DSDT patch requests
rodrigo.bar1995
Donator
Donator
CPU: Intel® Core i3-4150 CPU @ 3.50
Motherboard: ASUS H81M-C-BR
GPU: AMD Radeon HD 6670 2GB DDR3
DSDT patch requests
Post by rodrigo.bar1995 » 23 Jun 2019, 16:48
Hello, I have a Canon T5 when I connect via USB on hackintosh or connect the memory card does not connect on mac.
What else do I need to do to get my hackintosh to 100% or almost.
CPU: Intel® Core i3-4150 CPU @ 3.50GHz
Motherboard: H81M-C-BR
Storage: SSD KINGSTON SUV400S37240G
Audio: Realtek ALC887
DSDT patch requests
Post by MaLd0n » 23 Jun 2019, 22:59
pauliebb,
Added in 3 minutes 48 seconds:
areg_noid,
check if work
Added in 47 seconds:
ariegrinder, extract new send_me
reym, extract new send_me
Added in 38 seconds:
news104, use hackintool
Added in 3 minutes 59 seconds:
rankawarj, i edit ur file, dsdt is same for all system, extras check useful links in my sig
Added in 1 minute 10 seconds:
rodrigo.bar1995, use o aplicativo "captura de imagem"
-Donated? Send me one PM-
ariegrinder
CPU: Intel Core i5 7200u 2.5Ghz
Motherboard: Asus A456UR
GPU: Intel HD 620
DSDT patch requests
Post by ariegrinder » 23 Jun 2019, 23:52
23 Jun 2019, 23:11
pauliebb, DSDT.aml.zip
areg_noid, DSDT.aml.zip
check if work
this is the file, thanks
B-Souza
CPU: i7 9700k
Motherboard: Gigabyte z390 Aorus Pro
GPU: Gigabyte RX 580
DSDT patch requests
Post by B-Souza » 23 Jun 2019, 23:58
My sleep is just asleep to the monitor. PC still ON
Can you help me?
DSDT patch requests
Post by MaLd0n » 24 Jun 2019, 00:58
ariegrinder, u need disable _DSM to XDSM
Added in 1 minute 47 seconds:
B-Souza,
ariegrinder
GPU: Intel HD 620
DSDT patch requests
Post by ariegrinder » 24 Jun 2019, 01:37
24 Jun 2019, 01:00
B-Souza, DSDT.aml.zip
I try, and it was a success.
but my Internal Microphone doesn't work.
but if _DSM to XDSM enabled, the microphone works.
is there something wrong with my CodecCommander SSDT?
location in SSDT-HDEF.aml
DSDT patch requests
Post by MaLd0n » 24 Jun 2019, 01:40
ariegrinder, don't use it, just inject via clover, check useful links in my sig
B-Souza
CPU: i7 9700k
DSDT patch requests
Post by B-Souza » 24 Jun 2019, 01:52
[/quote]
Ainda sem sucesso, o pc não está entrando em repouso, apenas o monitor :(
Estou enviando um novo SENDME... se puder ajudar
DSDT patch requests
Post by MaLd0n » 24 Jun 2019, 01:56
B-Souza, use o sleep no menu apple
ariegrinder
GPU: Intel HD 620
DSDT patch requests
Post by ariegrinder » 24 Jun 2019, 01:59
24 Jun 2019, 01:40
edited..
after I checked the SSDT Codec Commander, it turned out that there was a duplicate patch, after I deleted it, the mic returned to work.
thank MaLd0n for your help ...
if you wish, can you help me solve the problem Volume control FN + F10 to F12 doesn't work?
thanks.
B-Souza
CPU: i7 9700k
DSDT patch requests
Post by B-Souza » 24 Jun 2019, 02:00
24 Jun 2019, 01:56
Mas é justamente oq eu estou fazendo hehe, eu clico no sleep, e aí o monitor entra em repouso, mas a máquina continua toda ligada e acesa aqui kkk, daí eu aperto qualquer tecla e me aparece a tela de colocar a senha novamente.
