Catalina Hackintosh on Mobos Serie 100/200/300 / Full DSDT Patched with minimum amount of third-party kexts
yapiyapo
Donator
Donator
CPU: i7 8700k
Motherboard: z390 designare
GPU: igpu
Post by yapiyapo »
15 Nov 2019, 20:09
yapiyapo, check here
ok but how to aply?i check for example designare z390(cfl v1)and after?its apply automatic in config.plist?
Post by MaLd0n »
yapiyapo, open ur config.plist with one good txt app and add into devices/properties
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
15 Nov 2019, 20:24
nothing i paste the generated patch and same 14 mg....maybe its not good aply i dont know...
1-hackintool/patch/system config/gigabyte/designare z390(cfl1)
2-go patch and i generated patch
3-copy in config.plist in line of device
4-i save reboot and same 14 mg...
uisik34
CPU: i7 9700k
Motherboard: GB Z370 Aorus Gaming Ultra
GPU: Radeon RX580
Post by uisik34 »
14 Nov 2019, 13:56
uisik34, just use Olarila folder in post installation and stay with Internal Graphics Enable
I followed all instructions and here my "iMac Send me" file. Please send me DSDT.aml for perfect mackintosh to fine my system.
Link 1 [External Link Removed for Guests]
Link 2 [External Link Removed for Guests] ... t=m2sr0xwg
What does not work is internal UHD 630 detection in system at same time with RX 580!
In generosity and helping others, be like a river
In compassion and grace, be like the sun
In concealing others’ faults, be like the night
In anger and fury, be like a dead
In humility and modesty, be like the earth
In tolerance, be like the sea
Either look as you are or be as you look
by Rumi
Post by MaLd0n »
yapiyapo, check if have ur mobo there, not designare
Added in 22 minutes 35 seconds:
uisik34,
uisik34
CPU: i7 9700k
GPU: Radeon RX580
Post by uisik34 »
16 Nov 2019, 16:52
uisik34, DSDT.aml.zip
Muito obrigado MaLd0n
by Rumi
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
16 Nov 2019, 16:52
mi new mobo is z390 designare...what am I looking ??
i send my send me if you looking
Post by MaLd0n »
yapiyapo, use option apply current patches and test patches for ur mobo
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
16 Nov 2019, 23:32
yes,the apply option is activated i know,but when i reboot i have the same 14 Mb..i dont understand hackintool....its not easy for me...sorry..
is this correct??
key>Devices</key>
	<dict>
		<key>Audio</key>
		<dict>
			<key>AFGLowPowerState</key>
			<true/>
			<key>Inject</key>
			<integer>1</integer>
			<key>ResetHDA</key>
			<true/>
		</dict>
		<key>FakeID</key>
		<dict>
			<key>IntelGFX</key>
			<string>0x12345678</string>
		</dict>
		<key>InjectHDMI</key>
		<false/>
		<key>InjectLAN</key>
		<false/>
		<key>LANInjection</key>
		<false/>
		<key>Properties</key>
		<dict>
			<key>PciRoot(0x0)/Pci(0x1f,0x3)</key>
			<dict>
				<key>AAPL,slot-name</key>
				<string>Internal@0,31,3</string>
				<key>device_type</key>
				<string>Audio device</string>
				<key>hda-gfx</key>
				<string>onboard-1</string>
				<key>layout-id</key>
				<data>
				AQAAAA==
				</data>
				<key>model</key>
				<string>Cannon Lake PCH cAVS</string>
			</dict>
			<dict>
				<data>
				BwCbPg==
				</data>
				<string>Internal@0,2,0</string>
				<key>device-id</key>
				<data>
				mz4AAA==
				</data>
				<string>VGA compatible controller</string>
				<key>enable-hdmi20</key>
				<data>
				AQAAAA==
				</data>
				<key>framebuffer-con1-busid</key>
				<data>
				BgAAAA==
				</data>
				<data>
				AQAAAA==
				</data>
				<key>framebuffer-con2-busid</key>
				<data>
				BAAAAA==
				</data>
				<data>
				AQAAAA==
				</data>
				<key>framebuffer-con2-type</key>
				<data>
				AAgAAA==
				</data>
				<data>
				AQAAAA==
				</data>
				<key>hda-gfx</key>
				<key>model</key>
				<string>???</string>
			</dict>
		</dict>
		<key>USB</key>
		<dict>
			<key>AddClockID</key>
			<true/>
			<key>FixOwnership</key>
			<true/>
			<key>HighCurrent</key>
			<false/>
			<key>Inject</key>
			<true/>
		</dict>
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
16 Nov 2019, 23:32
i MaLd0n,i tested with al mb patch and when reboot i have the same 14 mg..in hackintool i changed various platform ids and the same problems...I have done your guide hackintool step by step and i dont know where is the problem...... :?: :?: :?:
Post by MaLd0n »
yapiyapo,
<key>IntelGFX</key>
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
17 Nov 2019, 18:56
yapiyapo,
<key>IntelGFX</key>
i copied the efi folder of usb installer y my efi folder...its not correct?
