HDMI Lion 10.7.5 can't find Method _STA
ic3cold
Post by ic3cold » 10 Mar 2013, 17:05
I'm trying to set up HDMI on Lion 10.7.5, it was working fine until I did a combo upgrade.
Device (PCI0)
            Name (_HID, EisaId ("PNP0A08"))
            Name (_CID, EisaId ("PNP0A03"))
            Name (_ADR, Zero)
            Method (_INI, 0, NotSerialized)
                If (CondRefOf (_OSI, Local0))
                    Store (0x21, OSTY)
            Name (SUPP, Zero)
            Name (CTRL, Zero)
            Method (_OSC, 4, NotSerialized)
                If (LEqual (Arg0, Buffer (0x10)
                            /* 0000 */    0x5B, 0x4D, 0xDB, 0x33, 0xF7, 0x1F, 0x1C, 0x40,
                            /* 0008 */    0x96, 0x57, 0x74, 0x41, 0xC0, 0x3D, 0xD7, 0x66
                    CreateDWordField (Arg3, Zero, CDW1)
                    CreateDWordField (Arg3, 0x04, CDW2)
                    CreateDWordField (Arg3, 0x08, CDW3)
                    Store (CDW2, SUPP)
                    Store (CDW3, CTRL)
                    If (LNotEqual (And (SUPP, 0x16), 0x16))
                        And (CTRL, 0x1E, CTRL)
                    And (CTRL, 0x1D, CTRL)
                    If (Not (And (CDW1, One)))
                        If (And (CTRL, One)) {}
                        If (And (CTRL, 0x04)) {}
                        If (And (CTRL, 0x10)) {}
                    If (LNotEqual (Arg1, One))
                        Or (CDW1, 0x08, CDW1)
                    If (LNotEqual (CDW3, CTRL))
                        Or (CDW1, 0x10, CDW1)
                    Store (CTRL, CDW3)
                    Return (Arg3)
                Else
                    Or (CDW1, 0x04, CDW1)
                    Return (Arg3)
            Name (PBRS, ResourceTemplate ()
                WordBusNumber (ResourceProducer, MinFixed, MaxFixed, PosDecode,
                    0x0000,             // Granularity
                    0x0000,             // Range Minimum
                    0x003D,             // Range Maximum
                    0x0000,             // Translation Offset
                    0x003E,             // Length
                IO (Decode16,
                    0x0CF8,             // Range Minimum
                    0x0CF8,             // Range Maximum
                    0x01,               // Alignment
                    0x08,               // Length
                WordIO (ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange,
                    0x0CF7,             // Range Maximum
                    0x0CF8,             // Length
                    ,, , TypeStatic)
                    0x0D00,             // Range Minimum
                    0xFFFF,             // Range Maximum
                    0xF300,             // Length
                    ,, , TypeStatic)
                DWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, Cacheable, ReadWrite,
                    0x00000000,         // Granularity
                    0x000A0000,         // Range Minimum
                    0x000BFFFF,         // Range Maximum
                    0x00000000,         // Translation Offset
                    0x00020000,         // Length
                    ,, , AddressRangeMemory, TypeStatic)
                    0x00000000,         // Range Minimum
                    0x00000000,         // Range Maximum
                    0x00000000,         // Length
                    ,, _Y00, AddressRangeMemory, TypeStatic)
                DWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, NonCacheable, ReadWrite,
                    0xFED40000,         // Range Minimum
                    0xFEDFFFFF,         // Range Maximum
                    0x000C0000,         // Length
                    0xD0000000,         // Range Minimum
                    0xF7FFFFFF,         // Range Maximum
                    0x28000000,         // Length
                QWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, NonCacheable, ReadWrite,
                    0x0000000000000000, // Granularity
                    0x0000000000000000, // Range Minimum
                    0x0000000000000000, // Range Maximum
                    0x0000000000000000, // Translation Offset
                    0x0000000000000001, // Length
            Method (_CRS, 0, NotSerialized)
                EROM ()
                Return (PBRS)
            OperationRegion (TMEM, PCI_Config, 0x52, 0x03)
            Field (TMEM, ByteAcc, NoLock, Preserve)
                DIM0,   4,
                DIM1,   4,
                        Offset (0x02),
                DIM2,   4
            Name (MTBL, Package (0x10)
                Zero,
                0x20,
                0x20,
                0x30,
                0x40,
                0x40,
                0x60,
                0x80,
                0x80,
                0x80,
                0x80,
                0xC0,
                0x0100,
                0x0100,
                0x0100,
                0x0200
            OperationRegion (PAMX, PCI_Config, 0x90, 0x07)
            Field (PAMX, ByteAcc, NoLock, Preserve)
                    ,   4,
                BSEG,   4,
                PAMS,   48
            Name (ERNG, Package (0x0D)
                0x000C0000,
                0x000C4000,
                0x000C8000,
                0x000CC000,
                0x000D0000,
                0x000D4000,
                0x000D8000,
                0x000DC000,
                0x000E0000,
                0x000E4000,
                0x000E8000,
                0x000EC000,
                0x000F0000
            Name (PAMB, Buffer (0x07) {})
            Method (EROM, 0, NotSerialized)
                CreateDWordField (PBRS, \_SB.PCI0._Y00._MIN, RMIN)
                CreateDWordField (PBRS, \_SB.PCI0._Y00._MAX, RMAX)
                CreateDWordField (PBRS, \_SB.PCI0._Y00._LEN, RLEN)
                CreateByteField (PAMB, 0x06, BREG)
                Store (PAMS, PAMB)
                Store (BSEG, BREG)
                Store (Zero, RMIN)
                Store (Zero, RMAX)
                Store (Zero, RLEN)
                Store (Zero, Local0)
                While (LLess (Local0, 0x0D))
                    ShiftRight (Local0, One, Local1)
                    Store (DerefOf (Index (PAMB, Local1)), Local2)
                    If (And (Local0, One))
                        ShiftRight (Local2, 0x04, Local2)
                    And (Local2, 0x03, Local2)
                    If (RMIN)
                        If (Local2)
                            Add (DerefOf (Index (ERNG, Local0)), 0x3FFF, RMAX)
