DSDT patch requests
Volneix
CPU: Core I5-4460
Motherboard: Asus B85M-E/BR
GPU: Nvidia GTX 650
DSDT patch requests
Post by Volneix » 19 Sep 2019, 18:10
config.plist.zip
Send me iMac-de-Volnei 20190918.zip
Good afternoon. Please help me with my hack. It had been working well, but after Mojave's arrival several problems began. The worst of these is Quick Look and Preview, which even following various tutorials do not work.
PLACA MÃE:
Asus B85M-E/BR
CHIPSET:
Intel Lynx Point B85, Intel Haswell
PROCESSADOR:
QuadCore Intel Core i5-4460, 3200 MHz (32 x 100) - (Processador Intel Core i5-4460 Haswell, Cache 6MB, 3.2GHz (3.4GHz Max Turbo), LGA 1150, Intel HD Graphics 4600
PLACA DE VÍDEO:
NVIDIA GeForce GTX 650 - (Placa de vídeo VGA EVGA GeForce GTX650 1024MB (1GB)
AUDIO:
nVIDIA HDMI/DP @ nVIDIA GK107 - High Definition Audio Controller
Realtek ALC887 @ Intel Lynx Point PCH - High Definition Audio Controller [C-2]
REDE:
Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
WIRELESS:
Adaptador PCI Express Wireless N 300mbps TL-WN881nd
BLUETOOTH:
Adaptador Usb Bluetooth V4.0 CSR
CONTROLADOR SATA
Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller
CONTROLADOR USB
Intel Lynx Point PCH - USB 2.0 EHCI Host Controller 1 [C-2]
Intel Lynx Point PCH - USB 3.0 xHCI Host Controller [C-2]
SSD:
INTEL SSDSC2CT120A3 (120 GB, SATA-III)
MONITOR:
LG 23MP55 (HDMI) [23" LCD]
Thank you very much.
Yamanouchi
CPU: Intel Core i5-8500
Motherboard: Gigabyte Z370m DS3H
GPU: Intel® UHD Graphics 630
DSDT patch requests
Post by Yamanouchi » 19 Sep 2019, 20:48
Hello.
Here is my file after running the run me app
DSDT patch requests
Post by MaLd0n » 19 Sep 2019, 21:08
raphento, this problem is not about dsdt, try with codeccommander
Added in 2 minutes 37 seconds:
prescriptionFX, Use Olarila Clover folder for ur chipset, reboot and extract new Send_me
Added in 3 minutes :
cane3, Use Olarila Clover folder for your Chipset/Notebook, reboot and extract new Send_me
Added in 6 minutes 56 seconds:
phithiphong,
Added in 4 minutes 45 seconds:
djsnake85,
Added in 7 minutes 55 seconds:
ha2210,
CHECK USEFUL LINKS IN MY SIGNATURE FOR OTHER SOLUTIONS FOR NOTEBOOKS
Added in 1 minute 52 seconds:
aldita, No, use correct smbios for ur processor
Naveed Ahmad,
audio
video
Added in 3 minutes 16 seconds:
ralgon,
nodge, check CSM option in bios/uefi setup
Added in 7 minutes 1 second:
Yamanouchi,
-Donated? Send me one PM-
Djl75
CPU: 9900k
Motherboard: Z390 maximus xi hero
GPU: Gtx 1070 strix
DSDT patch requests
Post by Djl75 » 19 Sep 2019, 23:51
Ok decided to replace some hard rives in my main machine and do a new install of Mac OS high Sierra ... I used the Olarila image and followed the guid.
I must say the Olarila way was much smoother than any other way. operates great. wifi out of the box. just need to install the web drivers next.
Can I please get an dsdt patch.
Send me Darrells-iMac.zip
cane3
CPU: 7700HQ
Motherboard: HP cb006nl
GPU: intel 630/1050 ti
DSDT patch requests
Post by cane3 » 20 Sep 2019, 00:00
thanks, for verifying, I attach the new files with the new efi
djsnake85
CPU: i9 9900k
Motherboard: Asus Strix 370 F
GPU: ASUS Strix 1080Ti /Asus rx 580
DSDT patch requests
Post by djsnake85 » 20 Sep 2019, 00:44
impossible to boot sytem when i make dsdt.aml the in patched folder tryed everything, when i remove dsdt my system start normally
DSDT patch requests
Post by MaLd0n » 20 Sep 2019, 01:16
Djl75,
Arquivo Comprimido.zip
Added in 3 minutes 51 seconds:
cane3,
apply battery patch and enable EC0 to EC patch rename
Added in 1 minute 25 seconds:
djsnake85, idk what happens, need check
djsnake85
CPU: i9 9900k
DSDT patch requests
Post by djsnake85 » 20 Sep 2019, 01:28
if you need more information I'm here , thank you :)
nodge
CPU: I3-4170
Motherboard: ASROCK h81m-vg4 R3.0
GPU: EVGA GTX 1050 OC
DSDT patch requests
Post by nodge » 20 Sep 2019, 02:12
MaLd0n,
CSM disabled.
UEFI Only mode.
iGPU disabled.
Both monitor connected on the Discrete Graphics Card (you can talk in Portuguese with me if you want)
Agradeço a ajuda.
