Xeon 2667 V2 Issues
dougsta
CPU: E5-2637 v2 - no macos :(
Motherboard: Dell T5610
GPU: gtx680
Xeon 2667 V2 Issues
Post by dougsta »
I picked up a server on ebay with 2 x e5-2680 v2 cpus (including a 1u case, intel motherboard S2600GZ, 16gb ddr3 1tb and 500gb hd) for £210 :)
I installed the 2 new cpus in the Dell T5610 and the good news is there is no instant kp :)
It was the e5-2637 v2 cpu causing the issue.
I've attached the clover f4 dump with the new cpus, does the new extract need any edits to get it running nicely?
origin.zip
Doug
Xeon 2667 V2 Issues
Post by MaLd0n »
dougsta,
dougsta
GPU: gtx680
Xeon 2667 V2 Issues
Post by dougsta »
cheers, I'll give it a try tomorrow, were there many edits/issues?
Xeon 2667 V2 Issues
Post by MaLd0n »
dougsta, essentials patches, realocate, etc
Leoppard;
CPU: xeon 2630
Motherboard: c602/x79
GPU: K620
Xeon 2667 V2 Issues
Post by Leoppard; »
Good night, then your machine is working? dougsta.
I have similar problem with my lenovo c30. dual xeon. :(
dougsta
GPU: gtx680
Xeon 2667 V2 Issues
Post by dougsta »
Leoppard, I don't think the cpu issue can be solved, the cpus are not supported by the macos kernel.
I swapped out the xeon 'e5-2367 v2' for xeon 'e5-2680 v2' as the cpu has worked in other builds.
I did managed to boot to full macos gui but only sometimes, mostly it gets stuck at or just before the login screen, mouse pointer is very slow/laggy.
I'll try a fresh install of High Sierra
Return to “Hardware”
