DSDT patch requests
thanhman18
CPU: i7 6700
Motherboard: gigabyte h170 gaming ddr4
GPU: GTX 1070
DSDT patch requests
Post by thanhman18 »
MaLd0n, please patch dsdt thank you
jcamilopez9
CPU: 8550U
Motherboard: NN
GPU: Nvidia GTX 1050
DSDT patch requests
Post by jcamilopez9 »
Hi everyone
My pc is a Lenovo 330s, core i5 8250u with Nvidia GTX 1050.
I follow the guide "Install MacOS with Oralira Image ..." to install Catalina on my PC, combined with this guide
everything works fine but the discrete graphics card (GTX 1050) is ON all the time making a battery drain, the battery on windows or linux lasts 8 hours but in Hackintosh Catalina lasts 1.5 hours.
I would appreciate your help.
My runme file:
Vohuu
CPU: I5 4210
Motherboard: Asus
GPU: Intel hd 4400
DSDT patch requests
Post by Vohuu »
Please help me. ASUS p550L
disctopf
CPU: Intel i5 750
Motherboard: GA-P55-UD3L
GPU: Nvidia GT730
DSDT patch requests
Post by disctopf »
please help me fix random freeze, thank you
PauloDapper
CPU: Intel Core 2 Duo E7500 2,93GHz
Motherboard: Phitronics P7I45GC-M+
GPU: ATI Radeon HD 4650
DSDT patch requests
Post by PauloDapper »
Hey guys, can you help me patch my Dell Inspiron 5558 15" (i7 5500u, Intel HD5500, GeForce 920M, SSD Sandisk 128GB, 8GB RAM, Ethernet Realtek FE, Wifi Dell 1707, audio codec Realtek ALC255)
Thanks! =)
flashad
CPU: i7 9700k
Motherboard: Gigabyte z390 Auros pro wi-fi
GPU: sapphire RX580 8gb
DSDT patch requests
Post by flashad »
i usimg a gigabyte z390 auros pro wifi and a core i7 9000 and a sapphire rx 580 8gb
Mortalitasi
CPU: INTEL CORE I5-8600K
Motherboard: GIGABYTE Z390 AORUS PRO
GPU: Intel UHD Graphics 630
DSDT patch requests
Post by Mortalitasi »
Hey !
Please help me to revive this old pc :)
Thanks in advance
duduiki
CPU: i7 5550u
Motherboard: Dell
GPU: HD5500
DSDT patch requests
Post by duduiki »
Olá Maldon, poderia fazer um Patch DSDT pra mim ?
-bateria não mostra
- hdmi não funiona (o notebook não possui placa de video externa)
Só falta isso.
Prometo fazer uma doação.
hermy-o
CPU: Asus x556UQ
Motherboard: Corel i5
GPU: 8GB RAM y 1TB
DSDT patch requests
Post by hermy-o »
18 Oct 2019, 13:31
Hi, Maldon. I need your help.
My laptop is Asus A556UQ, my specification are intel i5 7th gen, graphics : Intel HD Graphics 620.
I have problem with battery info, audio, touchpad, wifi, brightness setting.
Hi Greg
I have the same laptop as you, I would like to know if you could do Hackintosh and if so help me in the BIOS setup and also how I can disable the integrated to only work with HD Graphics 62
Thank you before, Gbu.
voytche
CPU: E8400
Motherboard: asus p5q pro
GPU: radeon hd6870
DSDT patch requests
Post by voytche »
Hi,
My pc is Asus p5q pro, Sapphire 6870, cpu e8400
Need dsdt, (sleep, ethernet builtin, hdmi audio, cpu speedstep...)
ahmedazab
CPU: Intel® Core™i7-7500U
Motherboard: Dell inspiron 5567
GPU: AMD Radeon™ R7 M445
DSDT patch requests
Post by ahmedazab »
Hello,
Here's my output from RunMe
Please tell me about the kexts I need to make it work :)
rock08
CPU: Intel i3
Motherboard: MSI CX640 Notebook
GPU: Intel HD3000
DSDT patch requests
Post by rock08 »
hi MSI cx640 i3 sandy bridge intel hm65 chipset
no wifi and bluetooth lan port audio and usb 3.0
flashad
CPU: i7 9700k
DSDT patch requests
Post by flashad »
hello when i try to atach the file send me it said that is to big. the file was about 3,7 mb
Added in 1 minute 14 seconds:
colorzpe
CPU: i5 8400
Motherboard: B365M Phantom Gaming
GPU: GTX 1070
DSDT patch requests
Post by colorzpe »
Thanks for help :D
masariuman
CPU: Intel® Core™ i5 6200U Processo
Motherboard: Asus A456UF
GPU: Intel HD Graphic 520
DSDT patch requests
Post by masariuman »
02 Dec 2019, 14:50
Does your Bluetooth technology work successfully ??? If it works, can you raise the method or tools ?? Thank you
my bluetooth on but not work, cannot get nearby active bluetooth device... sorry
masariuman
DSDT patch requests
02 Dec 2019, 14:50
vaha
CPU: i7
Motherboard: asus
GPU: amd r7
DSDT patch requests
Post by vaha »
Hello Catalina on Dell optiplex 5050 with Geforce ti 1050
Audio don't working
adriteam
Donator
Donator
CPU: Intel i7-5820K 3.3Ghz
Motherboard: ASUS X99-A II
GPU: Gigabyte AMD Radeon RX 580 8GB
DSDT patch requests
Post by adriteam »
Hello again MaLd0n. These are my runme results for a DSDT request.
It is an Acer E5-573g laptop, Intel Core Intel i5-5200U, Intel Broadwell-U PCH-LP motherboard and Intel HD 5500 with Nvidia Geforce GT940M (to disable please). Thank you
Edit: When i try to atach the file send me it said that is to big. the file was about 3,7 mb.
Im upload to TinyUpload.
Lordalex
Donator
Donator
CPU: I5 6200U
Motherboard: Asus UX303UB
GPU: Geforce 940M
DSDT patch requests
Post by Lordalex »
Hello, can you help me with my Notebook:
FN/ F buttons are not working, keyboard background / touchpad also not like it should be. (Normal movement ist working)
Asus UX303UB
CPU: I5 6200U
IGPU: Intel HD 520
GPU: Nvidia 940M
Ram: 8GB
Installed newest bios and used (CLOVER.NOTEBOOKS.100.200.300) file.
Here is my output from runme.app
Donation is made :)
OlgunB
Donator
Donator
CPU: I7 5500U
Motherboard: Toshiba P50-C-11V
GPU: Intel hd5500U / Nvdia gtx950m
DSDT patch requests
Post by OlgunB »
I Have send to from paypal :)
Return to “DSDT”