Post by MaLd0n »
yapiyapo, is wrong, fake intel gfx disakle igpu
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
17 Nov 2019, 19:13
ahamm.ok now in clover i have intelgfx in blank..and in properties in clover/devices i have the config of hackintool for igpu....but i reboot and same result 14mg...its crazy¡¡¡
in Platform ID:0x3EB0007 (its macmini8,1)and my model its imacpro1.1 its correct this?
<plist version="1.0">
<dict>
	<key>ACPI</key>
	<dict>
		<key>AutoMerge</key>
		<true/>
		<key>DSDT</key>
		<dict>
			<key>Debug</key>
			<false/>
			<key>Fixes</key>
			<dict>
				<key>DeleteUnused</key>
				<false/>
				<key>FixDarwin7</key>
				<false/>
				<key>FixHDA</key>
				<false/>
				<key>FixHPET</key>
				<false/>
				<key>FixIPIC</key>
				<false/>
				<key>FixMutex</key>
				<false/>
				<key>FixRTC</key>
				<false/>
				<key>FixRegions</key>
				<true/>
				<key>FixShutdown</key>
				<false/>
				<key>FixTMR</key>
				<false/>
			</dict>
			<key>Name</key>
			<string>DSDT.aml</string>
			<key>Patches</key>
			<array>
				<dict>
					<key>Comment</key>
					<string>change GFX0 to IGPU</string>
					<key>Disabled</key>
					<false/>
					<key>Find</key>
					<data>
					R0ZYMA==
					</data>
					<key>Replace</key>
					<data>
					SUdQVQ==
					</data>
				</dict>
				<dict>
					<key>Comment</key>
					<string>change HDAS to HDEF</string>
					<key>Disabled</key>
					<false/>
					<key>Find</key>
					<data>
					SERBUw==
					</data>
					<key>Replace</key>
					<data>
					SERFRg==
					</data>
				</dict>
				<dict>
					<key>Comment</key>
					<string>change HECI to IMEI</string>
					<key>Disabled</key>
					<false/>
					<key>Find</key>
					<data>
					SEVDSQ==
					</data>
					<key>Replace</key>
					<data>
					SU1FSQ==
					</data>
				</dict>
				<dict>
					<key>Comment</key>
					<string>change SAT0 to SATA</string>
					<key>Disabled</key>
					<false/>
					<key>Find</key>
					<data>
					U0FUMA==
					</data>
					<key>Replace</key>
					<data>
					U0FUQQ==
					</data>
				</dict>
				<dict>
					<key>Comment</key>
					<string>Fix bug SKL+</string>
					<key>Disabled</key>
					<false/>
					<key>Find</key>
					<data>
					oAqTU1RBUwE=
					</data>
					<key>Replace</key>
					<data>
					oAqRCv8L//8=
					</data>
				</dict>
			</array>
			<key>ReuseFFFF</key>
			<false/>
		</dict>
		<key>DisableASPM</key>
		<false/>
		<key>DropTables</key>
		<array>
			<dict>
				<key>Signature</key>
				<string>DMAR</string>
			</dict>
		</array>
		<key>FixHeaders</key>
		<true/>
		<key>FixMCFG</key>
		<true/>
		<key>HaltEnabler</key>
		<true/>
		<key>SSDT</key>
		<dict>
			<key>DropOem</key>
			<false/>
			<key>Generate</key>
			<dict>
				<key>APLF</key>
				<false/>
				<key>APSN</key>
				<false/>
				<key>CStates</key>
				<false/>
				<key>PStates</key>
				<false/>
				<key>PluginType</key>
				<false/>
			</dict>
			<key>NoDynamicExtract</key>
			<true/>
			<key>NoOemTableId</key>
			<true/>
		</dict>
		<key>smartUPS</key>
		<false/>
	</dict>
	<key>Boot</key>
	<dict>
		<key>Arguments</key>
		<string>dart=0 slide=0</string>
		<key>CustomLogo</key>
		<false/>
		<key>Debug</key>
		<false/>
		<key>DefaultLoader</key>
		<string>boot.efi</string>
		<key>DefaultVolume</key>
		<string>LastBootedVolume</string>
		<key>Legacy</key>
		<string>PBR</string>
		<key>NeverDoRecovery</key>
		<true/>
		<key>NeverHibernate</key>
		<true/>
		<key>NoEarlyProgress</key>
		<false/>
		<key>Secure</key>
		<false/>
		<key>Timeout</key>
		<integer>5</integer>
		<key>XMPDetection</key>
		<string>Yes</string>
	</dict>
	<key>CPU</key>
	<dict>
		<key>UseARTFrequency</key>
		<false/>
	</dict>
	<key>Devices</key>
	<dict>
		<key>Audio</key>
