AICPMPatch
midi_1996
CPU: i7-3520M
Motherboard: N/A (Sony Vaio SVS 2012)
GPU: IntelHD 4000 + Nvidia GT640MLE
Re: AICPMPatch
Post by midi_1996 » 02 Jan 2014, 21:14
Tried that, I can't get to sleep mode at all, AICPM is patched automatically but sleep isn't working, used SleepEnabler but got a KP.
Thanks anyway :D
If somebody knows anything, HELP :(
PimentelX86
Veteran
Veteran
CPU: i7 2600
Motherboard: IPMH61R1
GPU: GT 610
Re: AICPMPatch
Post by PimentelX86 » 02 Jan 2014, 23:26
Hello
Isn't necessary SleepEnabler...
Try run in terminal kextstat, see if kext AppleLPC is loaded
If not, apply the patch AppleLCP according your chipset in your DSDT
midi_1996
CPU: i7-3520M
Re: AICPMPatch
Post by midi_1996 » 03 Jan 2014, 21:51
AppleLPC is loaded and everything else
What now? :(
I made a topic on InsanelyMac to see my problem [External Link Removed for Guests]
Thanks for any help
m.gbt
Geek
Geek
CPU: i5-2467M
Motherboard: Intel HM65
GPU: Intel HD Graphics 3000
Re: AICPMPatch
Post by m.gbt » 08 Feb 2014, 05:09
Did you generate your SSDT using Pike's script?
You can try first with DropOemSSDT (you're dropping all tables with this option), later we can optimise and drop only what is needed.
If that's correct, check if your P-States are fine (maybe DPCIManager is the easiest way), you should have every state from 14 or 15 up to 36 (for your processor specifically). That will tell us your SSDT is good and loaded.
Have you patched your DSDT? Take a look on the patches for Ivy Bridge here: [Local Link Removed for Guests]
The EHCI influences on sleep and is one of the very few patches I manually apply to my DSDT (most of them I apply with Clover)
If all's correct, then you may try:
DSDT / SlpSmiAtWake
DSDT / SuspendOverride
Lastly... Attach here your Clover's config.plist if still not working.
Mavericks 10.9.2 Retail
When you ask for support, remember to tell the bootloader you use :)
midi_1996
CPU: i7-3520M
Re: AICPMPatch
Post by midi_1996 » 10 Feb 2014, 20:21
Well thanks for the respond, but I have stopped using OSX because I had a lot of problem w/ it and it takes my time during my studies, so I'll go back when holidays come (incha2allah) and I might see what I can do.
My DSDT is patched for AHDA (Realtek ALC275-audio layout=28? ) and for Intel HD4k (I use sometimes clover for that) and XHCI and EHCI (fixes, I don't see what they do but it doesn't seem to affect to sleep -either I have them or not- ) and for Battery (rehabman's repo of MaciASL's patches) for Sony Vaio S (I have SVS13A290X aka S13P ) and that's it :)
Thanks you all of the helping :)
JD7
CPU: i5-2500k
Motherboard: MS-7681
GPU: AMD 5770
Re: AICPMPatch
Post by JD7 » 12 Feb 2014, 08:56
:D - It works.
Thanks for the information and the perl script.
Nearly 100% working Hackintosh
Micky1979
Developer
Developer
Re: AICPMPatch
Post by Micky1979 » 06 Sep 2014, 12:51
Hi guys
to @RehabMan, @Philip Petev and @Oldnapalm,
this if seems a little stupid on my part, but I was reading here on InsanelyMac:[External Link Removed for Guests].....
Can I be included in the credits (or for a de-merit) for a little little little stupid thing? :D
the lipo version included in the new AICPMpatch, that originally was not included in the patch and then added by me, (but otool also i think, at least the one at insanelymac..and perhaps that's why the output is different from the known latest versions), are the same I've added to Pandora.app last year, and are not a new particular version, but are simply a compiled version in 10.6.8 with xCode 3.xx (or latest 4.x ??)....so both are old version, but working on all OSX version since SL.
This was necessary because calling lipo by the command line from Mavericks on, a message would appear asking to download that command(s) line, and this appen when Xcode is not installed on the new operating systems or even if them are included manually in /usr/bin, making any automation unusable... only this. Thank you
references:[External Link Removed for Guests] and [External Link Removed for Guests]
(I've also requested for a change in a PM to el coniglio but never answered)
Micky1979
PS (And please add the license for otool and lipo: APPLE PUBLIC SOURCE LICENSE
Version 2.0 - August 6, 2003 :idea: )
cidus
Re: AICPMPatch
Post by cidus » 09 Mar 2015, 00:47
Finally got my Hack working without NullCpu with this patch! Thanks! My MB is a Intel DP55WB, booting Yosemite with chameleon.
Question: Will a software update overwrite IntelCpuPower kext? Do we need to patch it again?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Re: AICPMPatch
Post by artur-pt » 09 Mar 2015, 09:45
cidus wrote:Finally got my Hack working without NullCpu with this patch! Thanks! My MB is a Intel DP55WB, booting Yosemite with chameleon.
if is a system update .. it will be overwrite the kext..
Hazemjaki
AICPMPatch
Post by Hazemjaki » 16 Jun 2019, 00:39
Hallo,
Is this Patch needed for Mojave i7-2600k and patched DSDT and SSDT?
thanks in advance
AICPMPatch
Post by MaLd0n » 16 Jun 2019, 01:09
Hazemjaki, for ur processor just use a ssdt generated with piker-alpha script
-Donated? Send me one PM-
Hazemjaki
AICPMPatch
Post by Hazemjaki » 20 Jun 2019, 19:08
16 Jun 2019, 01:09
Thanks man
Return to “Discussão geral”