                            If (LEqual (RMAX, 0x000F3FFF))
                                Store (0x000FFFFF, RMAX)
                            Subtract (RMAX, RMIN, RLEN)
                            Increment (RLEN)
                        Else
                            Store (0x0C, Local0)
                    Else
                        If (Local2)
                            Store (DerefOf (Index (ERNG, Local0)), RMIN)
                            Increment (RLEN)
                        Else
                    Increment (Local0)
            Method (_PRT, 0, NotSerialized)
                If (LEqual (GPIC, Zero))
                    Return (Package (0x47)
                        Package (0x04)
                            0xFFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0xFFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0xFFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0xFFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0001FFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x0001FFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x0001FFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0001FFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0002FFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x0002FFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x0002FFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0002FFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0003FFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x0003FFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x0003FFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0003FFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0004FFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x0004FFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x0004FFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0004FFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0005FFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x0005FFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x0005FFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0005FFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0006FFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x0006FFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x0006FFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0006FFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0007FFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x0007FFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x0007FFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0007FFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0008FFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x0008FFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x0008FFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0008FFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0009FFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x0009FFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x0009FFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0009FFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x000AFFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x000AFFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x000AFFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x000AFFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0012FFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x0012FFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0012FFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0012FFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x0016FFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x0016FFFF,
                            One,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x0016FFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0016FFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x0019FFFF,
                            Zero,
                            ^LPC.LNKE,
                            Zero
                        Package (0x04)
                            0x001AFFFF,
                            Zero,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x001AFFFF,
                            One,
                            ^LPC.LNKF,
                            Zero
                        Package (0x04)
                            0x001AFFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x001AFFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x001BFFFF,
                            Zero,
                            ^LPC.LNKG,
                            Zero
                        Package (0x04)
                            0x001CFFFF,
                            Zero,
                            ^LPC.LNKB,
                            Zero
                        Package (0x04)
                            0x001CFFFF,
                            One,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x001CFFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x001CFFFF,
                            0x03,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x001DFFFF,
                            Zero,
                            ^LPC.LNKH,
                            Zero
                        Package (0x04)
                            0x001DFFFF,
                            One,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x001DFFFF,
                            0x02,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x001DFFFF,
                            0x03,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x001FFFFF,
                            Zero,
                            ^LPC.LNKD,
                            Zero
                        Package (0x04)
                            0x001FFFFF,
                            0x02,
                            ^LPC.LNKA,
                            Zero
                        Package (0x04)
                            0x001FFFFF,
                            0x03,
                            ^LPC.LNKF,
                            Zero
                        Package (0x04)
                            0x001FFFFF,
                            One,
                            ^LPC.LNKC,
                            Zero
                        Package (0x04)
                            0x0019FFFF,
                            Zero,
                            ^LPC.LNKE,
                            Zero
                Else
                        Package (0x04)