		<dict>
			<true/>
			<key>Inject</key>
			<key>ResetHDA</key>
			<true/>
		</dict>
		<false/>
		<false/>
		<false/>
		<dict>
			<dict>
				<key>AAPL,GfxYTile</key>
				<data>
				AQAAAA==
				</data>
				<data>
				BwCbPg==
				</data>
				<data>
				mz4AAA==
				</data>
				<key>disable-external-gpu</key>
				<data>
				AQAAAA==
				</data>
				<data>
				AQAAAA==
				</data>
				<key>framebuffer-con1-alldata</key>
				<data>
				AgYKAAAEAADHAwAAAwQIAAAIAADHAwAA
				</data>
				<data>
				AQAAAA==
				</data>
				<data>
				AQAAAA==
				</data>
				<key>model</key>
			</dict>
		</dict>
		<key>USB</key>
		<dict>
			<true/>
			<true/>
			<false/>
			<key>Inject</key>
			<true/>
		</dict>
		<key>UseIntelHDMI</key>
		<false/>
	</dict>
	<key>GUI</key>
	<dict>
		<key>EmbeddedThemeType</key>
		<string>Dark</string>
		<key>Hide</key>
		<array>
			<string>Preboot</string>
		</array>
		<key>KbdPrevLang</key>
		<true/>
		<key>Mouse</key>
		<dict>
			<key>DoubleClick</key>
			<integer>500</integer>
			<key>Enabled</key>
			<true/>
			<key>Mirror</key>
			<false/>
			<key>Speed</key>
			<integer>8</integer>
		</dict>
		<key>ShowOptimus</key>
		<true/>
		<key>Theme</key>
		<string>OlarilaAnimation</string>
	</dict>
	<key>Graphics</key>
	<dict>
		<key>EDID</key>
		<dict>
			<key>Inject</key>
			<false/>
		</dict>
		<key>Inject</key>
		<dict>
			<key>ATI</key>
			<false/>
			<key>Intel</key>
			<false/>
			<key>NVidia</key>
			<false/>
		</dict>
		<key>NvidiaSingle</key>
		<false/>
		<key>RadeonDeInit</key>
		<false/>
	</dict>
	<key>KernelAndKextPatches</key>
	<dict>
		<key>AppleIntelCPUPM</key>
		<false/>
		<key>AppleRTC</key>
		<true/>
		<key>Debug</key>
		<false/>
		<key>DellSMBIOSPatch</key>
		<false/>
		<key>KernelCpu</key>
		<false/>
		<key>KernelLapic</key>
		<false/>
		<key>KernelPm</key>
		<true/>
		<key>KernelXCPM</key>
		<false/>
		<key>KextsToPatch</key>
		<array>
			<dict>
				<key>Comment</key>
				<string>External icons patch</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				RXh0ZXJuYWw=
				</data>
				<key>InfoPlistPatch</key>
				<false/>
				<key>MatchOS</key>
				<string>10.13.x,10.14.x,10.15.x</string>
				<key>Name</key>
				<string>com.apple.driver.AppleAHCIPort</string>
				<key>Replace</key>
				<data>
				SW50ZXJuYWw=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>AppleHDA Patch Assertions</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				U291bmQgYXNzZXJ0aW9uIA==
				</data>
				<false/>
				<key>MatchOS</key>
				<key>Name</key>
				<string>com.apple.driver.AppleHDA</string>
				<key>Replace</key>
				<data>
				AAAAAAAAAAAAAAAAAAAAAA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>USB port limit patch by PMHeart</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				g32IDw+DpwQAAA==
				</data>
				<false/>
				<key>MatchOS</key>
				<string>10.13.x</string>
				<key>Name</key>
				<string>com.apple.driver.usb.AppleUSBXHCI</string>
				<key>Replace</key>
				<data>
				g32ID5CQkJCQkA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>USB port limit patch #1 10.14.x modify by DalianSky(credit ydeng)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				g/sPDw==
				</data>
				<false/>
				<key>MatchOS</key>
				<string>10.14.x</string>
				<key>Name</key>
				<string>com.apple.iokit.IOUSBHostFamily</string>
				<key>Replace</key>
				<data>
				g/s/Dw==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>USB port limit patch #2 10.14.x modify by DalianSky(credit PMHeart)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				g+MP0w==
				</data>
				<false/>
				<key>MatchOS</key>
				<key>Name</key>
				<key>Replace</key>
				<data>
