[Guide] Native USB Fix for Desktops - No Injector/Kext Required - SkyLake+
[Guide] Native USB Fix - No Injector/Kext Required - SkyLake+
Post by MaLd0n » 21 Jun 2019, 21:44
telepati, checked here and hs10 is not used port, enable port in ssdt
telepati
CPU: i9 9900K
Motherboard: GigaByte Z390 M Gaming
GPU: Asus ROG RX 560
Post by telepati » 21 Jun 2019, 23:43
21 Jun 2019, 21:44
Sorry, but what do you mean? Just like you said I enabled port in ssdt. Please look at the pictures isn't it right?
I also tried both connectors type but nothing changed.
Post by MaLd0n » 22 Jun 2019, 00:05
telepati, extract one send_me
telepati
CPU: i9 9900K
Post by telepati » 22 Jun 2019, 19:44
22 Jun 2019, 00:05
Here is my send me files.
Post by MaLd0n » 23 Jun 2019, 03:49
telepati, hs10 is full load
sound like a bug system
repair permission, rebuild cache
telepati
CPU: i9 9900K
Post by telepati » 23 Jun 2019, 15:07
MaLd0n, I made a couple of changes in BIOS enabled XHC and 4G then repair permission and rebuild the cache,
Now everything works.
The picture you released it says AppleUSB20InternalHub now it says AppleUSB20Hub. But I will make a test with default BIOS settings. Cause I want to be sure this is BIOS related issue or not.
Edit: Test it with Default BIOS settings not changed. Everything still works. Thats mean repairs and rebuild cache fixed my problem. Thank you. :frantics
aldebaran
CPU: i5 8600k
Motherboard: Z370 gaming 3
GPU: RX560
Post by aldebaran » 28 Jun 2019, 11:14
MaLd0n,
I have different SSDT-5-AMI.aml file. So what should I do to get fixed SSDT file?
Here is my USB SSDT file.
Thank you for any help.
Regards, Aldebaran
Post by MaLd0n » 28 Jun 2019, 12:31
aldebaran, just create devices and check all _UPC
aldebaran
CPU: i5 8600k
GPU: RX560
Post by aldebaran » 02 Jul 2019, 20:38
MaLd0n,
What do you mean by creating device?
Regards, Aldebaran
Post by MaLd0n » 02 Jul 2019, 20:45
aldebaran, is a methods for identify ports
Method (MALD for example
swede420
CPU: i7 6700 3.4
Motherboard: GA-Z170M-D3H
GPU: SAPPHIRE RX 570 PULSE
Post by swede420 » 12 Jul 2019, 10:13
Hi Madl0n!
This is my SSDT for usb, I want do do native USB patches but I am confused about all those DP01,DP02, exec...
Cn you please help me?
Thanks in advance.
onemanosx
Post by onemanosx » 12 Jul 2019, 11:47
MaLd0n, My OEM does not contain UMAP and I have difficulty enabling the ports. Even adding UMAP didnt help either.
MSI B360 Gaming Arctic
Post by MaLd0n » 12 Jul 2019, 15:50
swede420, u need test
Added in 2 minutes 3 seconds:
onemanosx, have many variations
in my notebook for example
0xff enable and Zero disable
swede420
CPU: i7 6700 3.4
Post by swede420 » 12 Jul 2019, 20:13
12 Jul 2019, 15:52
I have bild this one but when I boot with it no USB att all. Can you please take a look?
Post by MaLd0n » 12 Jul 2019, 20:27
swede420, u have a many ports disable, many many, check all and put One
swede420
CPU: i7 6700 3.4
Post by swede420 » 12 Jul 2019, 20:42
12 Jul 2019, 20:27
How do I check? Is there a utility for it?
Post by MaLd0n » 12 Jul 2019, 20:50
swede420, read first post, u need check all _UPC
swede420
CPU: i7 6700 3.4
Post by swede420 » 12 Jul 2019, 23:06
Now I thought I got it right but one port does not work. Tried to enable the disabled ports one by one but it did not work. What can I do?
Post by MaLd0n » 13 Jul 2019, 01:05
swede420, full efi folder, replace, reboot and check if work, don't change nothing, just replace full efi
EFI.zip
swede420
CPU: i7 6700 3.4
Post by swede420 » 13 Jul 2019, 20:43
13 Jul 2019, 01:05
EFI.zip
Thankyou, but it did not work. The same USB port still don't work, it is working until boot though.