                            0xFFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0xFFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0xFFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0xFFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0001FFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x0001FFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x0001FFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0001FFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0002FFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x0002FFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x0002FFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0002FFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0003FFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x0003FFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x0003FFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0003FFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0004FFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x0004FFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x0004FFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0004FFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0005FFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x0005FFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x0005FFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0005FFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0006FFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x0006FFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x0006FFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0006FFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0007FFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x0007FFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x0007FFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0007FFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0008FFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x0008FFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x0008FFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0008FFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0009FFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x0009FFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x0009FFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0009FFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x000AFFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x000AFFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x000AFFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x000AFFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0012FFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x0012FFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0012FFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0012FFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x0016FFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x0016FFFF,
                            One,
                            Zero,
                            0x11
                        Package (0x04)
                            0x0016FFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0016FFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x0019FFFF,
                            Zero,
                            Zero,
                            0x14
                        Package (0x04)
                            0x001AFFFF,
                            Zero,
                            Zero,
                            0x10
                        Package (0x04)
                            0x001AFFFF,
                            One,
                            Zero,
                            0x15
                        Package (0x04)
                            0x001AFFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x001AFFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x001BFFFF,
                            Zero,
                            Zero,
                            0x16
                        Package (0x04)
                            0x001CFFFF,
                            Zero,
                            Zero,
                            0x11
                        Package (0x04)
                            0x001CFFFF,
                            One,
                            Zero,
                            0x10
                        Package (0x04)
                            0x001CFFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x001CFFFF,
                            0x03,
                            Zero,
                            0x13
                        Package (0x04)
                            0x001DFFFF,
                            Zero,
                            Zero,
                            0x17
                        Package (0x04)
                            0x001DFFFF,
                            One,
                            Zero,
                            0x13
                        Package (0x04)
                            0x001DFFFF,
                            0x02,
                            Zero,
                            0x12
                        Package (0x04)
                            0x001DFFFF,
                            0x03,
                            Zero,
                            0x10
                        Package (0x04)
                            0x001FFFFF,
                            Zero,
                            Zero,
                            0x13
                        Package (0x04)
                            0x001FFFFF,
                            0x02,
                            Zero,
                            0x10
                        Package (0x04)
                            0x001FFFFF,
                            0x03,
                            Zero,
                            0x15
                        Package (0x04)
                            0x001FFFFF,
                            One,
                            Zero,
                            0x12
                        Package (0x04)
                            0x0019FFFF,
                            Zero,
                            Zero,
                            0x14
This is the section from my Intel DX58SO motherboard DSDT, where Device PCI0 is declared, may be I am skipping something but there is no Method named _STA there please note the device is 0x00030000 ...
pernacabeluda
Re: HDMI Lion 10.7.5 can't find Method _STA
Post by pernacabeluda » 16 Mar 2013, 10:46
Sorry but this makes no sense. Your problem is probably on video kexts.
Return to “Lion (10.7)”
