DSDT patch requests
anusan
CPU: i3-4130
Motherboard: h81m-c
GPU: gtx 960 4095 mb
DSDT patch requests
Post by anusan » 20 Oct 2019, 02:17
Hi sir. Nvidia. Have more problem.
This is my file.
Solution plz
Arsenicson
CPU: i9 9900K
Motherboard: Aorus z390 Ultra
GPU: rx570
DSDT patch requests
Post by Arsenicson » 20 Oct 2019, 03:29
Please help with normal shutdown and sound volume control (not using Voodoo, just a standard EFI folder content from here [Local Link Removed for Guests])
saruwatari_saru1
CPU: itel
Motherboard: GIGABYTE
GPU: Nvidia
DSDT patch requests
Post by saruwatari_saru1 » 20 Oct 2019, 03:52
19 Oct 2019, 16:00
zenitheous, DSDT.aml.zip
Use Olarila Clover folder for your Chipset serie 300
enable ec0 to ec patch in ur config.plist
Added in 3 minutes 28 seconds:
arul7, Arquivo Comprimido.zip
Added in 2 minutes 59 seconds:
HeroBC, usb non-intel if don't work native, u need a extra kext
arif, Arquivo Comprimido.zip
update applealc and weg kext to last version, compile it
Added in 3 minutes 37 seconds:
saruwatari_saru1, extract full dump
OSX.Nobody, DSDT.aml.zip
Added in 1 minute 25 seconds:
eslam2500, [Local Link Removed for Guests]
This new file. Please patch o2 card reader for mac os catalina. Thank you so much.
RoyalFluzh
CPU: Intel Core i3 - 3240
Motherboard: H61H2-M13 v1.0
GPU: ZOTAC GTX 650
DSDT patch requests
Post by RoyalFluzh » 20 Oct 2019, 04:31
Hello,
I need help for my working,
I got too many error in boot log and in PCI (SysPref)
Send me MacBook-Pro.zip
my system is detected Atheros 9485 Wireless driver but I didn't have one
DELL E5440 | i5 4310U | INTEL HD4400 - NVIDIA GT 720M | 4 GB RAM
arul7
CPU: intel i5 3570k 3.40ghz
Motherboard: DH77EB
GPU: NVDIA Geforce 9400GT
DSDT patch requests
Post by arul7 » 20 Oct 2019, 05:10
20 Oct 2019, 03:52
i already download with your given nvdia update command but still not working ... and Audio is also not working please kindly rectify this problem
thanking you so much
greg_99
CPU: intel i5 7th gen
Motherboard: Asus
GPU: Nvidia gt940mx
DSDT patch requests
Post by greg_99 » 20 Oct 2019, 05:38
Hi Mald0n! Thankyou soo much for your DSDT! it's work.
But I have problem with my trackpad. My trackpad is working, can move the pointer, but if I move the pointer with trackpad, the pointer can't stop moving before I click the trackpad. I need you help for this problem.
Thankyou.
onemanosx
DSDT patch requests
Post by onemanosx » 20 Oct 2019, 05:43
20 Oct 2019, 05:38
Extract new sendme files.
MSI B360 Gaming Arctic
bunty_sam
CPU: i5 6th Gen
Motherboard: Gigabyte
GPU: AMD
DSDT patch requests
Post by bunty_sam » 20 Oct 2019, 06:07
Do I need new DSDT file for catalina?? Because while using the older one mac os is stuck on boot screen.
onemanosx
DSDT patch requests
Post by onemanosx » 20 Oct 2019, 06:10
20 Oct 2019, 06:07
Enable EC0 to EC patch in Clover
TheFahmi
CPU: Intel i7 9750H
Motherboard: HP Omen 15 DC1090TX
GPU: GTX 1650
DSDT patch requests
Post by TheFahmi » 20 Oct 2019, 07:46
hello sir,
I have done with : Accel GPU, Brightness control also sound.
but now camera and 1 USB port not working
kindly help to patch my dsdt or tutorial for it
Regards,
Fahmi
onemanosx
DSDT patch requests
Post by onemanosx » 20 Oct 2019, 07:52
20 Oct 2019, 07:46
Check your SSDT - UIAC to enable your missing USB port and camera.
TheFahmi
CPU: Intel i7 9750H
GPU: GTX 1650
DSDT patch requests
Post by TheFahmi » 20 Oct 2019, 07:58
onemanosx, so I must delete it? I have that file
EDITED: works, just delete SSDT-UIAC.AML
arul7
Motherboard: DH77EB
DSDT patch requests
Post by arul7 » 20 Oct 2019, 08:00
HellO Olarila,
Graphic drivers are not working once it is shutdown,
Audio is also not working,
Kindly rectify the problem
Thanking you
GIgabyte Z390 AOQRUS PRO Wifi
intel I7 8700
Zotac Geforce GT 1030 2 Gb
onemanosx
DSDT patch requests
Post by onemanosx » 20 Oct 2019, 08:04
20 Oct 2019, 07:58
If you remove it, make sure you have the USB port limit patch.
