DSDT Patch request [Dell Inspiron gaming 7567]
laloalire
CPU: Intel Core i5 7300-HQ
Motherboard: Dell Inspiron 15 7000 Laptop
GPU: HD Graphics 630- Nvidia 1050Ti
Post by laloalire » 28 Jul 2019, 17:34
Hello everyone, I finished up writing here to ask for help to patch my DSDT,
Almost everything works just fine (touchpad w/gestures, keyboard, brightness, sound, acceleration)
Also iMessage/Facetime works well with all iCloud services
Here are the main specs of my Laptop
Intel Core i5 7300HQ with HD graphics 630 (2048MB of graphics memory)
16GB Ram
Nvidia 1050 Ti (disabled per Optimus tech with a dsdt file I found on internet XD)
DW1560 BCM94352z ---> this should be supposed to work fine :(
The only issues I have right now is:
-Kernel panics when wake from sleep (started happening after install a DW1560) :wallbash
-Slow AF boot (started also with DW1560 installation)
-Bluetooth don't work, it sometimes appear as an USB device in system report -->See this for ref [External Link Removed for Guests]
Also when slow boot happens, I got this strange message in verbose boot
busy timeout bcm20702a0
it shows about 5 times before boot, every 60 seconds I think.
Everything else is just fine, I think my ACPI folder is a mess but kinda works well.
SEND ME files are HERE: [External Link Removed for Guests]
File was too large to attach in post, sorry! :wallbash
if any info is needed please let me know, ill be catching up often this post to check
Thanks to all! :laugh:
Post by MaLd0n » 28 Jul 2019, 19:18
laloalire, u have a full dsdt patched, but u use strange renames patch and strange collection of ssdt
laloalire
Post by laloalire » 28 Jul 2019, 19:55
@MaLd0n, I found them on github, and reading about my Bluetooth issue some people say it is a dsdt issue for USB port limit
Also people told me I should merge all those dsdt files into only one but idk how :/
Here are the description from files
- patched:
- SSDT-ALS0: Fake ambient light sensor
- SSDT-BRT6: Brightness control via keyboard
- SSDT-Disable_DGPU: Disable discrete GPU (Nvidia)
- SSDT-I2C: VoodooI2C GPIO pinning & disabling VoodooPS2 kext for trackpads and mouses
- SSDT-PNLF: Backlight ssdt
- SSDT-PRW: SSDT for usb instant wake
- SSDT-UIAC: Injecting right usb ports (coniguration for usbinjectall kext)
- SSDT-XCPM: Injecting plugin-type for power management
- SSDT-XOSI: Faking OS for the ACPI
- SSDT_ALC256: CodecCommander config for ALC256 (removes headphone noise)
More info here: [External Link Removed for Guests]
onemanosx
Post by onemanosx » 28 Jul 2019, 23:09
laloalire, I took a look at your files. You dont need the SSDTs except for maybe I2C,UIAC and BRT6. Why? Because your DSDT is fully patched.
You also do not need the renames that refers to the SSDT esp XOSI, _DSM, PRW
MSI B360 Gaming Arctic
laloalire
Post by laloalire » 30 Jul 2019, 01:06
28 Jul 2019, 23:09
So, you saying I should remove those files from my folder?
onemanosx
Post by onemanosx » 30 Jul 2019, 02:32
30 Jul 2019, 01:06
Simply, yes.
As an example, why would you add SSDT-PNLF when the patch is already done in DSDT?
Return to “DSDT”
