DSDT patch requests
reym
CPU: i7 8Gen Whiskey Lake
Motherboard: Razer Blade
GPU: MX150 4GDDR4
24 Jun 2019, 20:11
23 Jun 2019, 23:11
pauliebb, DSDT.aml.zip
Added in 3 minutes 48 seconds:
areg_noid, DSDT.aml.zip
check if work
Added in 47 seconds:
ariegrinder, extract new send_me
reym, extract new send_me
Added in 38 seconds:
news104, use hackintool
Added in 3 minutes 59 seconds:
rankawarj, i edit ur file, dsdt is same for all system, extras check useful links in my sig
Added in 1 minute 10 seconds:
rodrigo.bar1995, use o aplicativo "captura de imagem"
heere it is, I've run a new send me and attached it here.
thank you.
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
24 Jun 2019, 22:06
Hoping for keyboard backlight on my asus laptop please
ASUS VivoBook Flip 14 TP412UA-IH31T
claaron1000!
CPU: 3930K
Motherboard: Asrock Extreme6
GPU: Nvidia gtx 670 FTW
24 Jun 2019, 23:02
23 Jun 2019, 07:06
Added in 3 minutes 33 seconds:
claaron1000!, disable hibernate and auto sleep
Thank you again for all your help. sadly still no luck. all power options are disabled in bios, clover, and Power Management. still freeze and shutdown.
if I let the computer sit at the Log In screen but do not log in it stays runner for days.
Im trying to do a fresh install on a start drive now but can't get around a Error Loading Kernel Cache in clover. Any ideas?
I tried this before using your DSDT ands install went fine. Oddly I swapped back to my old SSDT's and still I'm getting the Error.
Thanks again for any help.
RubahGeni
CPU: Intel i7 8700T
Motherboard: Gigabyte B360n
GPU: AMD RX580
25 Jun 2019, 02:43
20 Jun 2019, 02:23
Added in 1 minute 43 seconds:
RubahGeni, RUN REPAIR PERMISSIOMS
When i changed SMBIOS or GPU, DSDT must be recreated again?
Thanks MaLd0n.
XInflict
CPU: Intel Core I7 3770
Motherboard: Asus P8Z77V-LX
GPU: Nvidia GeForce 970
25 Jun 2019, 04:55
Send me Gabriels-iMac.zip
I'm having a problem with my network, when I used the Chipset config it stoped showing my network card on PCI boards, now it don't show neither on network cards or PCI.
My actual problems are, Ethernet, Audio and Nvidia video (cont set to 1080p).
Processor: Intel Core I7 3770, GPU: NVIDIA GTX 970 and Motherboard: ASUS P8Z77-LX (up to date UEFI BIOS)
TylerHats
CPU: Intel Core i7-8700k
Motherboard: MSI MPG Z390 Gaming Plus
GPU: ASUS ROG Strix RTX 2070 O8G
25 Jun 2019, 07:40
MaLd0n,
Thanks for your help so far! I hadn't even noticed my mistake with the smbios. With the new patch and the corrected smbios, however, nothing has changed. The bluetooth seems a little more glitchy and the wifi portion still has no function despite being on the same device as the bluetooth, but I finally have been able to get the ethernet working. I can confirm that I am able to sign in and things like iMessage and FaceTime work, however Siri does not. Also, there is still no sleep functionality. It simply freezes the screen for a moment and then resumes. Thanks again for all your help! If anything else can be done, please let me know.
Send me.zip
UPDATE: After some exploring, I've discovered that all of my Motherboard's audio input and outputs have disappeared. They were previously visible and fully functioning. I'm not sure what has prompted this change.
Always trying to do something that's probably impossible ¯\_(ツ)_/¯
EDECAT
CPU: I5-2550k
Motherboard: GA-Z68AP-D3 v2.0 UA9 UEFI Bios
GPU: Zotac GT730 4GB DDR5
25 Jun 2019, 08:27
Hi , I can t install gt730 Nvidia
Hootpy
CPU: Xeon E5-2630v2 x2
Motherboard: X79-8D Huannan
GPU: RX 470
25 Jun 2019, 09:20
Can you help me patch the DSDT? Thank you so much! :D :D :D
sinochef
CPU: 8750
Motherboard: Msi
GPU: 2060
25 Jun 2019, 11:33
Hi my laptop is stuck when I try to reboot or shut down and the message is will be calling reboot(2) with flags: 0x0
adibaulia
CPU: Intel I5-7200U
Motherboard: Acer laptop e5-475g
GPU: GT 940MX
25 Jun 2019, 13:32
hei, this is my send-me file! thank u in advance!!
fbfreitas
CPU: Intel Core I5 4440
Motherboard: PCWARE IPMH81G1
GPU: INTEL HD GRAPHICS 4600
25 Jun 2019, 14:14
bisk8s,
Perfeito! O esquema do ultimo vídeo funcionou!
