DSDT patch requests
GSDEV
CPU: Ryzen 5 2600
Motherboard: B350GT3
GPU: RX580
DSDT patch requests
Post by GSDEV » 17 Oct 2019, 02:19
17 Oct 2019, 01:42
GSDEV, então o seu não tem suporte, vc tem de criar
eddie1681, DSDT.aml.zip
Added in 46 seconds:
MaLd0n descobri que minha placa mãe no manual e site fala que o codec é o ALC 887, mas no hackintosh ele reconhece como ALC 891, assim resolvi colocando o layou-id 11, obrigado pela ajuda
ogrima, cara, já editei esses arquivos mais de 30 vezes aqui no fórum, veja se vc acha na busca
DSDT patch requests
Post by MaLd0n » 17 Oct 2019, 02:24
thunder94,
Added in 43 seconds:
luyenk, i edited ur files, use same
GSDEV, ;)
GSDEV
CPU: Ryzen 5 2600
GPU: RX580
DSDT patch requests
Post by GSDEV » 17 Oct 2019, 02:43
Estou recebendo este erro agora, AVDCreateGPUAccelerator: Error loading GPU renderer, alguém sabe como resolver?
ssprod
Donator
Donator
DSDT patch requests
Post by ssprod » 17 Oct 2019, 02:46
Greetings, Maldon. System is running well with your appropriate EFI folder, however I'm unable to obtain Trackpad control, Audio, Brightness, or Battery Status. Any assistance would be greatly appreciated. Thank you, sir!
HP Elitebook 840-G2
Intel i5-5300U
HD5500
Morganemi
Donator
Donator
CPU: Intel i9 9900K
Motherboard: Gigabyte Z390 Dezignare
GPU: AMD Radeon RX 560 DE 2GB
DSDT patch requests
Post by Morganemi » 17 Oct 2019, 03:01
17 Oct 2019, 02:18
Morganemi, looks good
Thanks again :) Im not sure about everything he did but its working great now. Not sure if it was intentional but the Clover EFI folder for the HackBeast for the designare is missing the drivers for NVRAM. that's what was causing the issue with iMessage and FaceTime
nattevagon
CPU: Intel HD i7
Motherboard: ASUS X450JB
GPU: NVIDIA Geforce 940M
DSDT patch requests
Post by nattevagon » 17 Oct 2019, 03:19
Help me ASUS X450Jb
using Olarila Mojave 10.14.6 (18G95)
- 2,59 GHz Intel Core i7
- 8 GB 1600 MHz DDR3
- Intel HD Graphics 4600 4mb
how to make my VRAM full?
and my driver still vanilla only have keyboard + mouse + touchpad
thankyou
Morganemi
Donator
Donator
CPU: Intel i9 9900K
DSDT patch requests
Post by Morganemi » 17 Oct 2019, 03:32
17 Oct 2019, 02:18
alcanfane
DSDT patch requests
Post by alcanfane » 17 Oct 2019, 03:43
Can I also have dsdt.aml for my build too please
Szimba
CPU: i9-9900x
Motherboard: Gigabyte x299 Designare Ex
GPU: AMD RX580
DSDT patch requests
Post by Szimba » 17 Oct 2019, 06:23
Thank You MaLd0n !
Im see pci devices correctly ,the TB hot plug isnt working, but your beer on the way !
Best.
Szimba
adriteam
CPU: 6700HQ
Motherboard: Intel HM170 (Skylake PCH-H)
GPU: HD Graphics 530 and GTX 970M
DSDT patch requests
Post by adriteam » 17 Oct 2019, 06:44
Hello again MaLd0n and company.
I installed Mojave on my partner's laptop and here I send the Sendme.
I also attached a Kernel Panic log that happened to me when I started Mojave, just after extracting Origin with F4 in Clover in case it helps.
Lenovo U310 i5-3337U model with Multitouch Display 10 points.
Thanks for your time!!
jzaxjzax
CPU: intel Core i5-9600K
Motherboard: Asus Prime H370M-Plus
GPU: Sapphire Pulse RX580 4GB
DSDT patch requests
Post by jzaxjzax » 17 Oct 2019, 07:06
Hi Olarila team,
Need your support checking my Hackintosh if it looks fine and help fix some problems.
This time, I need fix about sleep, I can have my hack go sleep with click sleep menu sleep all night and wake perfectly with just a Magic Mouse click (can't use switch on/off to wake)
But the problem is while Hackie sleep, Fan and LED inside the case never sleep. Still on while only the Monitor off.
