DSDT patch requests
Siberia
CPU: 8700-k
Motherboard: h370 f-gaming
GPU: 1080ti
DSDT patch requests
Post by Siberia » 27 May 2019, 08:36
27 May 2019, 02:28
Nvidia don't work in Mojave, back to high sierra
Glitch with remote turn to sleep not with video card. I use high sierra.
kubade220
CPU: i5 8250U
Motherboard: hp pavilion 15
GPU: intel uhd 620
DSDT patch requests
Post by kubade220 » 27 May 2019, 08:36
27 May 2019, 01:11
macrobert612, DSDT.aml.zip
check hackintool tutorial for video patch
Added in 3 minutes 33 seconds:
Fanfarrao, DSDT.aml.zip
Added in 1 minute 17 seconds:
kubade220, [External Link Removed for Guests]
Added in 57 seconds:
chohsiao, is a olarila clover folder for serie 300 with full dsdt patch
Added in 54 seconds:
janjao, dsdt is same, just use olarila clover folder
Added in 4 minutes 8 seconds:
cuan, DSDT.aml.zip
audio u need inject via clover
Added in 3 minutes 53 seconds:
eyoung100, DSDT.aml.zip
ITS FULLY PERFECT WORK. Thank you so much ;)
rmdg88
CPU: i5 8400
Motherboard: Z370 Gigabyte Gaming 5
GPU: SAPPHIRE PULSE RX560
DSDT patch requests
Post by rmdg88 » 27 May 2019, 10:36
hi, could you have a look on this picture?
my iMac works fine, but since this 10.14.5 I have those purple lines during startup.
i have done a fresh install with the latest Mojave .img and it happens the same, it will be related to the DSDT?
Thanks!
jackfrost4u
CPU: 6th Gen Intel® Core i7-6700HQ
Motherboard: system 76
GPU: INTEL HD 530
DSDT patch requests
Post by jackfrost4u » 27 May 2019, 14:57
everything works now except cannot toggle bluetooth on/off. not a big deal. I am going to move on to my other laptop, kabby lake. here is the info. below if you have any suggestions.
what BT u have?
Vendor ID: 0x004C
Product ID: 0x2006
Composite Class Of Device: 0x38010C
ssprod
DSDT patch requests
Post by ssprod » 27 May 2019, 18:23
Greetings Maldon.. I seem to be on a mad experiment.. I picked up a Gigabyte BRIX GB-BS15A-6200 (i5 6200-HD520).. Used your appropriate notebook EFI and it worked with Mojave, however any fine tuning you can perform would be greatly appreciated. Thank you very much!
platinumsteel
CPU: i7 8700K
Motherboard: Gigabyte Z370 Gaming 5
GPU: GTX 1080
DSDT patch requests
Post by platinumsteel » 27 May 2019, 18:32
Hi Maldon hoping u can create this patch for me thanks in advance....Gigabyte Designare+i7 8700K+RX 580
Send-me-Freds-iMac.zip
eamonn
CPU: i7 6700
Motherboard: 7040
GPU: N/A
DSDT patch requests
Post by eamonn » 27 May 2019, 19:05
Hi,
This is my first post. I'm trying to generate a new config.plist for my first hackintosh and I'm quite lost. Could someone help me out please? I have a wifi/bluetooth card installed so airdrop, iMessage etc work fine. My fans won't work however, the graphics are a little off in places (glitching etc, using internal graphics) and I cant monitor my temps etc.
Any help would be greatly appreciated, thanks!
Dell Optiplex 7040
i7 6700
esata
CPU: Intel Core i7-6700 3.4GHz
Motherboard: H170-P/G20CB/DP_MB. (ASUSTeK
GPU: NVIDIA GTX 1070 8GB
DSDT patch requests
Post by esata » 27 May 2019, 19:15
Após subir o "send me" e receber um DSDT.aml, basta coloca-lo em "EFI em Clover/ACPI/Patched" ?
ASUS G20CB-B21 Gaming Desktop | H170-P/G20CB/DP_MB. | Intel Core i7-6700 3.4GHz | NVIDIA GTX 1070 8GB | (2x8GB) 16GB DDR4 SDRAM | Realtek ALC887 | Realtek 8821AE | BLUETOOTH: ? | SSD: 128GB KINGSTON SHFS37A120G | HDD: 1TB TOSHIBA DT01ACA100 | ADAPTER 180W 19.5V 3P(5.5PIH) / ADAPTER 230W 19.5V 3P(7.4PHI) | G20AJ CPU FAN ASSY / G20BM THE MOD ASSY
FredBloggs
CPU: Intel u-4200
Motherboard: Lenovo u430 touch
GPU: Intel
DSDT patch requests
Post by FredBloggs » 27 May 2019, 20:17
Thanks Man.