Só não consegui ainda fazer o audio sair pelo HDMI.
O meu áudio funciona pelo HDMI, mas ele demora aproximadamente uns 10 segundos pra sair e não tenho controle de volume no HDMI. Isso eu não sei se é normal ou se tem correção, no meu caso, uso um Desktop e a placa gráfica é uma OnBoard Intel HD Graphics 4600.
Para a sua placa, as informações que possuo são essas:
ÁUDIO HDMI - INTEL HD4000 MOBILE
Requisitos:
1- GRÁFICO INTEL HD4000 PERFEITAMENTE INJETADO.
2- CHIP DE ÁUDIO ONBOARD INJETADO.
3- PATCH VIA CLOVER.
Patch’s [Kernel and Kext Patches]:
—1—
Find: 02050000 00040000 07040000
Replace: 02050000 00080000 06000000
Comment: HDMI-audio HD4000
—2—
Find: 03040000 00040000 81000000
Replace: 03040000 00080000 06000000
—3—
Find: 04060000 00040000 81000000
Replace: 04060000 00080000 06000000
E, como fala em chip de áudio injetado, tem que testar os Layout-id:
Realtek | ALC269 | 0x100004, 0x100100, 0x100202, 0x100203 layout 1-11, 13-21, 27-30, 32, 33, 35, 40, 45, 55, 58, 66, 76, 88, 93, 99, 127, 188
Abraço e boa sorte!
hunck
CPU: 8700K
Motherboard: Z370XP-SLI
GPU: VEGA56
25 Jun 2019, 15:45
hi MaLd0n
I can not find same motherboard (DSDT)
can you help me ?
M/B: Intel DZ87KLT-75K
VGA:Nvidia GTX960
Silapakdeewong2546
CPU: -
Motherboard: -
GPU: Intel HD Graphics 4000
25 Jun 2019, 16:58
Hello I need DSDT Patch for my laptops : Lenovo G400 [I can't find DSDT Patch for my laptops]
CPU : Intel Core i5 3230M [3rd Gen]
GPU : Intel HD Graphics 4000 / AMD Redeon HD 8500M
Please help me I need DSDT Patch for my Hackintosh , Thanks... .
25 Jun 2019, 16:59
RubahGeni, no, use same file
-Donated? Send me one PM-
juanvascas
Geek
Geek
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
25 Jun 2019, 17:48
24 Jun 2019, 16:58
Hi I am using Mojave and I can boot (with only hot patches) with most things working, I read in a post from MaLd0n abouth the benefits of a proper DSDT patched. I would like to have one if possible.
Thanks!
I have reuploaded my Send Me, I think the system DSDT was not properly extracted maybe? Not sure was getting some weird reboots even with a clean DSDT so extracted them again.
arunkumarnk
CPU: i5 4690
Motherboard: asus b85mk
GPU: RX560
25 Jun 2019, 18:32
i am having issue with nvidia gtx970, when dual monitor is connected, no display on both monitor. if i plug monitors after booting it works. but when i connect 2 monitors before booting , no display
i am using asus z170 pro gaming motherboard
os olarila high sierra 10.13.6
RubahGeni
CPU: Intel i7 8700T
GPU: AMD RX580
25 Jun 2019, 18:33
25 Jun 2019, 16:59
OK thanks you Mald0n.
Mrzhay
CPU: Intel Core i7-2670QM @ 2.2GHz
Motherboard: Intel PLCSF8 (U3E1)
GPU: Intel HD Graphics 3000
26 Jun 2019, 00:11
Hello sir Maldon I successfully installed the Catalina and follow your guide please help patch my DSDT file I already attach it below and please tell what else should I do to make smooth thank you so much sir..!!
trance4
CPU: I5-6500
Motherboard: Hp 600 G2
GPU: Intel 530
26 Jun 2019, 11:41
hi I installed on my Lenovo Thinkcentre M73Z everything is works but sound and Bluetooth dosent work.
sometime I reboot the computer and the bluetooth works and after a reboot again the bluetooth dosent work.
please help me' my audio card is ALC 10ec0269.
thanks in advance
26 Jun 2019, 13:07
trance4, u need check what bt u have for check solution
Return to “DSDT”
