DSDT patch requests
berserk
CPU: core i3 m330
Motherboard: toshiba l500
GPU: mobility ati 4650
DSDT patch requests
Post by berserk » 16 Oct 2019, 14:07
Added in 1 minute 11 seconds:
berserk, fix it via clover not dsdt or ssdt
what processor generation?
i7-8565U 8 generation
porro
CPU: Intel i5 8600k
Motherboard: Gigabyte Z370 HD3P
GPU: Radeon RX 580
DSDT patch requests
Post by porro » 16 Oct 2019, 14:41
Hi MaLd0n, attached files please help with dsdt , thanks!! :help
aawu1079
CPU: I7-3770K
Motherboard: GA Z77P-D3
GPU: RX580 8GB
DSDT patch requests
Post by aawu1079 » 16 Oct 2019, 14:56
15 Oct 2019, 21:15
aawu1079,
(40.7 KiB) Downloaded 1 time
Hi MaLd0n
After applied DSDT.aml and reboot. I cannot move keyboard and mouse in login pages.
please suggestion.
Szimba
CPU: i9-9900x
Motherboard: Gigabyte x299 Designare Ex
GPU: AMD RX580
DSDT patch requests
Post by Szimba » 16 Oct 2019, 15:08
Hi Maldon.
Help me to patch my DSDT please.
Gigabyte X299 Designare EX i9-9900X-AMDRX580.
Can you help me Thunderbolt hotswap?, and sleep not working , sleep is doing shutting down...
Thanks.
nichnich
CPU: 8700k
Motherboard: Gigabyte Aorus Gaming 5
GPU: EVGA 1080ti
DSDT patch requests
Post by nichnich » 16 Oct 2019, 15:20
Send me Nicks-MacBook-Pro.zip
Thank you
khalidthami
CPU: i7-8565U
Motherboard: Asus UX433FA
GPU: HD620
DSDT patch requests
Post by khalidthami » 16 Oct 2019, 17:53
Please help me to correct DSDT and SSDT
ACPI.zip
Hi, please help me with DSTD patching
Deihmos
CPU: i7 7700K
Motherboard: ASROCK Z270 KILLER
GPU: RX 590
DSDT patch requests
Post by Deihmos » 16 Oct 2019, 19:12
Hello thank you for your help. It is really appreciated
Specs
i7 7700K
ASRock Z270 Killer SLI/AC
DW 1830 Wifi
Sapphire RX 590
cloteh
Donator
Donator
CPU: i5-9600
Motherboard: z370m d3h
GPU: radeon rx 580
DSDT patch requests
Post by cloteh » 16 Oct 2019, 19:24
Hi, please help me with DSTD patching.
Send me Claudius-iMac 2.zip
kuarahy@icloud.com
CPU: Intel i7-8565U
Motherboard: Lenovo IdeaCentre B750
GPU: Intel UHD Graphics 620 / NVID
DSDT patch requests
Post by kuarahy@icloud.com » 16 Oct 2019, 19:28
15 Oct 2019, 22:54
Added in 12 minutes 28 seconds:
kuarahy@icloud.com, delete ur efi folder and paste my efi there
EFI.zip
Hi,
Thank you MaLd0n !
The graphic card was correctly recognized after using your EFI !
There are few things that I have to work out
- the track-pad isn't recognized yet (in system preferences), but I can use it, the pointer wouldn't stop though, I have to click on it to make it stop otherwise it would continue moving.
- I realized that after using your EFI the quality of my cam got worse, is there any additional kext I should install?
- the usb wi-fi isnt working properly, I mean, sometimes it works sometimes it doesnt. Sometimes I need to change from one port to another (it is a TP-WN823N)
Once again thank you for your help
Best regards
longlyd
CPU: i5
Motherboard: dell
GPU: hd 530
DSDT patch requests
Post by longlyd » 16 Oct 2019, 20:44
Send me iMac.fritz.box.zip
Hi everyone,
Please help with DSDT create ... Thanks in advance
Morganemi
Donator
Donator
CPU: Intel i9 9900K
Motherboard: Gigabyte Z390 Dezignare
GPU: AMD Radeon RX 560 DE 2GB
DSDT patch requests
Post by Morganemi » 16 Oct 2019, 22:14
Good evening MaLd0n
Sorry to bother you again. But Chris Batenchuk helped me out and got my airplay and sidecar working again but he made some changes to my config.plist. Just wanted to make sure nothing needed any changes in my DSDT file. Heres my new Send Me report.
pedrophro
CPU: i7
Motherboard: Z370
GPU: 1080
DSDT patch requests
Post by pedrophro » 16 Oct 2019, 23:01
Hello. I'm new to hackintosh. My notebook is an Acer E1-571.