DSDT patch requests
Post by MaLd0n » 20 Sep 2019, 03:39
nodge, with Nvidia card u neeð enable csm, disable is for amd card
daeklove
CPU: i5-9400
Motherboard: MSI MPG Z390 Gaming Plus
GPU: Radeon RX 560
DSDT patch requests
Post by daeklove » 20 Sep 2019, 03:58
Can i have some help with this please?
thanks
david
DSDT patch requests
Post by MaLd0n » 20 Sep 2019, 04:38
daeklove,
Dummyperson
CPU: Intel Core I7-9750H
Motherboard: Clevo NH58EDQ
GPU: Intel UHD Graphic 630/RTX 2060
DSDT patch requests
Post by Dummyperson » 20 Sep 2019, 07:51
Currently, the display brightness is low for the maximum brightness when ticked add_pnlf in config, with ssd-pnlf.aml I got the maximum brightness however a small decrease in brightness slider will make the display dark as similar to add pnlf. Sleep is kinda successful, fans turn off however when waking it up display is black, tried pressing keyboards nothing function and boot fails twice (cannot reach clover once, boot into black screen once after that booting normally works). Can't turn off keyboard lighting only turn off in window with the control centre.
ralgon
CPU: i5
Motherboard: lenovo s300
GPU: amd
DSDT patch requests
Post by ralgon » 20 Sep 2019, 09:01
19 Sep 2019, 21:45
ralgon, DSDT.aml.zip
Hello Mald0n. Thank you so much. I replaced my EFI folder with one you gave to another user and DSDT.aml that you posted and everything seems to work very well. The only problem I can't solve is with the hdmi output. When I connect or disconnect another screen the pc crash. Could you help me with that?
Ghoys
CPU: Core i3 8100
Motherboard: MSI 310 PRO-VH
GPU: INTEL UHD 630
DSDT patch requests
Post by Ghoys » 20 Sep 2019, 10:00
17 Sep 2019, 15:43
mportner, DSDT.aml.zip
Added in 1 minute 47 seconds:
venom86, i don't remember what ur hardware
Added in 8 minutes 37 seconds:
Ghoys, Arquivo Comprimido.zip
Added in 6 minutes 26 seconds:
Linkakid, ur config is very wrong, use olarila clover folder for chipset serie 9
hello, thanks for fix in my dsdt. but my audio not work, my device is alc 888b.
this my config.plist
236560739
CPU: I7-8700k
Motherboard: Z370-F
GPU: RX580
DSDT patch requests
Post by 236560739 » 20 Sep 2019, 10:22
I need help to dsdt
i7 8700k
ROG-STRIX-Z370-F-GAMING
RX580 PLUS
Hootpy
CPU: I3-9100f
Motherboard: GIGABYTE B150M-Wind
GPU: RX 550 2gb
DSDT patch requests
Post by Hootpy » 20 Sep 2019, 12:35
I have changed my graphics card to RX 550 2gb but the system does not recognize it. It displayed 7mb graphics. Does this card can be used by patching gpuid? Thanks in advanced!
Specs: i3-9100f - b150m gigabyte - rx 550 2gb power color
mviana2k
CPU: i7-8700
Motherboard: MSI Z730 PC PRO
GPU: GFORCE GTX 650
DSDT patch requests
Post by mviana2k » 20 Sep 2019, 12:52
Hi, my name is Marcelo please help with this one. Thanks.
aler83
CPU: i7 4770k
Motherboard: z87-pro
GPU: rx570
DSDT patch requests
Post by aler83 » 20 Sep 2019, 13:51
Hi Maldon,
Could you please create an DSDT for my system. I'm running IMACPRO1,1 so that I don't have any issues with iGPU and DRM content.
Asus Z87-Pro
Intel i7 4770k
Saphire RX570 ITX
Everything works but would like to get rid of WEG kext, without it, it black screens
Also I haven't modified anything on config.plist for my chipset except smbios, please let me know if its okay or if there are things I can get rid of.
thanks you so much.
attached original acpi as well.
m4vrox
CPU: I7-7770
Motherboard: ASRock Fatal1ty Z270 Gaming-IT
GPU: Zotac GeForce GTX 1080
DSDT patch requests
Post by m4vrox » 20 Sep 2019, 14:44
Hi,
I updated from High Sierra to Mojave and everything seems to work expect a very weird issue:
My keyboard does not work, my mouse does.
I changed the USB port to connect my keyboard it does fix it
Even more funny I tried to connect my mouse to my keyboard USB port and the mouse works but not the keyboard! :wallbash
I tried your Clover folder for MB 100/200/300 to generate the zip file without success to fix the keyboard
I also started form fresh with a new USB install try but same thing booting on USB install stick, the keyboard does not work
- Motherboard Fatal1ty Z270 Gaming-ITX/ac
- CPU Intel Core i7-7700
- RAM Corsair Vengeance LPX 32 GB DDR4-2400
- GPU Zotac GeForce GTX 1080 8 GB Mini (Will swap to iGPU if / when keyboard fixed)
- SDD Samsung 960 EVO 500 GB M.2-2280 NVME
I hope the DSDT will fix the issue
I attached my zip archive
Thanks a lot in advance
Return to “DSDT”
