DSDT patch requests
Fanfarrao
CPU: Core i3 6100
Motherboard: Asrock FAtal1ty H170 Performan
GPU: Gigabyte Gtx750 ti
DSDT patch requests
Post by Fanfarrao » 26 May 2019, 09:16
Hello good day. I followed all the steps in the guide, but I have a problem with my video card. Could someone help me, please? Here's my DSDT patch.
Send me iMac-de-Andy.zip
kubade220
CPU: i5 8250U
Motherboard: hp pavilion 15
GPU: intel uhd 620
DSDT patch requests
Post by kubade220 » 26 May 2019, 10:39
Hello. Can u fix my bluetooth (dell dw1560) because system does not see him.
chohsiao
CPU: intel i7-8086k
Motherboard: maximus x hero wifi
GPU: sapphire rx580 8g
DSDT patch requests
Post by chohsiao » 26 May 2019, 12:53
Hello mald0n, I bought some components like yours, mb is ga-z390 m gaming, cpu is 9900k, graphics is rx580 8g, wifi is bcm94360cd pci-e, could you send me the efi files running perfect, thanks very much!
janjao
CPU: i3 6100
Motherboard: gigabyte H110M
GPU: GT 710
DSDT patch requests
Post by janjao » 26 May 2019, 15:22
Hello Maldon, I reinstalled Mojave on my notebook Asus x510ur and for some reason the old DSDT is not booting. Can u please patch the fine tuning again?
cuan
CPU: Intel® Core™ i7-8700
Motherboard: ASRock® B360M Pro4
GPU: GIGABYTE Radeon RX570 GA 8G MI
DSDT patch requests
Post by cuan » 26 May 2019, 16:51
Hello Mardon, I created myself a clean vanilla Clover setting, everything works fine but the sound came from DisplayPort is crackling, it's not clear and sound like 32kbps music. Could you please fix it? I got AppleALC and CodecCommander installed, without CodecCommander, it still sounds like that.
PC Spec: i7 8700, RX 570, ASRock B360M Pro4.
Thank you a lot!
P/s: it also sounds crackling with onboard audio output
honedy
DSDT patch requests
Post by honedy » 26 May 2019, 17:41
23 May 2019, 13:39
Added in 9 minutes 12 seconds:
honedy, vc tem de usar a voodoi2c e tentar o touchpad/trackpad com ela, a não ser que a voodoops2 esteja perfeita no seu notebook
Consegui fazer funcionar o touchpad com a DSDT
Era só configuração da Bios do notebook
Na Bios em Main tem a opção do Touchpad
Foi só mudar de Advanced para Basic,salvar e reiniciar
Muito obrigado por tudo
Agora só tenho que fazer funcionar os gestos
moemengaber
CPU: i5 4750
Motherboard: HP 800 G1
GPU: NVIDIA GT 730 DDR5
DSDT patch requests
Post by moemengaber » 26 May 2019, 18:57
15 May 2019, 11:43
How did you get the GT 730 DDR5 to work? I have the same card, but with 1GB and so far I can not get it to load without nv_disabble = 1. Help me. Thank you!
Mald0n, do you now khow I can solve this!?
It's a kepler chipset which works OOB without any modifications from my side
kubade220
CPU: i5 8250U
GPU: intel uhd 620
DSDT patch requests
Post by kubade220 » 26 May 2019, 19:10
26 May 2019, 03:15
come back, miss you. Where are you ? :(
platinumsteel
CPU: i7 8700K
Motherboard: Gigabyte Z370 Gaming 5
GPU: GTX 1080
DSDT patch requests
Post by platinumsteel » 26 May 2019, 21:55
Hi again Maldon..In behalf of a good friend am kindly requesting getting a DSDT done for his system..His specs are Gigabyte Designare.I7 8700K + RX 580 . ...Somehow it's a little too large when i try to attach it tru here..So i sent a google drive link..thanks.
eyoung100
CPU: i7-770k
Motherboard: MSI Z270-A Pro
GPU: Nvidia 1050Ti
DSDT patch requests
Post by eyoung100 » 26 May 2019, 22:35
Finally had time to upgrade to Mojave. Here are my stats.
