Olarila HackBeast Z390 DESIGNARE - Thunderbolt - Full DSDT patches - CLOVER - OPENCORE
Olarila Hackintosh Machines. The Real Vanilla!
bluepr0
CPU: 9900k
Motherboard: Asus Prime Z370-A II
GPU: RX580 8GB
Post by bluepr0 » 28 Sep 2019, 12:29
I thought Designare Z390 was not recommended due to the need to use OSXAptioFix2Drv-Free2000.efi which is discouraged from its own developer
Post by MaLd0n » 28 Sep 2019, 14:45
bluepr0, the driver work good for years and never burn any hack
u can use aptiomemoryfix with my files, work good without igpu enable
hbp
CPU: I 8700K
Motherboard: GA-Z390-DESIGNARE
GPU: VEGA 56 8 GB
Post by hbp » 07 Oct 2019, 22:09
@MaLd0n, any chance to update OpenCore file from the link above to version .4 or .5? .3 seems to be older than I would have expected.
Post by MaLd0n » 07 Oct 2019, 22:26
hbp, just read manual and update, need check changes in new version
sheep
Post by sheep » 10 Oct 2019, 15:02
Boa tarde, que hack ein, eu vou montar um aqui similar hoje, com uma placa Asus Prime z390-p e i9 9900kf com rx 580, vou precisar fazer muitas modificações para o DSDT ou so usar tudo igual ao q esta aqui no post ?
Post by MaLd0n » 10 Oct 2019, 15:04
sheep, dsdt sempre precisa, mas essa placa tem thunderbolt etc, use o outro tutorial
gabriel_rinaldi
Donator
Donator
CPU: Intel 9900K
Motherboard: Z390 Designare
GPU: NITRO+ RX 590 8GB
Post by gabriel_rinaldi » 19 Oct 2019, 18:17
MaLd0n I have a very similar setup, with a few differences:
- I have an NVIDIA card (2080 Ti) on slot 1 (I have a dual boot with Windows)
- I have a Radeon Nitro 580 on slot 2
- I have a PCI card with an original MacBook wifi/Bluetooth card for unlocking with the Apple Watch
- Running Catalina
Is it safe to use your EFI folder including the DSDT patches? Is it ok to have the NVIDIA card (It is not working on Mac, but I don't know if it causes problems)?
Also, why are you using UBBInjectAll instead of creating the patch?
Post by MaLd0n » 19 Oct 2019, 18:45
gabriel_rinaldi, need disable ur nvidia via dsdt for use only ur amd card under macos
Added in 56 seconds:
gabriel_rinaldi, about usbinjectall, if for all users, u can use hackintool for create a simple injector
gabriel_rinaldi
Donator
Donator
CPU: Intel 9900K
Post by gabriel_rinaldi » 20 Oct 2019, 06:43
19 Oct 2019, 18:46
MaLd0n How can I disable it? I am always scared of playing with the DSDT patches. I know my card is on PciRoot(0x0)/Pci(0x1,0x0)/Pci(0x0,0x0) (IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/PEG0@1/IOPP/GFX0@0).
I am using your EFI folder from this post. Here is the results of my "Run me":
Send me gabriels-imac.lan.zip
Thank you!
Post by MaLd0n » 20 Oct 2019, 15:16
gabriel_rinaldi,
gabriel_rinaldi
Donator
Donator
CPU: Intel 9900K
Post by gabriel_rinaldi » 20 Oct 2019, 17:01
MaLd0n thank you! Can I use this with your SSDTs?
Post by MaLd0n » 20 Oct 2019, 17:52
gabriel_rinaldi, use my efi folder, with ssdts, is a oem ssdt with little edits for fix acpi errors and others
Post by MaLd0n » 24 Oct 2019, 15:44
UPDATE FIRST POST
EFI FOLDER
DEDECO
CPU: i9900k
Motherboard: Z390 DESIGNARE
GPU: RX590
Post by DEDECO » 28 Oct 2019, 13:16
Bom dia, segui o tutorial que tem aqui no site, e na pós instalação usei a pasta EFI que disponibilizou nesse post. Não consigo montar meu hd externo thunderbolt. A bios está configurada como mandou também. Envio o send me para que se puder possa me ajudar com o DSDT e essa questão do thunderbolt (estou usando um adaptador thunderbolt Original da Apple, comprado no site para conectar no meu HD thunderbolt 2). Obrigado
Z4g0r
CPU: Intel Core I9
Motherboard: Gigabyte Z390 DESIGNARE
GPU: Radeon Rx Vega 56 8 GB
Post by Z4g0r » 30 Oct 2019, 14:14
after update to 10.15.1 doesnt work
Post by MaLd0n » 30 Oct 2019, 16:02
DEDECO,
Z4g0r, use last weg version
WhateverGreen.kext.zip
DEDECO
CPU: i9900k
GPU: RX590
Post by DEDECO » 30 Oct 2019, 17:37
MaLd0n, Obrigado. Ainda continuo sem conseguir montar meu HD TB2. Uso o adaptador tb3 para tb2 da apple. Segue os prints. Tem como resolver isso? Uso a BIOS F7 e a configuração que recomendou, vi no site que tem uma nova versão F8, isso resolveria o problema? Vi num forum que tem que deixar Thunderbolt(TM) Enumeration/Legacy, mas na bios não tem essa opção.
Post by MaLd0n » 30 Oct 2019, 18:06
DEDECO, creio que não
teem de ver sobre esse adaptador
Z4g0r
CPU: Intel Core I9
Post by Z4g0r » 30 Oct 2019, 19:22
30 Oct 2019, 16:02
DEDECO, DSDT.aml.zip
Great MaLd0n, it works now,i read that the problem was born for adding ATI gpu that disable a hdmi port. I boot with the HigSierra Backup and made changes to EFI. I was in trouble and had becoming to install mojave too :D ... My brain is lost, now i'm very old and not fresh like you. With Apple from 1981 (Apple II, ///, Lisa (Clascal u remember? ;) ) ... Greetings, i no have paypal, but if you have sometings like a card ...
Post by MaLd0n » 30 Oct 2019, 20:19
Z4g0r, :mrgreen: :meeting
Return to “Olarila Hackintosh Machines”
