DSDT patch requests
cperkins87
CPU: intel i5 4210u
Motherboard: asus
GPU: intel 4400 hd
DSDT patch requests
Post by cperkins87 » 18 Sep 2019, 16:28
Asus q502la
intel i5-4210u
intel hd4000 graphics
battery not showing, sleep not working, hardware access not working, no volume, no audio, no bluetooth, basically I just got it installed and can't figure out anything
running 10.14.6 olarila
also I can't get it to boot from hard drive I have to leave the usb plugged in and then I have to use the keyboard to navigate
also in Mac OS the mouse is glitchy on clicking and the top bar in the web browser is graphics are kind of garbled glitchy sometimes
ruhul20
Donator
Donator
CPU: i9700k
Motherboard: z390-f
GPU: RX580
DSDT patch requests
Post by ruhul20 » 18 Sep 2019, 16:43
18 Sep 2019, 04:10
Added in 10 minutes 59 seconds:
ruhul20, the config looks good, what problem ur hack have?
It keeps restarting randomly.
Theres no fixed time when it does it. Ive only had the computer on for one hour now and its restarted about 9 times already.
blaster15
CPU: i5 5200u
Motherboard: acer
GPU: intel 5500
DSDT patch requests
Post by blaster15 » 18 Sep 2019, 16:59
model= acer e5 571
intel i5-5200u
intel hd 5500
a good part of the hack is working but certain things are weird like at some point it crashes and doesn't work after that. I believe that something is missing, could help?
majeddh
CPU: Intel i7-8850U
Motherboard: HP 15-DA0019NIA
GPU: UHD 620 + MX130
DSDT patch requests
Post by majeddh » 18 Sep 2019, 17:08
here is the send me file :
just a note: System didn't boot previously without the patched dsdt files in clover/acpi/patched (using only original)
Send me Majeds-iMac.zip
venom86
CPU: Intel Core i7 3520M
Motherboard: Dell Latitude E6530
GPU: Intel HD4000
DSDT patch requests
Post by venom86 » 18 Sep 2019, 18:02
18 Sep 2019, 15:11
Added in 19 minutes 5 seconds:
venom86, CLOVER.zip
Sorry, same here, used your config.plis with your dsdt and kexts, but no luck.
DSDT patch requests
Post by MaLd0n » 18 Sep 2019, 19:24
cperkins87,
check useful links in my sig for some notebooks solution
Added in 5 minutes 30 seconds:
ruhul20, ur config is correct.
take some tests without overclock, test all ur hardware too
Added in 7 minutes 31 seconds:
blaster15,
use olarila clover folder for ur chipset
Added in 1 minute 30 seconds:
majeddh, use hackintool for activate video
Added in 36 seconds:
venom86, the config is correct, idk what happens
-Donated? Send me one PM-
raphento
CPU: I7 7500U
Motherboard: DELL
GPU: INTEL 620
DSDT patch requests
Post by raphento » 18 Sep 2019, 19:47
I put the patch you made available and thanks in advance.
Headset audio worked and CPU consumption was no more than 15% even at rest. After restarting a few times, the headset audio stopped working and processing returned to 15%, even at rest.
Could you help me correct?
I have attached the new send_me already with DSDT.
Thanks.
ruhul20
Donator
Donator
CPU: i9700k
Motherboard: z390-f
GPU: RX580
DSDT patch requests
Post by ruhul20 » 18 Sep 2019, 21:26
18 Sep 2019, 19:39
Thanks Maldon,
Got some good things to report to you now. The PC has been on for the past 3 hours and no random restart.
lucaskds
CPU: INTEL i7 8700K
Motherboard: Z370 GAMING 7 AORUS
GPU: NVIDIA 1070ti
DSDT patch requests
Post by lucaskds » 18 Sep 2019, 21:54
18 Sep 2019, 04:10
bramon, DSDT.aml.zip
tbh need a ssdt by kgp
bt need a rehabman injector
Added in 1 minute 41 seconds:
criolodoido, have a some bug with ur bios, extract original tables with f4 key in clover boot screen
Added in 4 minutes 13 seconds:
lucaskds, Arquivo Comprimido.zip
Added in 1 minute 18 seconds:
venom86, u need extract send_me with my dsdt load
rfemove FakePCIID_XHCIMux
capitanbelico, use olarila clover folder for chipset serie 100/200/300
Added in 14 minutes 56 seconds:
majeddh, need patch dsdt
sdsuster, DSDT.aml.zip
Added in 8 minutes 43 seconds:
Naveed Ahmad, DSDT.aml.zip
Added in 6 minutes 57 seconds:
ssprod, DSDT.aml.zip
Added in 4 minutes 55 seconds:
Francisco_live, DSDT.aml.zip
install voodooi2c kexts
Added in 1 minute 35 seconds:
josefikuii, google drive
Added in 2 minutes 12 seconds:
mportner, u need check my signature, useful links, some things in notebook is personal
Thanks a lot! :)
lucianopopa
CPU: i7 6700
Motherboard: Z170m-Plus
GPU: GTX 1070 8Gb OC
DSDT patch requests
Post by lucianopopa » 18 Sep 2019, 23:04
Alguém consegue me ajudar a verificar minha dsdt?
