DSDT patch requests
thunder94
CPU: i7 2700k
Motherboard: P8H61-M LX
GPU: ATI Radeon HD 5770
DSDT patch requests
Post by thunder94 » 18 Oct 2019, 08:01
18 Oct 2019, 02:23
thunder94, just enable in bios, whatevergreen have a properties for all igpus, use last version and check if work
Thank you so much I succeeded, I first tried how you told me and then I followed the guide that you initially passed me :D
Szimba
CPU: i9-9900x
Motherboard: Gigabyte x299 Designare Ex
GPU: AMD RX580
DSDT patch requests
Post by Szimba » 18 Oct 2019, 08:39
Hi.
Gsdev im try, but not hot plug...
Dear MaLd0n.
Ca you repatching my ssdt, becuase im forgotten upgrade the bios for my processor microcode.
Thank You, and have a nice day.
Tullaphat
CPU: Intel i7 6700
Motherboard: MSI Z170A M3
GPU: GTX 1080Ti
DSDT patch requests
Post by Tullaphat » 18 Oct 2019, 09:11
My Laptop MSI GE60-2OC (OS : Olarila High Sierra)
I followed Installation guide (every step). But My Laptop can't see ssd as uefi device. I have to boot through usb all the time.
DSDT will fix this?
tytu1202
CPU: i5 8250U
Motherboard: Acer Aspire E5-576G-54JQ
GPU: UHD 620 ; MX150
DSDT patch requests
Post by tytu1202 » 18 Oct 2019, 10:07
Good day! Please help me ^^
Hãy thách thức và thay đổi thế giới bằng bàn phím của bạn.
ssprod
Donator
Donator
DSDT patch requests
Post by ssprod » 18 Oct 2019, 12:05
17 Oct 2019, 14:38
Greetings, Maldon. When I use this DSDT, the system KP's just prior to display. Incidentally, this unit is a 1600x900 Display. Thanks
erpipas46
CPU: Asus
Motherboard: Asus
GPU: Nvidia Geforce
DSDT patch requests
Post by erpipas46 » 18 Oct 2019, 13:01
greg_99
CPU: intel i5 7th gen
Motherboard: Asus
GPU: Nvidia gt940mx
DSDT patch requests
Post by greg_99 » 18 Oct 2019, 13:31
Hi, Maldon. I need your help.
My laptop is Asus A556UQ, my specification are intel i5 7th gen, graphics : Intel HD Graphics 620.
I have problem with battery info, audio, touchpad, wifi, brightness setting.
Thank you before, Gbu.
eslam2500
CPU: 8550u
Motherboard: lenovo
GPU: mx150 - intel uhd 620
DSDT patch requests
Post by eslam2500 » 18 Oct 2019, 13:45
please help me trackpad doesn't shot in setting but working with bugs when I use voodooi2c ... and sleep/wake bug
thanks
Added in 11 minutes 42 seconds:
Lenovo ideapad 520 ... trackpad works when I used voodooi2c but not recognized in setting and works without features and can't patch it
and see/wake bug please..
and thanks
lingam
CPU: i7-8700
Motherboard: tuf z390-pro
GPU: gtx1050ti
DSDT patch requests
Post by lingam » 18 Oct 2019, 14:33
Hiiii dable display is not working . Nvidia. Fix my dsdt
nattevagon
CPU: Intel HD i7
Motherboard: ASUS X450JB
GPU: NVIDIA Geforce 940M
DSDT patch requests
Post by nattevagon » 18 Oct 2019, 14:39
Hai maldon, I need your help again
My Laptop is ASUS X450JB
my specs is Intel HD Graphics 4600 / intel i7 gen 4
i have using olarila mojave
I want fix my brightness hotkey on keyboard, with fn+f5 for decrease brightness and fn+f6 for increase brightness and fn+f7 for off display, then I want to ask something about wifi, how to repair wifi with broadcom, because previous I used Atheros but the connection is very slow
i have problem with battery, my device have not battery info such as low battery info or recharge info.
thankyou before mr Malden , god bless u
aabir
CPU: i3-4170
Motherboard: H81M-S2PV
GPU: intel HD 4400 Graphics
DSDT patch requests
Post by aabir » 18 Oct 2019, 15:04
please help me with OC DSDT.
here is my OC send me file.