cazixpp
CPU: Xeon E5450
Motherboard: Asus P5K SE
GPU: GTX 1050 Ti
DSDT patch requests
Post by cazixpp » 26 May 2019, 22:45
Hi,
I need to get sleep and native audio (Realtek alc883 8-channel) and Ethernet (Attansic L1 Gigabit Ethernet), and eventually remove errors
for my asus P5K SE. I have a GTX 1050 Ti 4Gb DDR5 and intel xeon E5450
thank you for your help.
regok
CPU: i5 7500
Motherboard: MSI B250M Mortar Arctic
GPU: Asus GTX 1060 6GB
DSDT patch requests
Post by regok » 26 May 2019, 23:53
In my PCI don't detect intel HD 630 and other chipset and my nvme. On display i just see nvidia, my cpu graphic is work properly? and sometimes i got laggy, especially when opening adobe software, i don't know what is wrong. And Hardware Encoder,decoder,hecv, quick sync.
Thanks :) :) :)
DSDT patch requests
Post by MaLd0n » 27 May 2019, 00:56
macrobert612,
check hackintool tutorial for video patch
Added in 3 minutes 33 seconds:
Fanfarrao,
Added in 1 minute 17 seconds:
kubade220, [External Link Removed for Guests]
Added in 57 seconds:
chohsiao, is a olarila clover folder for serie 300 with full dsdt patch
Added in 54 seconds:
janjao, dsdt is same, just use olarila clover folder
Added in 4 minutes 8 seconds:
cuan,
audio u need inject via clover
Added in 3 minutes 53 seconds:
eyoung100,
:guitar[External Link Removed for Guests]:guitar
:guitar[Local Link Removed for Guests]:guitar
-Donated? Go to "User Control Panel/Usergroups" and request "Donator" for change group permission-
Siberia
CPU: 8700-k
Motherboard: h370 f-gaming
GPU: 1080ti
DSDT patch requests
Post by Siberia » 27 May 2019, 01:14
Thanks Maldon. I'll do donate. But the Glitch not gone. Same problem. Hackintosh won't goes to sleep remote. Work only from keyboard.
DSDT patch requests
Post by MaLd0n » 27 May 2019, 01:19
cazixpp,
audio, check useful links in my sig
lan, u need a kext
Added in 3 minutes 9 seconds:
regok, first u need a good config, check olarila clover folder
Added in 36 seconds:
Siberia, use iMac18,1 smbios to avoid glitches
Siberia
CPU: 8700-k
GPU: 1080ti
DSDT patch requests
Post by Siberia » 27 May 2019, 01:34
27 May 2019, 01:22
I changed smbios and got nothing.
The same problem.
DSDT patch requests
Post by MaLd0n » 27 May 2019, 02:28
Siberia, u use Mojave?
Nvidia don't work in Mojave, back to high sierra
regok
CPU: i5 7500
DSDT patch requests
Post by regok » 27 May 2019, 03:00
27 May 2019, 01:22
yes, i use config from olarila clover for mobo series 100,200,300. but I little bit change the config. Do I have to return to config for the series 100,200,300 before I change it and start the runme again?
saifulapm
CPU: Dell N4050
Motherboard: Intel
GPU: Intel HD 3000
DSDT patch requests
Post by saifulapm » 27 May 2019, 06:16
Hello Sir, I have attached send_me.zip. Please help me.
My Laptop Dell n4050 with SSD and 8gb Ram Intel HD 3000. After installation High Sierra, No Audio, No Wifi, No Bluetooth. When Boot from USB, Ethernet working but when boot from hard disk ethernet don't work.
Please help me.
brunovinicius
CPU: i5 8600K
Motherboard: EVGA Z370 Classifield K
GPU: AMD Vega 64
DSDT patch requests
Post by brunovinicius » 27 May 2019, 07:40
MaLd0n, eu atualizei para 10.14.5 usando a imagem aqui do site.. fiz uma instalação limpa e usei a pasta EFI que voce tinha feito o patch para mim na versão anterior, so que nessa ultima versão perdi o USB 3.0... Fiz o RunMe e coloquei aqui no google drive o arquivo, da uma olhadinha ai pra ver se ta tudo certinho, muito obrigado.
Return to “DSDT”