				g+M/0w==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>USB Port limit patch #3 10.14.x modify by DalianSky(credits PMheart)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				g/sPDw==
				</data>
				<false/>
				<key>MatchOS</key>
				<key>Name</key>
				<key>Replace</key>
				<data>
				g/s/Dw==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>USB Port limit patch #4 10.14.x modify by DalianSky(credits PMheart)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				g/8PDw==
				</data>
				<false/>
				<key>MatchOS</key>
				<key>Name</key>
				<key>Replace</key>
				<data>
				g/8/Dw==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>USB Port limit patch #1(credits PMheart)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				g/sPDw==
				</data>
				<false/>
				<key>MatchOS</key>
				<string>10.15.x</string>
				<key>Name</key>
				<key>Replace</key>
				<data>
				g/s/Dw==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>USB Port limit patch #2(credits PMheart)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				g/kPDw==
				</data>
				<false/>
				<key>MatchOS</key>
				<key>Name</key>
				<key>Replace</key>
				<data>
				g/k/Dw==
				</data>
			</dict>
		</array>
		<key>PanicNoKextDump</key>
		<true/>
	</dict>
	<key>RtVariables</key>
	<dict>
		<key>BooterConfig</key>
		<string>0x28</string>
		<key>CsrActiveConfig</key>
		<string>0x67</string>
		<key>ROM</key>
		<string>UseMacAddr0</string>
	</dict>
	<key>SMBIOS</key>
	<dict>
		<key>BiosReleaseDate</key>
		<string>09/17/2019</string>
		<key>BiosVendor</key>
		<string>Apple Inc.</string>
		<key>BiosVersion</key>
		<string>IMP11.88Z.F000.B00.1909172024</string>
		<key>Board-ID</key>
		<string>Mac-7BA5B2D9E42DDD94</string>
		<key>BoardManufacturer</key>
		<key>BoardSerialNumber</key>
		<string>C027033004NJG36A8</string>
		<key>BoardType</key>
		<integer>10</integer>
		<key>BoardVersion</key>
		<string>1.0</string>
		<key>ChassisAssetTag</key>
		<string>iMacPro-Aluminum</string>
		<key>ChassisManufacturer</key>
		<key>ChassisType</key>
		<string>0x09</string>
		<key>EfiVersion</key>
		<string>1037.0.78.0.0</string>
		<key>Family</key>
		<string>iMac Pro</string>
		<key>FirmwareFeatures</key>
		<string>0xFD8FF53F</string>
		<key>FirmwareFeaturesMask</key>
		<string>0xFF9FFF3F</string>
		<key>LocationInChassis</key>
		<string>Part Component</string>
		<key>Manufacturer</key>
		<key>Mobile</key>
		<false/>
		<key>PlatformFeature</key>
		<string>0x00</string>
		<key>ProductName</key>
		<string>iMacPro1,1</string>
		<key>SerialNumber</key>
		<string>C02T4ZZNHX87</string>
		<key>SmUUID</key>
		<string>4BB6CEE7-D6C7-4612-B64D-2303E5A738FC</string>
		<key>Trust</key>
		<true/>
		<key>Version</key>
	</dict>
	<key>SystemParameters</key>
	<dict>
		<key>InjectKexts</key>
		<string>Detect</string>
		<key>InjectSystemID</key>
		<true/>
	</dict>
</dict>
</plist>
D8V1D
CPU: i3 7350K
Motherboard: ASUS PRIME Z270-A
GPU: RX Vega 64
Post by D8V1D »
Is there anyway to stop CPU downclock when idle?
I'm on Catalina, using a ASUS Prime z270-a motherboard and i3-7350K (Kaby Lake) CPU.
I've already disable c-states, speedstep, etc in BIOS. In Windows 10 my cpu is always at 4.2ghz.
The NullCPUPowerManagement.kext also doesn't stop it from downclocking.
Post by MaLd0n »
yapiyapo, post ur config.,plist here
Added in 42 seconds:
D8V1D, u don't need disable it, if u need more power proc stay in high clock
D8V1D
CPU: i3 7350K
GPU: RX Vega 64
Post by D8V1D »
I don't want the CPU to downclock.
How do I proc stay in high clock?
Post by MaLd0n »
D8V1D, is automatic
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
18 Nov 2019, 00:24
i send you¡thx :frantics
Post by MaLd0n »
yapiyapo,
config.plist.zip
check if work
