OS X 10.8 Mountain Lion bootable USB
Mr.KiLLeR
CPU: Intel Core i5-3317U
Motherboard: Intel
GPU: Intel HD4000
Re: OS X 10.8 Mountain Lion bootable USB
Post by Mr.KiLLeR » 30 Sep 2013, 12:49
mike146 wrote:Reply -> My problem is that i don't have QE/CI ( and my video card isn't recognized properly -> 64mb vram instead of 512mb and it's quite slow for some animations )
Btw , i know that i need to do something with some numbers list but i don't know where.
What i'm supposed to do i think :
ig-platform-id: 01660000, Stolen is FB RAM: 96MB, Pipes: 3, Ports: 4, FBMem: 3
ig-platform-id: 01660001, Stolen is FB RAM: 96MB, Pipes: 3, Ports: 4, FBMem: 3
ig-platform-id: 01660002, Stolen is FB RAM: 64MB, Pipes: 3, Ports: 1, FBMem: 1
ig-platform-id: 01660003, Stolen is FB RAM: 64MB, Pipes: 2 Ports: 2, FBMem: 2
ig-platform-id: 01660004, Stolen is FB RAM: 32MB, Pipes: 3, Ports: 1, FBMem: 1
ig-platform-id: 01660008, Stolen is FB RAM: 64MB, Pipes: 3, Ports: 3, FBMem: 3
ig-platform-id: 01660009, Stolen is FB RAM: 64MB, Pipes: 3, Ports: 3, FBMem: 3
ig-platform-id: 0166000A, Stolen is FB RAM: 32MB, Pipes: 2 Ports: 3, FBMem: 2
ig-platform-id: 0166000B, Stolen is FB RAM: 32MB, Pipes: 2 Ports: 3, FBMem: 2
ig-platform-id: 01620005, Stolen is FB RAM: 32MB, Pipes: 2 Ports: 3, FBMem: 2
ig-platform-id: 01620006, Stolen RAM for FB: 0MB, Pipes: 0, Ports 0, FBMem: 0
ig-platform-id: 01620007, Stolen RAM for FB: 0MB, Pipes: 0, Ports 0, FBMem: 0
I don't know where i need to modify something nor how.
Thanks !
Use latest Chameleon and I guess that should be fine :)
Acer Aspire v5-571P
Intel Core i5-3317U @ 1.70GHZ
6GB RAM
500GB HDD
Windows 8 64Bit
andy5925
CPU: i7 4770k
Motherboard: asus z87-a
GPU: gtx 770 windforce
Post by andy5925 » 01 Oct 2013, 14:38
After installation from USB, it says successful and then reboots. I have the boot order to set to USB first, but when the USB comes back up, I do not see my HD to boot into the operating system. The partition is set to MBR and I believe it is set to active (although I could use some help in how I can verify it is active). Any help would be greatly appreciated.
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 01 Oct 2013, 15:38
is u hd controller set to ahci ?
or sata mode ?
andy5925
CPU: i7 4770k
Post by andy5925 » 01 Oct 2013, 18:10
artur-pt wrote:hello
or sata mode ?
Soooo looks like I may be out of luck. I was trying to complete this on my old Dell XPS 420 system with bios A07. I don't see any options in the bios to modify the HD controller settings. Unless anyone has any ideas I may be stuck.
andy5925
CPU: i7 4770k
Post by andy5925 » 01 Oct 2013, 18:46
Ok I got the drive to display and chose to boot from the HD where OSX was installed. My new issue is that I get a message that says "still waiting for root device" and a grey box with an "x" through it appears on the screen. Help?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 01 Oct 2013, 20:19
see this
and see bios sets
i don't know if ever work 10.8 ...
xFroggy
CPU: i7
Motherboard: Dell XPS 15 (NOT RUNNING OSX)
GPU: 640M
Post by xFroggy » 06 Oct 2013, 04:28
I installed OS X to the hard drive then I go back to boot into the USB and now it doesn't show the hard drive so I cant actually set up OS X I have tried everything I know, Different Hard Drives, Different SATA Operation (AHCI which is default) ATA and Legacy I have NO Idea why this isnt booting I have tried Clover and Chameleon they BOTH don't show it. Please help!
djyteck
CPU: E-450
Motherboard: A50M
GPU: HD6320
Post by djyteck » 08 Oct 2013, 12:29
Hi community,
I try to install Niresh Mountain Lion 10.8.2 on my laptop HP DM1 4136SF (release in 2012).
