DSDT patch requests
codeyoc
CPU: Intel Core i5-2400 3.1GHz
Motherboard: ASUS P8Z68-V LE
GPU: NVIDIA Quadro K2200 4GB
DSDT patch requests
Post by codeyoc » 16 May 2019, 12:00
Last DSDT patch I will need for a while. this will be my 3rd golden build once I install a new wifi card.
having trouble with battery percentage. mainly want to fix tap to click. voodoops2 not working 100% doesn't show preferences. two finger scroll is working. no sound but will prob use voodooHDA unless DSDT patch fixes audio.
the last last laptop I got a DSDT for was too old to run anything well. I gave it to a friend as a spare windows machine.
thanks for everything. really hoping tap to click and battery percentage will work on this HP ProBook 4230s.
thanks again. Olarila rules :guitar :smoke:
geirisk8
CPU: i9 9900k
Motherboard: Gigabyte Z370 Gaming K3
GPU: RX580
DSDT patch requests
Post by geirisk8 » 16 May 2019, 12:21
Hi guys, I've got a photo and video editing machine.
9900K (slight overclock)
Gigabyte Z370 AORUS Gaming K3
32GB RAM
Sapphire Radeon Vega64
I'm using Lightroom and Final Cut a lot so I want to make sure my computer is running at absolute peak performance where I utilise the iGPU and Vega64 together with quicksync. I work with h.265 files a lot too. I run one 32" 1440p monitor via the display port of the Vega64.
Attached is the "send me" file.
DSDT patch requests
Post by MaLd0n » 16 May 2019, 13:37
toxicsulfur, restart ur hack, press F4 key in clover boot screen, boot into system and run my app again, i need a original tables, u have a strange patches in ur config.plist
Added in 52 seconds:
bencarlos, dp work good?
Added in 6 minutes 8 seconds:
codeyoc, use previous dsdt and apply battery patch from rehabman repo
Added in 9 minutes 13 seconds:
geirisk8, replace full efi, reboot
EFI.zip
-Donated? Send me one PM-
intracom
CPU: 5600U
Motherboard: main thinkpad x1 gen 3
GPU: HD5500
DSDT patch requests
Post by intracom » 16 May 2019, 16:05
16 May 2019, 03:17
intracom, work for all
I tried inject ID 12 18 28 but it don't working :((((
DSDT patch requests
Post by MaLd0n » 16 May 2019, 17:51
intracom, iof dont work u need other way
Recrossmusic
CPU: Dell 15R 5537
Motherboard: intel
GPU: HD440 / AMD HD6780M
DSDT patch requests
Post by Recrossmusic » 17 May 2019, 01:59
Hi, Please I need the DSDT for my Dell 15R 5537 service number GH9RLZ1. I install 10.14.5 version.
Thanks advance!
DSDT patch requests
Post by MaLd0n » 17 May 2019, 02:59
Recrossmusic,
veja na minha assinatura Useful Links pra video, audio, etc
toxicsulfur
CPU: Intel i5 vPro 4300U
Motherboard: Lenovo 20A8S0NT00
GPU: Intel HD 4400
DSDT patch requests
Post by toxicsulfur » 17 May 2019, 03:00
@ MalD0n i cant upload file here, have to use Sendspace
Thank you.
jgil00
CPU: i3 330m
Motherboard: GPU
GPU: Intel hd 1st gen
DSDT patch requests
Post by jgil00 » 17 May 2019, 03:03
Hi , Done :)
DSDT patch requests
Post by MaLd0n » 17 May 2019, 03:21
toxicsulfur, replace full efi, reboot
check useful links i my sig
Added in 9 minutes 43 seconds:
jgil00,
alcanfane
DSDT patch requests
Post by alcanfane » 17 May 2019, 03:42
16 May 2019, 02:51
toxicsulfur, [Local Link Removed for Guests]
Added in 3 minutes 36 seconds:
alcanfane, DSDT.aml.zip
use Olarila Clover folder for ur chipset
put ur amd gpu in first slot
Put GPU in first slot and use Olarila Clover 300 and it stuck at Intel Lan error. Is it because I used multishit method at first installation ?
DSDT patch requests
Post by MaLd0n » 17 May 2019, 03:50
alcanfane, use a fresh install, never use multishit
waterloopan
CPU: 4770k
Motherboard: z87
GPU: rx570
DSDT patch requests
Post by waterloopan » 17 May 2019, 04:12
Hi, here is my file, thanks a lot for your help.
DSDT patch requests
Post by MaLd0n » 17 May 2019, 04:16
waterloopan,
toxicsulfur
GPU: Intel HD 4400
DSDT patch requests
Post by toxicsulfur » 17 May 2019, 04:40
Mald0n,,
Thank you USB and my wireless usb working fine, But now No Sound and Battery meter.
Apple ALC3232 not sure what is the inject id?
erickmabanto
CPU: Intel Core i7 4770k
Motherboard: Asus Sabertooth z87
GPU: Zotac GTX 1070ti
DSDT patch requests
Post by erickmabanto » 17 May 2019, 06:40
Mald this is the full dump of RunMe.app
papoun
CPU: I7-7700HQ
Motherboard: MSI
GPU: GTX1050TI
DSDT patch requests
Post by papoun » 17 May 2019, 11:01
Hello
All of abors congratulations for this beautiful Forum
I would love a can help to edit my DSDT (which my been patched by Maldone on another forum).
1-the backlight works but only after a cycle of sleep or suspend activity. On the other hand the problem is that the standby or the suspention of activity does not put my labtop in sleep, it restarts and does not turn off.
2-I'm not sure that my NVIDIA 1050TI GPU is properly desactivated. If we could check him out. I have a big hot spot between my keyboard and TrackPad.
3- For the graphic part acceleration, I still try to activate my output miniDP (possible with Hackintool and patch of the connector) but it makes me frozen of the system that I connect a screen on the mini DP... But I think it is related to the activation of the GPU, I will take this point later. 4-I seem to have a small problem with my internal USB port HS07 (MSI EPF USB) that lights up and turns off in a loop. This port allows me to manage the RGB illumination of the keyboard. Under high Sierra the operation was correct.
Thanks for your help, I attached the file SendMe.
DSDT patch requests
Post by MaLd0n » 17 May 2019, 13:21
toxicsulfur, check usefgul links in my sig, just inject audio and apply battery patch again
Added in 13 minutes 48 seconds:
erickmabanto,
Added in 5 minutes 25 seconds:
papoun, check if problem is nvram
trackpad, try a updated kext from here
Blacket
CPU: Intel Core i7 6700-HQ
Motherboard: ASUS UX501VW
GPU: Nvidia GTX960M
DSDT patch requests
Post by Blacket » 17 May 2019, 13:43
Hi.
My name is Mohammad, today I try to install osx High Sierra but I need the dsdt for my Asus Ux501VW.
Thank you very much :)
DSDT-SSDTs.zip
DSDT patch requests
Post by MaLd0n » 17 May 2019, 13:45
Blacket, run my app for a full dump
Return to “DSDT”
