AICPMPatch
Re: AICPMPatch
Postby iddpioneer » 12 Jul 2012, 21:33
Então Cassio, fui na pasta que vc me passou: e vi que tem um plist para cada mac, no meu caso uso o MacBookPro8_2, anexei ele p/ vc dar uma olhada, pois nao sei o que fazer nele.
coloquei no dropbox, veja: http://dl.dropbox.com/u/50415121/MacBookPro8_2.plist
i7RAM: 8192MBSSD Samsung 850 EVO M.2 500GB
iddpioneer
CPU: i7
Motherboard: Notebook Sony
GPU: NVidia / Intel
Re: AICPMPatch
Postby Cassio » 13 Jul 2012, 14:57
Eu também não sei o que modificar, a sugestão é testar outro plist ou outro SMBIOS. Talvez comparando os resultados a gente descubra o que precisa ser editado.
Cassio
Senior
Re: AICPMPatch
Postby iddpioneer » 13 Jul 2012, 20:04
Ae Cassio, resolvi o problema, temporariamente, apaguei a ACPI_SMC_PlatformPlugin.kext e pronto, o sistema ja sobe sem a nullcpu... vou deixar assim enquanto descubro o que fazer...
valeu pela dica da kext.
iddpioneer
CPU: i7
GPU: NVidia / Intel
Re: AICPMPatch
Postby osxfr33k » 15 Jul 2012, 02:47
Jahworks wrote:AICPMPatch funcionando no i7 2670QM G74SX. Apaguei a Null, rodei o patch e desabilitei no chameleon wizard: Generate P-states e drop SSDT. Valeu por mais uma Cássio.
Since we have the same Laptop I thought I might ask. Have you installed Mountain Lion 10.8 Golden Preview yet or will you?
I am trying to figure out what I will need from 10.7.3 to 10.8 Golden?
I have been reading that I have to insert a modified ssdt link on this thread somewhere then I have to DropSSDT=yes and Enable C/P state=no in the CABP? I wonder though if cstate enabled=yes should stay yes and not no? will the ssdt fix also work for cstate?
I read that fermi for the Nvidia gtx 2,3,4,5x now works OOT have to see. No editing at all for OpenCL support:
http://www.insanelymac.com/forum/index. ... pic=275993
WHich FakeSMC and plugs are we using for 10.8 Golden? Is there a link for them?
Will the speedstep patch work on 10.8 golden?
How difficult or time consuming will editing the ssdt be? My DSDT was prepared by Mald0n and has been working from 10.6x all the way up to 10.7.3.
Edited:
A lot of my characters in this post are turned around backwards? I don't know how to fix that?
Now everything is ok again. Must be this Google Chrome Portuguese to English conversation. I hope you can see it like me now?
osxfr33k
Re: AICPMPatch
Postby iddpioneer » 19 Jul 2012, 18:25
I think the problem is with the FakeSMC some key might be missing for the new ML.
iddpioneer
CPU: i7
GPU: NVidia / Intel
Re: AICPMPatch
Postby iddpioneer » 19 Jul 2012, 19:54
Ae Cassio e pessoal, consegui eliminar o problema totalmente aqui e com as kexts originais.
1o Veja o Conteúdo de: IOPlatformPluginFamily.kext > Contents > Plugins
dai veja o conteúdo de: ACPI_SMC_PlatformPlugin.Kexts > Contents Resources
Dai Edite o plist correspondente ao smbios que você está usando, exemplo:
MacBookPro8_2.plist
dentro do arquivo procure por esse bloco de texto:
Code: Select all
      <key>FanMax</key>
      <array>
         <integer>6200</integer>
      </array>
      <key>FanThrottledRPM</key>
      <integer>3500</integer>
E apague todo o bloco.
OBS: Tenha em mente que os RPMs dependendo do seu caso podem estar diferentes, e mesmo assim, vc deve apagar todo o bloco.
E pronto! Tenha um Feliz iHack ! Com gerenciamento de energia funcionando como nativo.
For those who read in english:
First look at the content of: IOPlatformPluginFamily.kext> Contents> Plugins
view the contents of : ACPI_SMC_PlatformPlugin.Kexts> Contents Resources
Then edit the plist corresponding to the SMBIOS are you using, for example:
MacBookPro8_2.plist
within the file look for this block of text:
Code: Select all
      <key>FanMax</key>
      <array>
      </array>
And delete the entire block.
NOTE: Keep in mind that depending on the RPMs of your case may be different, and yet, you must erase the entire block.
And voila! Have a Happy iHack! With power management working as native!
iddpioneer
CPU: i7
GPU: NVidia / Intel
Re: AICPMPatch
Postby osxfr33k » 20 Jul 2012, 05:55
Still need a ssdt I tried it got kernel panic without ssdt!!
This did however remove the kernel smc message.
ACPI_SMC_PlatformPlugin::initFanThrottleControl - waiting for AppleSMC
osxfr33k
Re: AICPMPatch
Postby mendietinha » 30 Jul 2012, 10:19
as kexts estão subindo, dsdt com patch pras kexts problematicas, patch na intelcpum, mas continua o kp sem a null.
mountain lion para usb baixado daqui, specs na assinatura. alguma idéia pq continua o kp?
obrigado.
mendietinha
Staff
CPU: i5 750
Motherboard: Intel
GPU: GTX760
Re: AICPMPatch
Postby Cassio » 30 Jul 2012, 16:24
Poste uma foto da tela. Veja se não é o mesmo caso do iddpioneer viewtopic.php?f=9&t=1003&start=50#p13311
Cassio
Senior
Re: AICPMPatch
Postby mendietinha » 30 Jul 2012, 17:15
segue a foto
mendietinha
Staff
CPU: i5 750
Motherboard: Intel
GPU: GTX760
PreviousNext
Return to Downloads