Here's my config :
• CPU : AMD E-450 dualcore (1.65Ghz)
• Chipset : AMD A50M FCH
• RAM : 4 Go
• HDD : SATA 500 Go
• Graphic processor : AMD Radeon HD 6320
The installation is performed correctly, but at the first boot i have a Kernel Panic. (see pictures)
I can boot my pc only with the bootflag "-x" (Safe Mode),
I think the problem isn't critical, but i can't found the issu at my problem...
So, i hope, you can be help me in my step.
Thanks.
Y.
mendietinha
CPU: i5 750
Motherboard: Intel
GPU: GTX760
Post by mendietinha » 08 Oct 2013, 13:06
probably you can make it better with snow leopard.
PimentelX86
Veteran
Veteran
CPU: i7 2600
Motherboard: IPMH61R1
GPU: GT 610
Post by PimentelX86 » 08 Oct 2013, 13:31
Hello
If you change to a retail installation
Will be better to help you.
Kuvar
CPU: i5-2450M
Motherboard: Intel PCH HM67Dell Vostro 3550
GPU: ATI Mobility Radeon HD 6630m
Post by Kuvar » 11 Oct 2013, 12:07
Hye everyone
I have Dell V3550
It has switchable graphics,which is eating my Battery,Is there any way by which I use Graphic support or I can disable it in Mountain lion 10.8.1
Dell Vostro 3550, i5-2450M(2.50 GHz-Turbo Boost3.10 GHz) , RAM - 4 GB , Graphic - ATI Mobility Radeon HD 6630m 1GB(Switchable Graphics) , Chipset Intel PCH HM67, Yosmite 10.10/ Win 8.1 Pro x64/ Dualboot Chamelionwizard
Lefe1985
CPU: Xeon X5670
Motherboard: Asus P6X58D-E
GPU: AMD HD5850
Post by Lefe1985 » 14 Oct 2013, 13:20
Hi,
I managed to successfully configure my hackintosh but there's only one thing ! I can't get to make my USB MIDI keyboard controller to work.
I wanted to know if there were specific drivers for that or is it AppleHDA based ?
Typing system_profiler SPUSBDataType in a terminal doesn't show up any device when connected.
Thanks for your replies
jtroc6
CPU: i3
Motherboard: intel
GPU: dont know
Post by jtroc6 » 18 Dec 2013, 08:49
no admin access after in stall in vb
hamid37
CPU: core i7
Motherboard: lenovo x201
GPU: 640 M
Post by hamid37 » 24 Mar 2014, 16:21
Cassio wrote:Access [External Link Removed for Guests] to get download link (channel topic).
Image size: 5.020.384.768 bytes (need at least an 8 GB pen drive)
MD5 (OS X 10.8 Install USB.raw) = 4251f2d2866417add966ffcec848cc4f
Contents:
OS X Mountain Lion GM Seed (Build 12A269)
MD5 (InstallESD.dmg) = 8b4869920cd740414fe6b7e3f0b1be3e
Modified files:
System/Installation/Packages/OSInstall.mpkg
System/Library/PrivateFrameworks/Install.framework/Frameworks/OSInstall.framework/Versions/A/OSInstall
Added files:
System/Library/Caches/com.apple.kext.caches/Startup/Extensions.mkext
boot (Chameleon v2.1svn r2003)
Extra/Preboot.dmg
Preboot.dmg contents:
Extensions.mkext
org.chameleon.Boot.plist
Extensions.mkext contents:
AHCIPortInjector.kext
AppleACPIPS2Nub.kext
FakeSMC.kext
IOAHCIBlockStorageInjector.kext
NullCPUPowerManagement.kext
PXHCD.kext
VoodooPS2Controller.kext
VoodooPS2Keyboard.kext
VoodooPS2Mouse.kext
VoodooPS2Trackpad.kext
How to use:
1 - Copy the .raw file to an USB stick using SUSE Studio Image Writer.
If you have error during copy, eject and re-connect the pen drive. When Windows asks if you want to format it, cancel and run Image Writer again.
If the problem persists, disable your anti-virus software, it may be blocking raw write to the drive.
Another Image Writer for Windows, if SUSE doesn't work
2 - Boot the USB drive and install.