And other problems, I don't see it clearly that it a big deal for everyday use. By the way, if you kindly help to take a bit look around and fix something you think that it's weird nonsense or unneccesary to have, that would be thankfully appreciated.Thank you
intel Core i5-9600K 3.7GHz
M/B Asus Prime H370M-plus
Ram 2666 32gb Corsair
GPU Saphire Pulse RX580 4GB ( Also 560 570 all working too)
M.2 SSD WD black 250GB
SATA SSD GLOWAY 480 GB
HDD Seagate Barracuda 2TB
Wireless BCM943602CS PCIe X1
khalidthami
CPU: i7-8565U
Motherboard: Asus UX433FA
GPU: HD620
DSDT patch requests
Post by khalidthami » 17 Oct 2019, 07:19
Hi, please help me with DSTD patching
ACPI.zip
Asus ux433fa
i7-8550u whiskey lake-u
HD620
alphonse
CPU: I5 3750
Motherboard: P8Z77-M
GPU: 1050TI
DSDT patch requests
Post by alphonse » 17 Oct 2019, 07:44
13 Oct 2019, 05:16
alphonse, processors with F don't have IGPU and intel quick sync don't work, the problem is it, next time use processor with igpu
u can try with imacpro1,1 smbios
use geekbench4, geekbench5 is diff and points is low
Are your sure no igpu is problem?
I will buy new one if it worth
thunder94
CPU: i7 2700k
Motherboard: P8H61-M LX
GPU: ATI Radeon HD 5770
DSDT patch requests
Post by thunder94 » 17 Oct 2019, 08:20
17 Oct 2019, 02:26
thunder94, DSDT.aml.zip
GSDEV, ;)
Thanks for the quick response, everything works, but I noticed that the cpu works only at 1.6 GHz, looking at the Intel Power Gadget program, how can I fix it?
luyenk
CPU: Intel Core i7-5500U
Motherboard: Dell Inspiron 5458
GPU: Intel HD Graphics 5500
DSDT patch requests
Post by luyenk » 17 Oct 2019, 09:50
17 Oct 2019, 02:26
GSDEV, ;)
Thank you very much
But after copying the file to the EFI \ CLOVER \ ACPI \ patched folder, the keyboard was disabled.
Now what do I do next?
porro
CPU: Intel i5 8600k
Motherboard: Gigabyte Z370 HD3P
GPU: Radeon RX 580
DSDT patch requests
Post by porro » 17 Oct 2019, 10:04
Thank you MaLd0n for help, but using the DSDT i get a kernel panic. Looking to panic log i have removed plugin type one section from DSDT and now I can boot fine. With F10 bios I used to set plugintype one, but now with F13 bios it only give me kernel panic if set, with or without using DSDT.
ahmedgamal09
CPU: core i3-6006u
Motherboard: Unknown
GPU: Intel hd520
DSDT patch requests
Post by ahmedgamal09 » 17 Oct 2019, 11:48
can anyone help me with my trackpad it dos not work at all
DSDT patch requests
Post by MaLd0n » 17 Oct 2019, 13:58
GSDEV, tem de usar iMacPro1,1 smbios pro hardware accel
Added in 11 minutes 50 seconds:
ssprod,
new send_me after reboot
Added in 2 minutes 25 seconds:
Morganemi, in some cases cause issues in others no
Added in 23 seconds:
nattevagon, hackintool
Added in 7 minutes 53 seconds:
alcanfane,
Added in 2 minutes 20 seconds:
Szimba, check kgp ssdt about hotplug, work in some cases
Added in 1 minute 1 second:
adriteam, use a hackintool to create a video patch, the problem is framebuffer
Added in 10 minutes 15 seconds:
jzaxjzax,
Arquivo Comprimido.zip
is a common problem with asus mobo, check ERP option in bios/uefi
Added in 3 minutes 49 seconds:
khalidthami,
A-D-H-I
CPU: Core I 5 8250U
Motherboard: ASUS
GPU: Nvidia Geforce 940MX
DSDT patch requests
Post by A-D-H-I » 17 Oct 2019, 14:45
Mald0n , can you help me to fix , baterai , wifi , toucpad , brightnes , and audio . Please help me.. i will very grateful to you..
Thank you very much if you or any one help me
This is my Run Me
DSDT patch requests
Post by MaLd0n » 17 Oct 2019, 14:49
alphonse, the intel quick sync solve many problems, jpg preview, freezes, fast encoder/decoder, etc
u can try with iMacPro1,1 smbios
Added in 1 minute 27 seconds:
thunder94, generate ssdt for power management
Added in 35 seconds:
luyenk, try with acidenthera version
porro, in my dsdt have a plugin type
Added in 24 seconds:
ahmedgamal09, [Local Link Removed for Guests]
Added in 1 minute 36 seconds:
A-D-H-I, check useful links in my sig, u have a good start, no just need a personal things
Return to “DSDT”
