[Guide] Native USB Fix for Desktops - No Injector/Kext Required - SkyLake+
Post by MaLd0n » 20 May 2019, 18:36
-All credits to Piker-Alpha
Here
and here
1- Check OEM SSDT about USBs, in my case is SSDT-6-A M I.aml, i'm using a Z390 mobo
2- Create Methods into SSDT OEM inside Scope _SB.PCI0.XHC.RHUB, Internal and USB 2 is native, just create USB 3, USB-C
We just need duplicate Methods (GUPC for example) native from our ACPI table and Inject values
Connector types in the ACPI specification
0xFF - internal - GUPC
Zero - USB 2 - TUPC
0x03 - USB 3 - MALD
0x09 - USB-C - MAL0 (Same HSxx/SSxx in both orientations, then it has an internal switch)
0x0A - USB-C - MAL1 (Different HSxx/SSxx in each orientation, then it has no switch)
-Example
GUPC and TUPC is a native Methods
Method (GUPC, 1, Serialized)
Name (PCKG, Package (0x04)
Zero,
0xFF,
Zero,
Zero
PCKG [Zero] = Arg0
Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.GUPC.PCKG */
Method (TUPC, 1, Serialized)
One,
Zero,
Zero,
Zero
PCKG [Zero] = Arg0
Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.TUPC.PCKG */
Method (MALD, 1, Serialized)
Zero,
0x03,
Zero,
Zero
PCKG [Zero] = Arg0
Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.MALD.PCKG */
Method (MAL0, 1, Serialized)
Zero,
0x09,
Zero,
Zero
PCKG [Zero] = Arg0
Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.MAL0.PCKG */
Method (MAL1, 1, Serialized)
Zero,
0x0A,
Zero,
Zero
PCKG [Zero] = Arg0
Return (PCKG) /* \_SB_.PCI0.XHC_.RHUB.MAL1.PCKG */
3- Enable or Disable USB ports
-Check example TUPC
Look at Method _UPC - USB Port Capabilities
Enable = One
Disable = Zero
Example
Scope (\_SB.PCI0.XHC.RHUB.HS01)
Method (_UPC, 0, NotSerialized) // _UPC: USB Port Capabilities
If ((H1TC == Zero))
If (((UMAP & One) == One))
Return (TUPC (One))
Else
Return (GUPC (Zero))
Else
Return (\_SB.UBTC.RUCC (H1CR, One))
If you need identify your USB ports like USB-C for example, change TUPC/GUPC to MAL0
Scope (\_SB.PCI0.XHC.RHUB.SS01)
If ((H1TC == Zero))
Return (MAL0 (One))
Else
Else
Zero - USB 2 - TUPC
0x03 - USB 3 - MALD
-USB 2 PORTS inside USB 3 BUS, just Inject USB 3
-My SSDT with edits
SSDT-6-A M I.aml.zip
-Use a Diff Merge to compare files
-Original
ORIGINAL.txt.zip
-Edited
EDITED.txt.zip
-Download Diff Merge
[External Link Removed for Guests]#
Allan
CPU: i5-3210M
Motherboard: InsydeH20
GPU: IntelHD 4000
[Guide] Native USB Fix - No Injector/Kext Required - SkyLake+
Post by Allan » 28 May 2019, 10:44
Excellent guide MaLd0n, awesome!!
Bit by bit we will understanding more about ACPI patching, thank you.
But one doubt, I need to keep the USB Injection at Clover? E.g: Devices > USB > Inject/FixOwnership/HighCurrent
Post by MaLd0n » 28 May 2019, 12:35
Allan, u can use it in clover without problem
Allan
CPU: i5-3210M
GPU: IntelHD 4000
Post by Allan » 28 May 2019, 16:28
28 May 2019, 12:35
Got it ;)
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 30 May 2019, 05:21
@MaLd0n,
I was waiting a long time for something like this.
Unfortunately I didn't manage to create a correct one.
If you have the time , can you help me out ?
I'm attaching my native acpi ssdt for usb and my current usb configuration.
Thank you in advance.
Post by MaLd0n » 30 May 2019, 11:29
mathewgx, check if work
SSDT-2-xh_OEMBD.aml.zip
the image have all ur real ports?
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 30 May 2019, 18:22
Working great !!!
Just had to change a port from usb3 to usb2 but that's nothing.
Thank you , again , my friend.
Post by MaLd0n » 30 May 2019, 19:43
mathewgx, ;)
vinpo
CPU: Intel I7 6700K
Motherboard: Asus Z-170A
GPU: Sapphire RX 580 Nitro+ 8gb
Post by vinpo » 01 Jun 2019, 16:50
Hi, guys
ffor which version of macOS is this method applicable?
Thanks everyone
Post by MaLd0n » 01 Jun 2019, 21:57
vinpo, all
piyushrawal
CPU: i7-7700
Motherboard: MSI H270-A Pro
GPU: RX 580
Post by piyushrawal » 04 Jun 2019, 20:29
Hey, thanks for the guide but it seems I didn't grasp it right.
Do you mind looking at what I did wrong?
Also, can I also remove XHCI-unsupported.kext if I use this method?
Post by MaLd0n » 04 Jun 2019, 20:43
piyushrawal, dont need usbinjectall and XHCI-unsupported.kext
use ssdt with usb patch limit and u don't need more
SSDT-xh.aml.zip
if u need change connectors, check inside all _upc and change
Zero - USB 2 - TUPC
0x03 - USB 3 - MALD
0x09 - USB-C - MAL0
0x0A - USB-C - MAL1
btw, SSDT-xh is a native name or u renamed it? use a native name and clover replace a correct table, i never test with rename
piyushrawal
CPU: i7-7700
GPU: RX 580
Post by piyushrawal » 04 Jun 2019, 21:13
04 Jun 2019, 20:43
SSDT-xh.aml.zip
Zero - USB 2 - TUPC
0x03 - USB 3 - MALD
0x09 - USB-C - MAL0
0x0A - USB-C - MAL1
It's working with limit patch. But I am unable to disable USB ports to get it under 15 limit by setting Return (MALD (One)) to Return (MALD (Zero)). It has no effect.
And yes, renaming was a bad idea. It doesn't work if renamed.
Post by MaLd0n » 04 Jun 2019, 21:16
piyushrawal, remove ssdt uiac
piyushrawal
CPU: i7-7700
GPU: RX 580
Post by piyushrawal » 04 Jun 2019, 21:32
04 Jun 2019, 21:16
It's deleted. If you wish to take a look, I've attached the clover folder. It contains stock ssdt in origin folder as well.
Post by MaLd0n » 04 Jun 2019, 22:51
piyushrawal, replace full EFI, reboot and extract new send_me, don't change nothing
EFI.zip
piyushrawal
CPU: i7-7700
GPU: RX 580
Post by piyushrawal » 04 Jun 2019, 23:18
04 Jun 2019, 22:51
EFI.zip
MaLd0n, there you go.
Post by MaLd0n » 04 Jun 2019, 23:20
piyushrawal, run my app for full dump
--Run_Me
piyushrawal
CPU: i7-7700
GPU: RX 580
Post by piyushrawal » 04 Jun 2019, 23:28
MaLd0n, my apologies for misunderstanding.
Post by MaLd0n » 04 Jun 2019, 23:38
piyushrawal,
now, just change One to Zero if u need disable
