DSDT patch requests
ruben
CPU: 8700k
Motherboard: GIGABYTE Z370 AORUS GAMING 7
GPU: RX 580
DSDT patch requests
Post by ruben »
Hi guys..Can I get some help with my dsdt ..will very much appreciate it thanks
Intel i7 8700k
Gigabyte Z370 Gaming 7
RX 580 4gb on the Way.
Send me Ruben-iMac.zip
kia
CPU: i5
Motherboard: gigabytes z170-d3h
GPU: Intel HD Graphics 530
DSDT patch requests
Post by kia »
Hi, MaLd0n.
Can you help to patch the DSDT, I have problems when enter in sleep mode.
thanks
mariolanestaley
CPU: Intel Core i3 8350K
Motherboard: Gigabyte Z390 M
GPU: Radeon Sapphire Nitro+ 580 8GB
DSDT patch requests
Post by mariolanestaley »
Hallo Mald0n, need your help edit dsdt on Z390 UD + Sapphire Nitro+ RX 580 8gb running Catalina. I already follow your step to install macOS Catalina, but PCI system information not showing any information (sleep, shutdown, restart etc not working) Thank you!
file send_me (run app) :
hannsmawardi
CPU: i5-7200U
Motherboard: X456URK
GPU: GeForce 930MX
DSDT patch requests
Post by hannsmawardi »
Help me please..here is my file generated from RunMe app.. Thanks! :help
>> [External Link Removed for Guests]
:help :help :help :help :help
m0ustafamahm0ud
CPU: i7 8565U
Motherboard: Lenovo
GPU: MX230 / UHD 620
DSDT patch requests
Post by m0ustafamahm0ud »
hi sir i want urgent help for my laptop
ideapad L340-15IWL
** battery life only 2 hrs
** trackpad does not work
please help sir !!
i7 8565U
UHD620
my files :
kick81
CPU: 9900K
Motherboard: ASUS ROG STRIX 390-F
GPU: Sapphire nitro+ 5700XT
DSDT patch requests
Post by kick81 »
Hi Mald0n,
I´ve changed my pc, could you please send me new DSDT?
Thanks!!
tuncas
CPU: Intel i9 9750H
Motherboard: HM370 chipset
GPU: Intel UHD 630
DSDT patch requests
Post by tuncas »
Mojave 10.14.6 msi ge75 notebook shutdown/restart/sleep problems.
Hi people,
This is a 3 days old notebook; MSI GE75 9SF,
after installing W10 to internal WDC ssd nvme (r:1600 mb, w:1200 mb),
i tried to install Mojave on external usb sandisk ext pro 3.1. (r:350 mb, w:250 mb)
i cannot open below cover theres warranty sticker!
Technical specs:
17" notebook MSI GE75 Raider 9SF
cpu: i7-9750H, 6 core, 12 mb cache
gpu: Intel UHD 630 internal, + nvidia rtx2070 (no luck for hackintosh :p )
chipset: HM370
hdd slots: 2 M.1, 1 sata
lan: Atheros killer e2500
wifi: intel killer e1550 (no luck for hackintosh)
sd card reader: RealTek RTS5129 USB Card Reader
audio: realtek 1220
hdmi 2.0, dp 1.2, usb c type outs, 4K out
2 port usb 3.2 gen1, 2 port usb 3.2 gen2
I could booted and installed from Olaria Mojave 10.14.1 and then updated to 10.14.6
cpu id detected, its cores and voltages + temperatures.
UHD 630 is detected out of the box.
battery detected.
lan is succesfull with "AtherosE2200Ethernet.kext"
no luck with bt and killer 1550 wifi (so im using an usb bt and wifi no problem)
in future i plan to buy BCM94352HMB...
Questions:
1- Please can i have DSDT/SSDT aml s, so shutdown and rebbot problems may be fixed? required files attached.
2- even sleep problems, too?
3- it naturally detected sound ALC1220 but theres no microphone...
what do you suggest; AppleHDA patcher or voodoo for ALC1220 sound + microphone ?
4- theres no hdmı or dp or usb c video outs, because the real nvidia card takes responsibility there, is there no hope?
5- If i buy BCM94352HMB, is it best option for wifi and bluetooth? (i was using them in my other notebooks for long time, since 10.10 s...)
6- Realtek usb2 sdcard reader :0bda 0129 ; couldnt get it work, is there a kext?
7- what about the steelseries illuminated keyboard? they have software in their web page for mac, but my notebooks integrated kb is not detected?
only sound inc/dec works, other kb fn key dont operate. so screen is at max brightness :p
8- my last question; its detected; MacBookPro14,3
should i change to 15,1 as it much suits that 9th gen. notebook? 2019 year produced and i9 cpu.
My Best Regards.
its 4.5 mb so attaching files says file too large...
ipcray
DSDT patch requests
Post by ipcray »
Hello Mald0n and thanks for your work over the years!
Always been a lurker but I just cannot figure out the battery and lid function on this M11XR1 DSDT. To be clear, with just Clover Patching (included patched clover DSDT also) everything works except battery and laptop lid.
Im attaching origin folder including the oem and clover patched DSDTs and other tables.
