AMD hackintosh .........! (Lion )
matpratik
CPU: INTEL core i7
Motherboard: HP DV6 6121TX
GPU: AMD 6770M 2GB DDR5
Post by matpratik » 04 Feb 2013, 10:17
MAC OS X Lion 10.7.3 legacy kernel finally released !
Need this things .....................!
1:-Retail DMG from apple store
2:-USB flash drive at least 8 GB
3:-Lion Legacy kernel
Nedd to change in BIOS......................!
1:-ACPI is enable
2:-Change ide to AHCI
3:-USB legacy is enable
4:-Plug and Play should enable
How to Make USB installer..................!
1:-Restore dmg to USB or
2:-Use unishit for making installer
use this link for making USB installer................!
Once you done Replce the mach_kernel
downlod legacy kernel from here
if u made installer USB using unishit then simply replace mach_kernel
OR
Make " Extra "folder in USB and copy FakeSMC.kext and install chimera 1.11 boot loader on USB and boot from USB
HP Pavilion DV6 6121TX
-OS X 10.8.3 Mountain Lion,OS X Lion 10.7.5 & Win7(x64)
-Intel Core i7-2630QM 2,0GHz (Sandy Bridge)
-6gb DDR3-1333,640 HDD,InsydeH20 Bios F1B
-AMD Radeon HD 6770M 2GB & Mobile Intel® HD Graphics 3000 (switchable)
Return to “Lion (10.7)”
