[Guide] How to create a personal Vanilla MacOS HighSierra or Mojave Image/Installer
Post by MaLd0n » 21 May 2019, 15:38
--Donations via PayPal--
-Download MacOS App Store versions
--First we need create a .dmg--
-Go to Disk Utility/File/New Image/Blank Image
-Change Save As:, Where:, Name:, Size:, Format:, and Image Format: and Save. Done!
-Mount .dmg
--Start Process--
1- Download "Mojave MBR HFS Firmware Check Patch", "MBR-Manual-Method.dmg"
Credits: crazybirdy
* You can use other way like a 'createinstallmedia' command in Terminal
2- Open MBR-EasyInstallerMaker
3- Put your password
4- Drag MacOs.app into terminal and press Enter
5- Drag mounted partition into terminal and press Enter
6- Press Enter again
7- Wait finish
--Installing Clover bootloader--
1- Download Clover bootloader
2- Open Installer
3- Change Install Location
4- Select your disk
5- Go to Customize
6- Select "Install Clover in the ESP", go to "Boot Sectors" and select "Install boot0ss in MBR", go to "BIOS Drivers, 64 bit" and select "FSInject-64" and "ApfsDriverLoader-64" (Legacy mode)
7- Go to "UEFI Drivers" and select "DataHubDxe-64", "FSInject-64", "VboxHfs-64", "ApfsDriverLoader-64" and "AptioMemoryFix-64.efi" (UEFI mode)
8- Install Clover - This way work for Legacy and UEFI
--Editing/Adding files into Image/Installer--
1- Go to EFI/ESP and replace/put files
a- Full EFI from Olarila Image Intel PCs
EFI Olarila.zip
d- Full EFI AMD PCs
EFI AMD PCs.zip
--Change Extensions--
1- Change extensions .dmg to .raw
2- If you need update Clover bootloader, Kexts, etc, just rename .raw to .dmg
--Compress to Share--
1- Open Terminal and type
bzip2 -z
2- Drag image into terminal
-Useful Links
-Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders!
Jenny David
Developer
Developer
CPU: i5 - 3360M
Motherboard: Intel HM76 (7 Series)
GPU: Intel HD 4000
Post by Jenny David » 21 May 2019, 16:10
Great Tutorial. Thanks Daniel ;)
Post by MaLd0n » 21 May 2019, 16:22
Jenny David, Thx. ;) :cap
erroruser
CPU: AMD Ryzen 7 3700X
GPU: Sapphire rx 5700 XT
Post by erroruser » 21 May 2019, 16:53
:guitar :guitar
Asus z390-A, i9 9900k, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, sapphire rx 590, fractal celcius s36
:superman :superman
Post by MaLd0n » 21 May 2019, 16:55
erroruser, :guitar :guitar :guitar
Allan
CPU: i5-3210M
Motherboard: InsydeH20
GPU: IntelHD 4000
Post by Allan » 22 May 2019, 21:25
That's a great guide!
Excellent for those who wanna learn more, or don't wanna download "Distros" around the internet...
Good work MaLd0n, ;)
Post by MaLd0n » 22 May 2019, 22:15
Allan, :cap
dm1720x
CPU: i7
Motherboard: GA-x79-UD3
GPU: GTX680
Post by dm1720x » 29 May 2019, 00:46
21 May 2019, 15:38
viewforum.php?f=84
Post by MaLd0n » 29 May 2019, 01:36
dm1720x, ?
richwood
CPU: intel i7
Motherboard: Gigabyte
GPU: Asus
Post by richwood » 23 Jun 2019, 03:52
Greetings,
What is the best way to get the .raw image into an .iso so it can be used in Vmware Workstation?
Post by MaLd0n » 23 Jun 2019, 03:54
richwood,
hdiutil convert /path/to/example.dmg -format UDTO -o /path/to/example.iso
mv example.iso.cdr example.iso
Elton Sousa
CPU: i5-4200U
Motherboard: Acer
GPU: Nvidia
Post by Elton Sousa » 01 Jul 2019, 14:58
Good Morning!
the Mojave MBR HFS Firmware Check Patch script is not compatible with Catalina, there is another way to create the penboot
thank you!
Post by MaLd0n » 01 Jul 2019, 15:01
Elton Sousa, sudo /Applications/Install\ macOS\ Catalina.app/Contents/Resources/createinstallmedia --volume /Volumes/Catalina
richwood
CPU: intel i7
GPU: Asus
Post by richwood » 04 Jul 2019, 06:37
@mald0n
thanks buddy. I'll give that a go using hdiutil in macOS.
I tried renaming the raw file to dmg in Windows and then converting to iso using AnyToIso. It converted the file but Vmware won't recognize it.
Ok, so I've created an iso file using hdiutil and then copied the iso back to Windows. Vmware Workstation still won't recognize this iso file. Can anyone make the vmdk file from the beta 3 image?
jjpower80
CPU: i5 4440 Haswell
Motherboard: Asus B85M-G 16Gb DDR3 1600Mhz
GPU: Radeon RX560 4GB
Post by jjpower80 » 17 Jul 2019, 11:48
Hi guys, I get an error when copying the macOS image to the terminal. Nevertheless I have recorded the image of Olarila AMD in a usb and I have started it, being without advance in the beginning. I do not know if it's because of the processor that I have a Phenom II b45 ... Thanks for the tutorial😃
steezy
CPU: Intel Core i3 8100
Motherboard: ASUS Prime H310M-D
GPU: NVIDIA GeForce GT 730
Post by steezy » 13 Aug 2019, 08:41
MaLd0n, Hi Daniel, I'm trying to build new Hackintosh on;
Mother Board; ASUS H310M-D R2.0
CPU: Intel i3-8100 @3.60GHz
Graphics Built In; Intel UHD 630
Try to install Mojave and use CHIPSET SERIES 10, 20 and 30 (SKYLAKE / KABYLAKE / COFFEELAKE), but after series of codes after boot my display just went off and nothing happens...need your expertise please...many thanks!!!
Post by MaLd0n » 13 Aug 2019, 13:26
steezy, is about video, use hackintool, u can try with only InjectIntel too
steezy
Post by steezy » 14 Aug 2019, 06:48
13 Aug 2019, 13:26
Hi Daniel, still the same, up;oaded my config after hackintool patch by the way, can you look at it, thanks.
Post by MaLd0n » 14 Aug 2019, 13:48
steezy, first try with only InjectIntel
steezy
Post by steezy » 16 Aug 2019, 07:05
14 Aug 2019, 13:48
Hi Daniel, still no luck, but I'm not sure if I've done the instruction very well :D
[External Link Removed for Guests], that is the message before my screen went off. I'm planning to get compatible external graphics, but I still want to try the onboard graphics. Hope you can take a look on my config. :cap