Thanks for any help you can provide, I will donate for fully working/patched DSDT/SSDTs (if needed)!
OF NOTE: This DSDT uses Nvidia discrete setting in bios and clover. Intel should be disabled. I will also boot Mojave on this machine and intel (switchable) in bios must be used. If I need to change the setting and send all that to you for same patching I will do so.
If you end up fixing 2 versions, ill up my donate. Thanks again!
P1aton0FF
CPU: Xeon 2697v2
Motherboard: Huanan X79-ZD3
GPU: Sapphire RX590
DSDT patch requests
Post by P1aton0FF »
02 Dec 2019, 13:54
try turn off SATA hotplug
This is Pci-e SSD's. Whatever hotplug - is disabled
luannt
CPU: Intel i7-7700HQ
Motherboard: HM175
GPU: Nvidia 1050Ti
DSDT patch requests
Post by luannt »
Hi, MaLd0n.
Can you help to patch the DSDT, It took me several days to fix it, but there were still many unresolved issues, so I reinstalled it from the beginning. thanks for help
elitelog
CPU: Intel
Motherboard: Intel
GPU: Intel HD 4400
DSDT patch requests
Post by elitelog »
Not working: Sleep, shutdown, brightness slider, wifi and sound. Thanks!
juncastro65
CPU: Intel core i7 skylake
Motherboard: Gigabyte GA Z170N Wifi
GPU: Gigabyte RX 570 Gaming
DSDT patch requests
Post by juncastro65 »
I have a Mojave Laptop ACER swift 3 SF314 56G hackintosh. I can say its working stable including Wifi card using DW1820A with pin masking.. Only the brightness control and HDMI output is not working.. Can you help me.. Here are the Hackintools settings I have.
boungeud
CPU: i5 8400 Coffee Lake
Motherboard: GA Z390 Designare
GPU: AMD RX580 8GB
DSDT patch requests
Post by boungeud »
Dear, MaLd0n, Thanks for the good work
Can you help to patch my DSDT?
Here is the send me file
Some additional infos about my build
Motherboard, it's a Gigabyte Z390 Designare
CPU Intel Core i5 8400
Radeon RX580 8GB
Thanks again for your time.
mviana2k
CPU: i7-8700
Motherboard: MSI Z370 PC PRO
GPU: Radeon RX 570 8 GB
DSDT patch requests
Post by mviana2k »
05 Nov 2019, 20:36
Olá, mudei o arquivo pois o computador estava muito instável, então fiz o limpa geral. Obrigado pelo trabalho.
Olá, sem querer abusar mas acho que passou batido aqui.
marcinkk
CPU: Intel
Motherboard: acer
GPU: intel
DSDT patch requests
Post by marcinkk »
Pls patch dsdt file [External Link Removed for Guests]
onthewall
CPU: i5-7600k
Motherboard: ASRock Z270 Extreme4
GPU: RX5700
DSDT patch requests
Post by onthewall »
Greetings Maldon!
Can you help with my setup? I have attached the zip file here.
Everything works well, but the CPU power management I think needs to be adjusted.
And if you see any other tweaks that need to be done.
1st Hackintosh... i7-5775c, ASRock Z97 Extreme6
2nd Hackintosh... i5-7600k, ASRock Z270 Extreme4, RX5700
osvaldoms
CPU: i3-330M
Motherboard: Pegatron IMPIP-M5 S989
GPU: Nvidia GT-230M
DSDT patch requests
Post by osvaldoms »
Estou testando o High Sierra em um note com processador i5-2410M, e placa mãe 7 Series. Levei um pau para conseguir instalar, mas depois de instalado recebo vários erros no modo verbos. O brilho não funciona direito e a bateria não mostra status. Segue o arquivo gerado pelo Runme.
Send me MacBook-Pro-de-Teste.zip
Fajah
CPU: i7-3537U / Ivy Bridge (Chipset
Motherboard: Intel HM76 (Southbridge)
GPU: HD4000 1366x768
DSDT patch requests
Post by Fajah »
Greetings from Italy MaLd0n
I followed the step by step guide and used Mojave 10.16,6 & NOTEBOOKS CHIPSET SERIES folder for my Ivy Bridge
Spech:
Asus (K56CB Family) S56CB-XX173H / i7-3537U / Ivy Bridge (Chipset) / Intel HM76 (Southbridge) / HD4000 1366x768 / NVIDIA GT740M
I ask politely the DSDT and this is my runmee folder: [External Link Removed for Guests]
Ps.just two questions,
- from the file what do you notice that is already working correctly?
- How can I understand if management and other things are working properly?
surely from what I seem to notice don't work: audio, power management, battery indicator, one USB 2.0(there are three ports one 3.0 and two 2.0), (..)
I wait your response, thank you
Best regards
Raffaele
Utrabook:
mero1212
CPU: intel
Motherboard: asus
GPU: intel
DSDT patch requests
Post by mero1212 »
@mald0n Will my Mojave dsdt work in catalina? Or should I send you new “send” from Catalina?
d2999381
CPU: i7-4510u
Motherboard: -
GPU: HD4400
DSDT patch requests
Post by d2999381 »
Hello, this is my send_me file. Thank you!
Return to “DSDT”
