🎉 NEW Discord server!
[Guide] Native USB Fix for Desktops - No Injector/Kext Required - SkyLake+
piyushrawal
CPU: i7-7700
Motherboard: MSI H270-A Pro
GPU: RX 580
[Guide] Native USB Fix - No Injector/Kext Required - SkyLake+
Post by piyushrawal »
04 Jun 2019, 23:38
piyushrawal, DSDT.aml.zip
now, just change One to Zero if u need disable
MaLd0n, am I to use it alongside SSDT-4-xh_rvp08.aml or just the DSDT?
I am sorry for being a total noob.
And thanks a ton for your help. :)
Post by MaLd0n »
piyushrawal, use both files ssdt and dsdt, only it with my EFI folder
piyushrawal
CPU: i7-7700
GPU: RX 580
05 Jun 2019, 00:37
Got it! Thanks a lot. :crazy:
onemanosx
Post by onemanosx »
For laptops (at least for my skylake laptop), it is also worth to know that native _UPC or _PLD is within DSDT itself. Similarly, like how Maldon had described all we need to do is replace zero to one and define usb type in the scope of UUPC and UPLD as per my example.
Hope this helps for some of us.
MSI B360 Gaming Arctic
Post by MaLd0n »
14 Jun 2019, 13:39
:guitar
Canela
Donator
Donator
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela »
Hi MaLd0n, is your edited SSDT for Z390 M Gaming? Can I use it?
Post by MaLd0n »
Canela,
SSDT-6-A M I.aml.zip
Canela
Donator
Donator
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela »
15 Jun 2019, 23:55
Canela, SSDT-6-A M I.aml.zip
Thanks! ;)
telepati
Geek
Geek
CPU: i9 9900K
Motherboard: ASUS TUF Z390 Gaming Plus
GPU: Asus ROG RX 560
Post by telepati »
15 Jun 2019, 23:55
Can I also use this? Our motherboard is the same. Should I make any changes? If I can use this, can or should I remove these kexts and SSDT;
SSDT-UIAC.aml
XHCI-unsupported.kext
USBInjectAll.kext
Post by MaLd0n »
telepati, yes, use ssdt with usb patch limit port for raise one port more, this mobo have a 16 usb ports
Canela
Donator
Donator
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela »
MaLd0n, following your guide I have edited your SSDT to change some ports. I do not use the HS09, so I have a total of 15 ports ... does that mean I can erase the USB Port Limit Patches?
Post by MaLd0n »
Canela, if u use only 15 ports, yes. Don't need usb limit port
Canela
Donator
Donator
CPU: i7-8700
GPU: RX 590 8GB
Post by Canela »
16 Jun 2019, 20:55
Perfect thanks! :frantics
telepati
Geek
Geek
CPU: i9 9900K
Post by telepati »
16 Jun 2019, 17:02
Internal USB 2.0 didn't work. No Bluetooth hardware anymore.
These are my all 15 ports;
Post by MaLd0n »
telepati, u need change things, i have many devices usb like bt
telepati
Geek
Geek
CPU: i9 9900K
Post by telepati »
19 Jun 2019, 23:43
Thanks to the warning. I used 15 ports and removed patch limit. My HS10 is the Internal and using Bluetooth connection. Just like you said on the first page I use GUPC (One) and enabled it. But still doesn't work, still says no Bluetooth hardware. I am totally losing my Bluetooth. Could you please tell me what am I doing wrong?
Post by MaLd0n »
telepati, u try other like 0x03...
telepati
Geek
Geek
CPU: i9 9900K
Post by telepati »
21 Jun 2019, 03:11
What do you mean by that? Is MALD instead of GUPC for internal HS10?
Edit:
I tried all connectors made all HSxx to MALD, TUPC, GUPC but nothing changes no internal USB and No Bluetooth connection. I think no native USB for me.
Post by MaLd0n »
telepati, test port with one device usb2 or usb 3
telepati
Geek
Geek
CPU: i9 9900K
Post by telepati »
21 Jun 2019, 19:08
I did but nothing changed. I just gave up. This will not work for me :wallbash