Trying to get DW1820A working
brunovinicius
CPU: i5 8600K
Motherboard: EVGA Z370 Classifield K
GPU: AMD Vega 64
DSDT patch requests
Post by brunovinicius » 27 May 2019, 21:23
rmdg88, I have the same issue.. only during startup
Fanfarrao
CPU: Core i3 6100
Motherboard: Asrock FAtal1ty H170 Performan
GPU: Gigabyte Gtx750 ti
DSDT patch requests
Post by Fanfarrao » 27 May 2019, 21:29
27 May 2019, 01:11
cuan, DSDT.aml.zip
Thank you so much, MaLd0n :frantics . :superman Good job bro :guitar
smoky-jr
CPU: Intel Xeon E5-2697 v4
Motherboard: ASRock Fatal1ty X99 Profession
GPU: Geforce GTX970 4GB
DSDT patch requests
Post by smoky-jr » 27 May 2019, 22:32
Hey,
Almost everything works, a video card is recognized and works.
Sleep mode works.
Audio works.
Only usb3.0 works, usb2.0 does not work, even though I did all the required patches.
Unknown processor message on "About this Mac".
Does not recognize bluetooth
Does not recognize the second network port
Does not recognize the wireless card
Does not recognize the nvme pci-e controller
Would appreciate help.
Thanks.
ASRock X99 Professional Gaming i7|18-Core Intel Xeon E5-2697 v4 2.3GHz |Gigabyte GeForce GTX 970 4GB|DDR4 16GB SDRAM|Realtek ALC1150|Intel Dual Giga Lan I211, I218-V|Intel Dual Band Wireless-AC3160|Intel Bluetooth 3160|Samsung SM951 PCIe SSD M.2|TOSHIBA THNSNJ512GDNU SSD M.2|HDD: 1TB Hitachi Ultrastar A7K1000|ASMedia ASM1142 USB 3.1 xHCI (Type-C)|Intel USB 3.0 xHCI|Intel USB 2.0 EHCI|Corsair 850w
CompHuh
CPU: ConanHuh
Motherboard: Hp
GPU: 85643499438
DSDT patch requests
Post by CompHuh » 27 May 2019, 23:43
Same here, was going crazy checking IPs/Ports/files over and over and nothing was working. So its something on AudioRealms end?
Why do requests go through them? Isnt there a way to not use them?
betoknoxx
CPU: i3-3227U
Motherboard: DELL
GPU: Intel HD4000
DSDT patch requests
Post by betoknoxx » 28 May 2019, 02:05
I'm sending my file. Thanks in advance.
Hackintoshnoob007
CPU: broadwell u, i3 5005u
Motherboard: hp 2336
GPU: intel hd 5500
DSDT patch requests
Post by Hackintoshnoob007 » 28 May 2019, 06:16
Have a good day. Thanks in advance for patching DSDT
platinumsteel
CPU: i7 8700K
GPU: GTX 1080
DSDT patch requests
Post by platinumsteel » 28 May 2019, 11:12
Hi Mal hoping I can get this other one done for a friend..HP envy x360 15-cn0300nd
Send-me-Mikes-MacBook-Pro.zip
hellonamer1
CPU: i5 8400
Motherboard: B360m Aorus Pro
GPU: GTX 1060
DSDT patch requests
Post by hellonamer1 » 28 May 2019, 13:08
Hi MaLd0n, very nice to meet you. My hackintosh work very well but sleep and HDMI audio doesn't work. Is this necessary to patch DSDT. I'm using desktop. Thanks a lot !! :frantics :frantics
RanoMac
CPU: I5-4210
Motherboard: HP
GPU: Nvidia 820
DSDT patch requests
Post by RanoMac » 28 May 2019, 14:45
Hello, I send my file.
Asus R752L (X751), CPU:i5 4200u and GC : GF840M FHD display
Not Work : Battery (zero), Only 1366x768, ...
AirPlay Wifi AR9565 very slow (~ 2 Mbit/s)
Thanks in advance.
dannyramdhani
CPU: i5 2340
Motherboard: Onda H67
GPU: GTX 670
DSDT patch requests
Post by dannyramdhani » 28 May 2019, 16:57
hello can you help me to fix my usb 3 port. its not working.
and I think the usb port sometimes wrong, its like no power on it.
My Spec:
i7 3770s
MSI ZH77a G43
GTX 670 PALIT
8gb Ram
Send me Dannys-iMac.zip
ovalf
CPU: i7 7900x
Motherboard: Asus x299 TUF 1
GPU: rx580
DSDT patch requests
Post by ovalf » 28 May 2019, 17:51
hello, change my hardware a little and upgraded to Mojave.
Send me FBPRO-2.zip
Send me FBPRO-2.zip
Thanks a lot
Return to “DSDT”