If you need, type [External Link Removed for Guests], for example:
-v (verbose boot) [default]
-x (safe)
-s (single user)
GraphicsEnabler=yes (enable graphics card drivers) [default]
USBBusFix=yes (fix problems with USB devices)
npci=0x2000 (use if boot stops at "PCI configuration begin")
cpus=1 (for HP with [External Link Removed for Guests], use while you don't have patched lapic kernel)
If you need, use [External Link Removed for Guests] to remove kexts which are causing problems (System/Library/Extensions) and use the flag -f (ignore caches) at boot, or remove /System/Library/Caches/com.apple.kext.caches/Startup/Extensions.mkext
If you get KP related to ApplePolicyControl.kext remove /System/Library/Extensions/AppleGraphicsControl.kext/Contents/PlugIns/ApplePolicyControl.kext
If boot stops right before reaching the installer, or graphics aren't working right, remove video kexts and boot with GraphicsEnabler=No -f
ATI = ATI*
Intel = AppleIntelHD* AppleIntelSNB*
nVidia = GeForce* NVDA*
You need at least one free partition, use Disk Utility (in the Utilities menu) to erase it as Mac Os Extended (Journaled).
If you want to install Chameleon (the boot loader) in this partition and you use MBR (not GUID, like if you already have Windows in the HD), it must be a primary (not extended/logical) partition.
Wait for the installation to finish and restart.
3 - Boot the USB drive, then choose to boot the HD you just installed OS X (not the installer USB again).
4 - Install Chameleon and the Extra folder to the HD.
I recommend using Chameleon Wizard to install and create/configure org.chameleon.Boot.plist and SMBIOS.plist in /Extra folder.
You can also download an installer (pkg) or binaries package (i386) [Local Link Removed for Guests]
5 - Install essential and other kexts you may need (network, audio, etc).
FakeSMC.kext is always needed.
While you don't have power management fixed, you will probably need NullCPUPowerManagement.kext.
If you use PS/2 keyboard or a laptop you will need VoodooPS2Controller.kext (or ApplePS2Controller.kext) and AppleACPIPS2Nub.kext.
How to find kexts for your hardware
I recommend using Kext Wizard to install kexts.
Post install issues:
Video (if you had to remove kexts to install) [Local Link Removed for Guests]
boot0: error [Local Link Removed for Guests]
CMOS reset after sleep [Local Link Removed for Guests]
Still waiting for root device using kernelcache [Local Link Removed for Guests]
No admin account [Local Link Removed for Guests]
When you format the USB drive as FAT/NTFS you'll notice its size was reduced. Just open Disk Management (Administrative Tools), remove the 4,68 GB partition and create a new one using all the drive.
hi how cam I access chat ?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 31 Mar 2014, 12:34
reading ... the forum..
fatboynate
CPU: i5 3570K Ivy Bridge
Motherboard: GA-Z77-D3H
GPU: ATI Radeon HD 7770
Post by fatboynate » 31 Mar 2014, 20:03
Hi there i have my desktop running mavericks and thought i'd get my laptop running ML but i cant get it to boot to the inststaller, i have prepatched my kernal so i dont have to use the cpus=1 boot flag.
i have all my kexts ready to use, once im at the desktop but im stuck here before the installer boots up.
[screenshot]
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 31 Mar 2014, 20:18
the notebook is ?
yellow ?
only a magician can help u .. with that kind of info.
sllz
CPU: Intel Core i5 760
Motherboard: ASUSTeK Computer Inc
GPU: NVIDIA GrForce 8400GS
Post by sllz » 29 Apr 2014, 09:07
what should I do, always fails when trying to create a new entry..
I use Niresh's OS X 10.8.2 if it's wrong? please answer..
diskjockey
CPU: q6600
Motherboard: intel dp35dp
GPU: gigabyte nvidia 210
Post by diskjockey » 12 Aug 2014, 09:26
first i would like to say this is amazing work thank you
second , im currently on 10.6.8 and created the usb with dd command
but when im trying to boot from the usb i reach the familiar screen i used to have
it seems like i cannot boot from the usb stick
is it because im already have camilion on my hard drive?
in another words, if im upgrading not installing fresh , how do i boot from usb ?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 12 Aug 2014, 10:03
we don't give any support outside this forum...
we don't use that kind of image .. so how can we talk about ?
use one of ours image .. and we can talk about any problem u have..