Send me iMac-de-Bandeide.zip
prescriptionFX
CPU: i3-3337U
Motherboard: Intel 7 Series/C216
GPU: Intel 4000
DSDT patch requests
Post by prescriptionFX » 18 Sep 2019, 23:06
Hi, I would appreciate if I can get some help with a fresh dsdt patching so I can get a working build for my Dell XPS 2720. I appreciate any help info/help.
Send me Rickys-iMac.zip
i5-4430S (Intel HD 4600)
Intel 87/ rev. C1
16gb RAM
ALC668 (not sure which layout id)
Sony Vaio Fit 15 (svf15a1acxb)
Laptop w/ 8gb RAM
Intel HD 4000
cane3
CPU: 7700HQ
Motherboard: HP cb006nl
GPU: intel 630/1050 ti
DSDT patch requests
Post by cane3 » 18 Sep 2019, 23:08
hello friend, after following many guides trying to patch dsdt and fix my hp laptop, I find myself asking for help.
I made an installation (vanilla), fixed audio, intel video 2 gb, bluethoot (intel integratet).
I was wondering if you can help me, check the whole thing a little, even giving me advice!
I thank you for your work!
phithiphong
CPU: E5-2660
Motherboard: intel S2600co
GPU: 1080
DSDT patch requests
Post by phithiphong » 19 Sep 2019, 06:03
thank
djsnake85
CPU: i9 9900k
Motherboard: Asus Strix 370 F
GPU: ASUS Strix 1080Ti /Asus rx 580
DSDT patch requests
Post by djsnake85 » 19 Sep 2019, 08:21
Hello
plese i need DSDT patch for my Dell latitude E5450
OS:Mojave 10.14.6
CPU :i5-5300U
GPU : Intel HD 5500
Memory: DDR 3 1600
SSD : samsung 850 EVO
bazsound
CPU: i7-3632QM
Motherboard: Sony VAIO Intel HM76
GPU: AMD Radeon HD 7550M/7650M
DSDT patch requests
Post by bazsound » 19 Sep 2019, 11:27
Here is my file after running the run me app..
My first time doing mackintosh, so not quite sure of everything. Tried my chipset but it stops things booting. Anyway that's in another thread
ha2210
CPU: E8400
Motherboard: G41
GPU: GT730
DSDT patch requests
Post by ha2210 » 19 Sep 2019, 13:20
HP 4420s Gen 1st installed 10.12 full QE / CI but installing 10.14 is also a kext but can't full QE / CI, help me full QE/CI, patch the brightness, battery and get all usb ports with it.
Thanks very much
aldita
CPU: i7 6700k
Motherboard: GIGABYTE z170x-ud3
GPU: DA GTX 1080
DSDT patch requests
Post by aldita » 19 Sep 2019, 13:45
13 Sep 2019, 14:38
metr1k, DSDT.aml.zip
Added in 56 seconds:
doucaniggia, check if dsdt work good
Added in 2 minutes 59 seconds:
criolodoido, dsdt bug, extract original tables
enable intel quick sync
Added in 3 minutes 22 seconds:
musicazx, DSDT.aml.zip
Added in 3 minutes 54 seconds:
aldita, DSDT.aml.zip
usse Olarila clover folder for chipset series 100/200/300
thanks Mald0n.. it works greats. sorry for late response. can i keep uses smbios imac 10.1 ?
Naveed Ahmad
CPU: i5 8400 + i3 7100U
Motherboard: GA-Z370M-D3H+Aspire Mob 7thGen
GPU: Intel UHD 630+ Intel HD 620
DSDT patch requests
Post by Naveed Ahmad » 19 Sep 2019, 15:22
Dear MaLd0n
intel HD 4600. only 5 MB
Audio not worked
DSDT and pics Attached
Mobile
SkyLake
DELL LATiTUDE E-7470 14" 6th Gen
Display Touch Screen Working on Mojave-10.14.3
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Hynix 256 GiB Nvme SSD
Clover UEFI 10.14.3
:cap :frantics :guitar :shock:
nodge
CPU: I3-4170
Motherboard: ASROCK h81m-vg4 R3.0
GPU: EVGA GTX 1050 OC
DSDT patch requests
Post by nodge » 19 Sep 2019, 16:27
tried to patch myself using the forum threads and youtube videos, no results.
so I did a fresh install and decided to make a help post.
What I'm trying to make work: Dual monitors on boot.
I can boot my hack on, then plug the Displayport monitor and use dual monitors normally. But if i try to boot on clover with the DisplayPort connected both screens get black.
ralgon
CPU: i5
Motherboard: lenovo s300
GPU: amd
DSDT patch requests
Post by ralgon » 19 Sep 2019, 18:07
Hi,
huawei matebook d i3
i3-8130U
Intel® UHD Graphics 620.
No audio, no battery indicator, no Bluetooth, bad graphics :help :help
Can you help me please?
thanks
Return to “DSDT”