Read the section: USB Solution. [Local Link Removed for Guests]
gabyta92
CPU: intel core 2duo
Motherboard: g31-es2c
GPU: ati 5450
DSDT patch requests
Post by gabyta92 » 20 Oct 2019, 09:17
Attached is my send_me.zip from my laptop...
Can u help me with native audio,trackpad no working and problems with sleep
OSXcatalina 10.15
dell latitude e5440
4gb ddr3
intel hd 4400
nvidia 720
jzaxjzax
CPU: intel Core i5-9600K
Motherboard: Asus Prime H370M-Plus
GPU: Sapphire Pulse RX580 4GB
DSDT patch requests
Post by jzaxjzax » 20 Oct 2019, 10:39
Hi Mald0n,
Need help to patch this build. And there are some questions.
This build can’t connect second monitor. There are 4 ports but only first DP port,
black screen upon using other. BUT system can detect the second monitor. On mojave and High sirra have different incidences Please see some picture attached here. Would like to know if it is been patched to work? And about Audio device, this build has no on-board audio , in case if i have a PCIe sound card like Creative Sound Blaster X-Fi Titanium SB0880 .Can I use it on macOS? Can I use driver installer from the website without problems?
Intel(R) Xeon(R) CPU X5675 @ 3.07GHz
MB : Asus Z8na-D6
Ram 32gb
GPU Vega 56 8gb
Send me MacOSs-Mac-Pro.zip
ref pics.zip
Added in 14 minutes 52 seconds:
17 Oct 2019, 14:38
jzaxjzax,
(53 KiB) Downloaded 1 time
is a common problem with asus mobo, check ERP option in bios/uefi
I tried setting both ErP S4 / ErP S5 and ErP S4/S5 on my asus M/B. The result had nothing changed at all.
The m/b led and fans are still on while monitor completely sleep . This mean it's just a common problem
which no any way to fix at all, right? If yes ,I would not try to find a way to fix anymore LOL. Coz This is
the only problem left on my hack. If I could fix it, this will be a perfect mac for me. but it's ok if no fix.
:guitar
intel Core i5-9600K 3.7GHz
M/B Asus Prime H370M-plus
Ram 2666 32gb Corsair
GPU Saphire Pulse RX580 4GB ( Also 560 570 all working too)
M.2 SSD WD black 250GB
SATA SSD GLOWAY 480 GB
HDD Seagate Barracuda 2TB
Wireless BCM943602CS PCIe X1
vickey_1985
CPU: intel core i5-7500
Motherboard: gigabyte z270-HD3
GPU: Asus gtx1050 2GB
DSDT patch requests
Post by vickey_1985 » 20 Oct 2019, 11:18
PayPal is not in my Country. How do I pay for patched dsdt ?
george543
CPU: Q6600
Motherboard: Asus P5q-Pro
GPU: Nvidia gv-N210
DSDT patch requests
Post by george543 » 20 Oct 2019, 12:58
21 Sep 2019, 03:56
Quite some time ago I used mmid install etc. then one of your DSDT.aml for my Gigabyte X58-UD3R (V2.0 FH Bios)
I also ran a "CustomBeast-GDMorry" :P
Now the time has come to try upgrade the system and I was assuming a new DSDT would be in order.
I have uploaded it with this comment. Thanks again.
Hey there,
I don't have anything in my signature re what I am running as atm I am trying to get the same board up and running
Gigabyte X58A-udr3 v2.0 has FH bios
I keep going around in circles, have tried the clover folder from here as in this site Olarila - CLOVER.LGA1366.X58
I can get to the select drive to boot the install FROM .. but verbose mode, I have tried numerous settings with in clover and in options but can't get to a Mac osx install screen, I lost track of the settings I have tried, had it on paper but that many tries and my head won't focus
My question is this DSDT file , will that possibly get me over the hurdle ? and from what I have found I use clover configurator to specify the dsdt.aml file within the efi clover folder ...
not sure if any of that makes sense
basically I'm stuck, I think I need go back to the start
ok do you have the clover / refi folder you could please share ?
I am trying to install either , Mojave or Catalina, not bothered which
Regards
George
OSX.Nobody
CPU: Intel Core-i5 7200U
Motherboard: ASUS X510UQ
GPU: Intel HD 620
DSDT patch requests
Post by OSX.Nobody » 20 Oct 2019, 13:40
19 Oct 2019, 18:51
OSX.Nobody, if u need sync tsc, use it, not problem
check useful links in my sig, have some tutorials
Thanks for your help. I'm really happy.
I have a query. Is it illegal to ask about the procedure that how u patched the DSDT? I mean the list of patches that you applied and where to find them. is there any such tutorial in Olarila site? I just want to learn more.
But if its Against the rules of here. then sorry for mentioning that.
vikkines
CPU: i3
Motherboard: h81m-c
GPU: gtx 750 2gb
DSDT patch requests
Post by vikkines » 20 Oct 2019, 14:30
Without gpu. Plz sent my dsdt :crazy: :crazy:
Return to “DSDT”
