Catalina Hackintosh on Mobos Serie 100/200/300 / Full DSDT Patched with minimum amount of third-party kexts
willromano
CPU: 8700k
Motherboard: z370 gigabyte ultra gaming
GPU: gtx 1070
Post by willromano » 02 Nov 2019, 17:34
Fala MaLd0n tranquilo? Rapaz to utilizando o Virtualsmc mas não consigo visualizar a temperatura da minha rx590 no hwmonitor e nem no iStat. Precisa de algum sensor a mais?
Specs:
Catalina 10.15
Z370 ultra gaming
i7 8700k
16gb
Gigabyte Rx 590 8GB
SSD Samsung 970 evo plus 500gb
Post by MaLd0n » 02 Nov 2019, 17:38
willromano, ainda não tem esse sensor
use a fakesmc se vc quiser monitorar isso
neoprom
CPU: I7-8700K
Motherboard: ASUS z370-I
GPU: HD630
Post by neoprom » 03 Nov 2019, 10:23
01 Nov 2019, 14:55
neoprom, set Device Intelgfx 0x12345678
Thanks installation completed, but audio not recognize (realtek), have you some suggestions?
Post by MaLd0n » 03 Nov 2019, 14:36
neoprom, check useful links in my signature
neoprom
CPU: I7-8700K
GPU: HD630
Post by neoprom » 04 Nov 2019, 18:49
03 Nov 2019, 14:36
Thanks, the audio ok, but I still have 2 problems:
1-the hd 630 with 7mb, i follow your tutorial with hackintool but still not work
2- the run.me app is in loop with this text "Increased delay x2 for IOREG dump. This will take a while...(33 sec)"
Thanks.
v2world
CPU: i7 8th gen ES
Motherboard: ASRock b360 pro4
GPU: GTX Titan
Post by v2world » 06 Nov 2019, 07:25
hi maldon..
I got problem with this mobo-asrock b360..
it won't shutdown, always keep restart..
I use the refi in 1st post..
also the restart button not function well..
can u suggest anything..
thanks
titoneto
CPU: ntel Core i7-8750H
Motherboard: ntel Cannon Point HM370
GPU: GeForce GTX 1060 with Max-Q De
Post by titoneto » 06 Nov 2019, 13:18
Olá Madlon MaLd0n, Estou tentando atualizar meu Hackintosh de mojave para Catalina, pois li em alguns fóruns que estão conseguindo fazer isso diretamente pelo IOS, mas após o primeiro boot, a tela da maça anda muito pouco e trava, tentei tanto no dessa quando no note, ambos do mesmo jeito.
Alguma sugestão?
Abraços
Post by MaLd0n » 06 Nov 2019, 13:40
v2world, dsdt request topic
Added in 18 seconds:
titoneto, atualiza o clover e as kexts
neoprom
CPU: I7-8700K
GPU: HD630
Post by neoprom » 06 Nov 2019, 13:44
and for me??? :help
Post by MaLd0n » 06 Nov 2019, 13:46
neoprom, video hackintool
run_me, check video about it
ilbars
CPU: i7 6700K
Motherboard: Asus Z170-A
GPU: HD 7850
Post by ilbars » 09 Nov 2019, 10:09
Hi MaLd0n,
can you help me ?
Post by MaLd0n » 09 Nov 2019, 16:51
ilbars,
ilbars
CPU: i7 6700K
GPU: HD 7850
Post by ilbars » 09 Nov 2019, 18:45
09 Nov 2019, 16:51
ilbars, DSDT.aml.zip
Thanks man ! It's worked flawlessly. U are rock :guitar
yapiyapo
Donator
Donator
CPU: i7 8700k
Motherboard: z390 designare
GPU: igpu
Post by yapiyapo » 09 Nov 2019, 19:53
Send me iMac-de-yapi.zip
MaLd0n, hello¡¡i installed 10.15.1 and you remember my problem with usb port?....same probleme with this...i send you "send me"in case you see something...thx¡¡¡¡
Post by MaLd0n » 09 Nov 2019, 19:58
yapiyapo, create one injector with hackintool
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo » 09 Nov 2019, 20:40
09 Nov 2019, 19:58
do you know any guide for this?
Post by MaLd0n » 09 Nov 2019, 22:48
yapiyapo, check hackintool topic in insanelymac, is very easy
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo » 10 Nov 2019, 14:24
09 Nov 2019, 22:48
thx ¡¡ i tested to plug usb 2.0 stick and usb 3.0 stick and 2.0 recognizes it but 3.0 not....how to activate 3.0???
Post by MaLd0n » 10 Nov 2019, 14:46
yapiyapo, if u create a injector, usb 3 work fine
yapiyapo
Donator
Donator
CPU: i7 8700k
GPU: igpu
Post by yapiyapo » 10 Nov 2019, 14:54
create a injector its export in USBPorts.kext??