DSDT patch requests
Post by MaLd0n » 24 Jun 2019, 02:04
B-Souza, tem cooler com cabo usb ou combo bt+wifi tb com cabo?
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
DSDT patch requests
Post by juanvascas » 24 Jun 2019, 06:22
I have all the ACPI patches for the USB port limit on Mojave and also this external icons patch:
<key>Comment</key>
<string>External Icons Patch</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
RXh0ZXJuYWw=
</data>
<key>InfoPlistPatch</key>
<false/>
<key>Name</key>
<string>AppleAHCIPort</string>
<key>Replace</key>
<data>
SW50ZXJuYWw=
</data>
However my external devices still show as internal, do I need something else?
areg_noid
CPU: Intel(R) Core(TM) i5-7200U CPU
Motherboard: HP 81A9
GPU: Intel 620
DSDT patch requests
Post by areg_noid » 24 Jun 2019, 16:42
23 Jun 2019, 23:11
check if work
Thanks before, but it still not work, is there another solution?
I attach send_me again
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
DSDT patch requests
Post by juanvascas » 24 Jun 2019, 16:58
Hi I am using Mojave and I can boot (with only hot patches) with most things working, I read in a post from MaLd0n abouth the benefits of a proper DSDT patched. I would like to have one if possible.
Thanks!
FedeBad95
CPU: i7 8700k
Motherboard: Z370 Taichi
GPU: GTX 1080
DSDT patch requests
Post by FedeBad95 » 24 Jun 2019, 17:25
hi MaLd0n, i re-updated my bios version can you repatch my dsdt? thanks again
Bowlokus
CPU: I7 8850H
Motherboard: Aorus
GPU: GTX 1080
DSDT patch requests
Post by Bowlokus » 24 Jun 2019, 17:42
Estou com um problema a respeito do brilho da tela no meu hackintosh em um notebook aorus x7 v8.. placa de video 1080 gtx. parece que o sistema nao reconhece como tela de notebook mas sim de um monitor convencional. segue em anexo o print do config do mac.
Todo o restante esta funcionando 100%.
Aorus X7 V8
i7 8850H
64 DDR4
3x 1TB NvMe m2 970 EVO
1x 1TB SSD 860 EVO
GTX 1080
MAX998
CPU: intel i 5 3,2
Motherboard: ASROCK Fatal1ty H87 Performanc
GPU: radeon rx570
DSDT patch requests
Post by MAX998 » 24 Jun 2019, 17:50
Hello can you help me ?
i don't have noise,
thanks
bisk8s
CPU: Intel(R) Core(TM) i7-3537U
Motherboard: Aspire V5-471
GPU: Intel(R) HD Graphics 4000
DSDT patch requests
Post by bisk8s » 24 Jun 2019, 18:34
14 Jun 2019, 18:40
Caramba, a minha também não funcionava por nada, quando usei o que descrevi, funcionou na hora ( A minha é a AR9485...
Segundo o RehabMan, a sua não é suportada.
Mas, acho que vale a pena lr esse post: [External Link Removed for Guests] na seção: Q. WiFi/bluetooth is not working. How to fix?
Added in 9 minutes 6 seconds:
bisk8s, achei este link onde o cara obteve sucesso.
Added in 58 minutes 43 seconds:
MaLd0n, abandonei o Dell por enquanto.
Estou com este outro Hack: IPMH81G1, I5 4440, 16GB (8 X 2), INTEL HD GRAPHICS 4600, SSD 360 Gb.
Até onde testei, funciona tudo nele, inclusive a hibernação. Mas como não sei se precisa da DSDT, fiz o send me.
Agradeço a ajuda.
Perfeito! O esquema do ultimo vídeo funcionou!
Só não consegui ainda fazer o audio sair pelo HDMI.
Segue imagem do hackingtool.
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
DSDT patch requests
Post by yamvmax » 24 Jun 2019, 18:43
Hoping for FN keys, and Especially keyboard backlight working on my asus tp412ua. Would greatly appreciate it!!
WHY AM I getting file too large??? I ran runme.
ASUS VivoBook Flip 14 TP412UA-IH31T
Return to “DSDT”