3rd generation i3 processor.
4GB RAM and SSD240
I installed Sierra and it worked.
Everything is working fine apparently. (Audio, HDMI with Audio, Wifi, Keyboard, etc.)
My only problem is that Bluetooth is recognized but can't find any pairing devices. As if it wasn't working right. My bluetooth chip is integrated with Wifi. AR9565 (BT> AR3012)
When I turn on the laptop with windows (I did dual boot) and restart to get into Sierra the bluetooth works normally, but when I turn on the computer directly in macOS sierra bluetooth does not work.
Can someone help me? I don't know what to do and I have no experience in source code.
RunMe attached.
kabobslice
CPU: I7 8700
Motherboard: Z390 Aorus Pro
GPU: Radeon Sapphire Nitro+ 580
DSDT patch requests
Post by kabobslice » 16 Oct 2019, 23:30
So I installed the kexts to my library extensions folder, cleared the cache, restarted, still not working. Im assuming my card is defective because it used to work without any kexts. I ordered a new one so we'll see with that. Im running Catalina, but I can't update, and the sleep doesn't work right. It doesn't wake back up and I have to restart it and it boots back with a notification about how the computer closed due to a problem. When I try to update it restarts in the middle of the update and creates a new boot icon in Clover called "Install Mac0s on (My Drive) - Data" When I boot into that icon it just boots up with the apple icon half way then restarts no matter how many times I click that icon.
iaksakkah
CPU: i7 4770k
Motherboard: GA-X87X-UD3H
GPU: MSI RX580 Armor 8gb
DSDT patch requests
Post by iaksakkah » 17 Oct 2019, 00:27
mald0n what you do for people is just great this my first dsdt in years thanks for making it happen!!
thunder94
CPU: i7 2700k
Motherboard: P8H61-M LX
GPU: ATI Radeon HD 5770
DSDT patch requests
Post by thunder94 » 17 Oct 2019, 01:23
I hope to get help to have the dsdt fixed, plus I would like to understand if my cpu is used properly (I tried to run a virtual machine and it does it quite slowly).
i7 2700k
P8H61-M LX
6gb RAM DDR3 1600Mhz
ATI HD 5770
High Sierra 10.13.6 (17G8037)
Send me iMac.station.zip
DSDT patch requests
Post by MaLd0n » 17 Oct 2019, 01:41
GSDEV, então o seu não tem suporte, vc tem de criar
eddie1681,
Added in 46 seconds:
ogrima, cara, já editei esses arquivos mais de 30 vezes aqui no fórum, veja se vc acha na busca
eddie1681
CPU: Core I5 8500K
Motherboard: GIGBYTE Z370DM DS3H
GPU: RX 580
DSDT patch requests
Post by eddie1681 » 17 Oct 2019, 01:44
Thank you Maldon!!
DSDT patch requests
Post by MaLd0n » 17 Oct 2019, 01:50
Dicky_MF,
Added in 1 minute 21 seconds:
agapitox, u need check if hdmi work in intelhd or nvidia
if wootk in intelhd check here
Added in 3 minutes 3 seconds:
profile,
Added in 44 seconds:
Andreigr, i edited ur files, use same, don't need edit again
luyenk
CPU: Intel Core i7-5500U
Motherboard: Dell Inspiron 5458
GPU: Intel HD Graphics 5500
DSDT patch requests
Post by luyenk » 17 Oct 2019, 01:56
Xin chào!
Xin được giúp đỡ
Thank for help :)
DSDT patch requests
Post by MaLd0n » 17 Oct 2019, 01:56
alcanfane, [External Link Removed for Guests]
fabridiross, check useful links in my signature
Added in 1 minute 18 seconds:
berserk, check if work inteluhd 620 or 630 for 8th
Added in 10 minutes :
porro,
Szimba,
SSDT-TB3HP.aml.zip
Added in 4 minutes 45 seconds:
nichnich,
Added in 3 minutes 9 seconds:
Deihmos,
Added in 2 minutes 21 seconds:
Morganemi, looks good
longlyd,
Added in 30 seconds:
pedrophro, bluetooth u need a injector
Return to “DSDT”
