AICPMPatch
Cassio
Re: AICPMPatch
Post by Cassio » 08 Aug 2012, 13:29
Se precisar, pode ser usado.
Sei que vários Sandy Bridge precisam. Ivy Bridge ainda não testei.
nexus76
Re: AICPMPatch
Post by nexus76 » 14 Aug 2012, 10:33
Cassio wrote:Script para modificar a AppleIntelCPUPowerManagement para sistemas Sandy Bridge.
Download: [Local Link Removed for Guests]
Escrito por el coniglio.
Baseado em
Agradecimentos a flAked e dmazar.
Como usar:
No terminal
cd ~/Downloads/AICPMPatch
Procurar wrmsr (sem modificar)
perl AICPMPatch.pl /System/Library/Extensions/AppleIntelCPUPowerManagement.kext/Contents/MacOS/AppleIntelCPUPowerManagement
Modificar
sudo perl AICPMPatch.pl /System/Library/Extensions/AppleIntelCPUPowerManagement.kext/Contents/MacOS/AppleIntelCPUPowerManagement --patch
Como resolver o "P-State Stepper Error 18" [Local Link Removed for Guests]
Hey, your tool is great but what about patching DSDT directly instead of the kext? After an update the settings would be kept.
Is the souce code public?
best regards ; )
Cassio
Re: AICPMPatch
Post by Cassio » 14 Aug 2012, 13:31
nexus76 wrote: Hey, your tool is great but what about patching DSDT directly instead of the kext? After an update the settings would be kept.
This can't be patched in DSDT. You can [External Link Removed for Guests] though.
It's a perl script, not a binary.
jcgeraldi
Re: AICPMPatch
Post by jcgeraldi » 24 Sep 2012, 14:58
Após aplicar o patch, e C e P states = No e criar o ssdt.aml como descrito no fórum tenho esse KP:
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Re: AICPMPatch
Post by artur-pt » 24 Sep 2012, 16:39
aco k teu problema n é aicpm
mas sim na appleintelacpiplatform
ve isto aki
tem gente k tem de usar uma kext modificada
plsh2me
CPU: Intel i5 M460 @2.53GHz
Motherboard: Dell Inspiron N5010
GPU: ATI Mobility Radeon HD 550v
Re: AICPMPatch
Post by plsh2me » 11 Oct 2012, 08:47
On OS X 10.8.2 shows -
What's wrong with this?
System: Dell Inspiron 15R (N5010)
ATI Mobility Radeon HD 550v; IDT 92HD81B1X5;
Dell 365 Bluetooth; Ethernet RTL 8169; Atheros AR9285
OS's: Windows 8 + Mac OS X Mountain Lion 10.8.3(12D78)+Ubuntu 12.10
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Re: AICPMPatch
Post by artur-pt » 11 Oct 2012, 09:39
the command line is wrong
see with attention
must read the post
plsh2me
Re: AICPMPatch
Post by plsh2me » 11 Oct 2012, 16:48
Yes
Thank you.....
Patch done!!!
Restarted without KP :D
plsh2me
Re: AICPMPatch
Post by plsh2me » 11 Oct 2012, 17:14
Hi,
Can I remove NullCPUPowerManagement.kext now?
plsh2me
Re: AICPMPatch
Post by plsh2me » 11 Oct 2012, 18:09
plsh2me wrote:Hi,
Update: Removed Nullcpupowermanagement kext & evoreboot.kext :D
But CPU temperature is too high 60+ !!!!!
What can I do?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Re: AICPMPatch
Post by artur-pt » 11 Oct 2012, 18:20
if u dsdt is well edited
that is not a problem
u need the aicpm patch and u dsdt well edited to have native power management
plsh2me
Re: AICPMPatch
Post by plsh2me » 11 Oct 2012, 19:05
artur-pt wrote:hello
I am using edited dsdt. also set generate P & C states.
booting with this, as I saw from log info -
FADT: Using custom DSDT!
Found ACPI CPU: P000
Found ACPI CPU: P001
Found ACPI CPU: P002
Found ACPI CPU: P003
SSDT with CPU C-States generated successfully
P-States: min 0x9, max 0x13
SSDT with CPU P-States generated successfully
RSDT: Added 2 SSDT table(s)
FADT: ACPI Restart Fix applied!
Added 2 SSDT table(s) into XSDT
Starting Darwin x86_64
Boot Args: boot-uuid=0B6F285E-7908-3C4F-9207-E5491999761D rd=*uuid
Any idea?
pcnewpinky
Re: AICPMPatch
Post by pcnewpinky » 07 Dec 2012, 21:14
Hi. look at this please ..
arch: x86_64
found wrmsr at 97cc
found wrmsr at a05e
found wrmsr at a0e9
found wrmsr at a136
found wrmsr at a266
found wrmsr at a580
found wrmsr at afd2
found wrmsr at b2c5
found wrmsr at 1165b
found wrmsr at 12a7a
found wrmsr at 13389
arch: x86_64
found wrmsr at 97cc, patched
found wrmsr at a05e, patched
found wrmsr at a0e9, patched
found wrmsr at a136, patched
found wrmsr at a266, patched
found wrmsr at a580, patched
found wrmsr at afd2, patched
found wrmsr at b2c5, patched
found wrmsr at 1165b, patched
found wrmsr at 12a7a, patched
found wrmsr at 13389, patched
and the result .. :cry: :roll:
System: i7-2630QM - ASUS N53SV - ML 10.8.2 GM
pernacabeluda
Re: AICPMPatch
Post by pernacabeluda » 07 Dec 2012, 22:40
Did you update kernelcache after patching?
Are you using custom SSDT for your CPU?
pcnewpinky
Re: AICPMPatch
Post by pcnewpinky » 07 Dec 2012, 22:57
pernacabeluda wrote:Did you update kernelcache after patching?
hei man! thans for ur notice ! ;)
Now i works perfect ! :D :D
SSDT.aml , i ignored it ! Now with that works
anerik70
Re: AICPMPatch
Post by anerik70 » 08 Jan 2013, 19:43
pcnewpinky wrote:Hi. look at this please ..
Hello I have an Asus N53sm 90% working ML 10.8.2 we can join to work on it
Asus N53SM - X5MS | Intel Core i7 2670QM | GT 630M |INTEL HD GRAPHICS 3000 |
TripleBoot: Ubuntu 12.04-Mountain Lion 10.8.2-Windows 8
RCOO
Geek
Geek
CPU: Intel Core I7 2630QM
Motherboard: ---
GPU: Intel HD3000 - GeForce GT540M
Re: AICPMPatch
Post by RCOO » 12 Feb 2013, 21:44
Depois de fazer patch ao kext e colocar o patch no DSDT (thanks artur_pt), estou a ter o seguinte kernel panic: [External Link Removed for Guests]
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Re: AICPMPatch
Post by artur-pt » 12 Feb 2013, 23:30
já tens ssdt ?
tá tudo no guia do powermanagement....
RCOO
Geek
Geek
Motherboard: ---
Re: AICPMPatch
Post by RCOO » 13 Feb 2013, 00:22
Tenho sim. Segue em anexo. Gerei o dsl e compilei para aml. Usei uma aplicação que aceitava dois argumentos: max TDP e max freq. No caso do meu processador, Intel i7 2630QM, era 45 e 2900.
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Re: AICPMPatch
Post by artur-pt » 13 Feb 2013, 10:18
tenta estes
i7 2630 QM SSDT's.zip
metes esses files em /Extra
DropSSDT=Yes
P e C-states=No
Return to “Discussão geral”
