Catalina Hackintosh on Mobos Serie 100/200/300 / Full DSDT Patched with minimum amount of third-party kexts
Post by MaLd0n »
yapiyapo, yes
yapiyapo
Donator
Donator
CPU: i7 8700k
Motherboard: z390 designare
GPU: igpu
Post by yapiyapo »
10 Nov 2019, 15:18
yapiyapo, yes
Hello MaLd0n...Seeing the problems I've had i decided to install your last mojave image but its impossible but dont boot to install macos..i viewed that there are people have problems with firmware f14 Motherboard aorus z370...and i decided downgrade to f10(its the best firmware)and have the same problem its impossible to install macos...
Help me¡¡¡plesssss :wallbash :wallbash :help :help
Post by MaLd0n »
yapiyapo, no idea what happens with ur hack
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
11 Nov 2019, 14:26
i try to change it amazon warranty and tell you.....
Post by MaLd0n »
yapiyapo, k
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
12 Nov 2019, 00:19
yapiyapo, k
Hello i returned old MB and i purchased z390 designare¡¡¡ :laugh: :laugh: I'm waiting for it to arrive¡¡
I've seen your post for this MB and i have a question... :D
Your EFI file its compatible with mi processor?i7 8700k or i need to change smbios? and the firmware F7 its the recommended??
thx¡¡
Post by MaLd0n »
yapiyapo, use f7+
u can use same smbios
uisik34
CPU: i7 9700k
Motherboard: GB Z370 Aorus Gaming Ultra
GPU: Radeon RX580
Post by uisik34 »
Can i use same instructions here for Gigabyte Z370 Aorus Gaming Ultra Ver. 1.0 (Bios F14) + i7 9700k and Sapphire Pulse RX580 8GB graphics? Is it possible to enable IGPU UHD630 as well ?
In generosity and helping others, be like a river
In compassion and grace, be like the sun
In concealing others’ faults, be like the night
In anger and fury, be like a dead
In humility and modesty, be like the earth
In tolerance, be like the sea
Either look as you are or be as you look
by Rumi
Post by MaLd0n »
uisik34, yes
uisik34
CPU: i7 9700k
GPU: Radeon RX580
Post by uisik34 »
14 Nov 2019, 13:47
uisik34, yes
i will try with your efi folder and write back here. can we enable igpu uhd630 with rx580 ? can you modify config.plist accordingly please?
by Rumi
Post by MaLd0n »
uisik34, just use Olarila folder in post installation and stay with Internal Graphics Enable
uisik34
CPU: i7 9700k
GPU: Radeon RX580
Post by uisik34 »
14 Nov 2019, 13:56
ok thanks dude
by Rumi
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
14 Nov 2019, 00:40
yapiyapo, use f7+
hello MaLd0n ¡¡ i installed the new MB and i try it OS mojave and i have a new problem....whe i boot with usb to install mojave,after the logo apple i have a black screen...i have only integral gpu...
Post by MaLd0n »
yapiyapo, use injectintel and intelgfx 0x12345678
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
15 Nov 2019, 11:07
thxxx it works¡¡¡ your dsdt its good for me?
Post by MaLd0n »
yapiyapo, yapiyapo, if i edited from ur mobo, yes
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
15 Nov 2019, 17:00
ok perfect¡ I'm seeing that I have only 14mb on intel.. :roll: :roll:
Post by MaLd0n »
yapiyapo, need a hackintool patch for video
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo »
15 Nov 2019, 17:11
ufff i followed your tutorial "[Local Link Removed for Guests] i copy y my config.plist but mmm nothing..sme 14 mg...
i copied config.plist generated with hackintool and i added in my config.plist
Post by MaLd0n »
yapiyapo, check here