HeroBC
CPU: i7-4790k
Motherboard: Asus Pro Wifi ac
GPU: GTX 1080ti
DSDT patch requests
Post by HeroBC » 18 Oct 2019, 15:26
Hi, Mald0n
My laptop is MSI GE62 (OS : Catalina)
Sleep and brightness doesn't work.
moataz59
CPU: i5 4200h
Motherboard: lenovo y50-70 intel
GPU: nividia gtx86m
DSDT patch requests
Post by moataz59 » 18 Oct 2019, 15:30
I need a help with my Brightness slider and sleep .. if there is error .. thanks for help
A-D-H-I
CPU: Core I 5 8250U
Motherboard: ASUS
GPU: Nvidia Geforce 940MX
DSDT patch requests
Post by A-D-H-I » 18 Oct 2019, 15:46
Hai Maldon, can you help me, i have some problem
I am using ASUS A442U Core i5 8250U
the problem's are
- Battery Info, Audio Driver, Volume setting, Brightness setting, sleep , and the important thing is my touchpad can't work
I've tried to follow your guide , but still can't work for me . I really appreciate if you help me to patching DSDT , Thank you .
Is there any relation with config.plist ?
Andreigr
CPU: Intel Core i5-8250U
Motherboard: Acer Nitro 5 515-31
GPU: GeForce MX150/UHD 620
DSDT patch requests
Post by Andreigr » 18 Oct 2019, 16:42
17 Oct 2019, 01:55
Andreigr, i edited ur files, use same, don't need edit again
So, there is no way to get touchpad work like in MacBooks?
eddie1681
CPU: Core I5 8500K
Motherboard: GIGBYTE Z370DM DS3H
GPU: RX 580
DSDT patch requests
Post by eddie1681 » 18 Oct 2019, 16:59
Hello Maldon,
I am still have the same issues after the DSDT patch . but it's a little different. this time when I put it to sleep, it will reboot. I can put it to sleep after. But it will reboot in the middle of the night and sleep again after
I have the following
CPU: Core I5 8500K
GPU: RX 580
32GB or Ram
I attached a new run me file I just did , and the DSDT patched I got , the way I patched it was to paste the AML file in the ACPI patched folder.
Thank you again!!
nilham92
CPU: Intel Core i5 8250u
Motherboard: Asus X442URR
GPU: Nvidia GT930MX
DSDT patch requests
Post by nilham92 » 18 Oct 2019, 17:03
Hello, anyone can help me patching DSDT and SSDT? I'm using Catalina with Clover boot loader right now. I attach required file. Thanks before
Specifications:
- Intel Core i5-8250u
- 4GB RAM
- Intel UHD620
- Nvidia 930MX
- Adata 120GB SSD
forerunner
CPU: i5
Motherboard: z390 aorus pro
GPU: rx590
DSDT patch requests
Post by forerunner » 18 Oct 2019, 20:53
Just join the forum and install painless Catalina with your FANTASTIC IMAGE.
Shutdown doesn't work fine, the pc reboot instead of to poweroff.
Here my files.
Thanks a lot in advance.
moemengaber
CPU: i5 4750
Motherboard: HP 800 G1
GPU: NVIDIA GT 730 DDR5
DSDT patch requests
Post by moemengaber » 18 Oct 2019, 23:22
Hi, Thanks for your efforts to make our Hackintosh better <3
My problem is :
i have HP ELitedesk 800 g1 TWR, with Haswell Processor -->
Processor : i5 4750
VGA: NVIDIA GT 730 DDR5 ( Works OOB )
I have catalina and everything is OK ( i guess ) , but i don't know if everything is actually fine, is my pc run with it's full power?
I have a compiled DSDT ( but full with errors ):
1- When i put it in CLOVER and reboot, sleep works, everything seems more stable but slower than before, but processor reaches very low frequencies when i don't use it and i that's what makes me think that i need DSDT.
2- When i delete DSDT everything back to be fast but i think it's less stable, sometimes i feel something crashes and i feel my pc is hot ( with HWMonitor app), also i feel the processor works with high frequencies sometimes in idle when i don't use it.
So, can anybody please have a look on my CLOVER folder ( Specially Config.plist ) and give me a fixed DSDT ( DOES I NEED DSDT ? ) or give me some advices ?
PS: i think my problem is the errors in DSDT and some optimizations in config.plist ( i'm not a professional so that's only my guess ).
Thanks a lot for your help :D
kobkob772
CPU: i5
Motherboard: -
GPU: hd 2000
DSDT patch requests
Post by kobkob772 » 19 Oct 2019, 00:09
Patch bluetooth please. (Broadcom BCM94322HM8L)
Return to “DSDT”
