]@0xffffff7f9acd6000
dependency: com.apple.iokit.IOStorageFamily(2.1)[CAC103D2-4533-3A81-8190-D0133B4F8626]@0xffffff7f99175000
dependency: com.apple.iokit.IOReportFamily(47)[0CAFCFA4-9263-3847-8ED0-1867D214CDD7]@0xffffff7f98e49000
BSD process name corresponding to current thread: kernel_task
Boot args: npci=0x2000 dart=0 -no_compat_check -v root-dmg=file:///Install%20macOS%20Catalina.app/Contents/SharedSupport/BaseSystem.dmg
Mac OS version:
19A583
Kernel version:
Darwin Kernel Version 19.0.0: Wed Sep 25 20:18:50 PDT 2019; root:xnu-6153.11.26~2/RELEASE_X86_64
Kernel UUID: 70EDD61F-86EE-3E1B-873F-98D909B78160
Kernel slide: 0x0000000018200000
Kernel text base: 0xffffff8018400000
__HIB text base: 0xffffff8018300000
System model name: iMac18,2 (Mac-77F17D7DA9285301)
System shutdown begun: NO
Panic diags file unavailable, panic occurred prior to initialization
System uptime in nanoseconds: 60912034063
last loaded kext at 38621896644: >!AMCCSControl 1.12 (addr 0xffffff7f9c6d0000, size 90112)
loaded kexts:
