Post by MaLd0n » 10 Nov 2019, 00:09
garviniciu, não
vc pode tentar esses drivers
vaguinho
CPU: intel core 2 duo 3.00ghz
Motherboard: gigabyte GA-G41MT-S2
GPU: NIVIDIA 9800 GT 256 BITS 1 GB
Post by vaguinho » 10 Nov 2019, 02:32
09 Nov 2019, 22:49
vaguinho, mavericks não precisa de nada extra, só setar ahci no bios, se o chipset não suporta ahci deve funcionar em ide mode, não sei o que está causando isso
de uma olhada na minha bios
Added in 1 minute 10 seconds:
se tiver alguma coisa errada me avise
e agradeço desde ja maldon :frantics
lorenzolamasse
CPU: Intel Core i7 8700K
Motherboard: Gigabyte Z390 UD (BIOS F7)
GPU: Nvidia Geforce GT730 2GB
Post by lorenzolamasse » 10 Nov 2019, 02:37
Dear Maldon, that's why I've done first (upgrading Clover), after searching on the forum for previous occurrences of the problem, but to no avail.
Not sure if I should try and change Cover options though (and which ones), or find out offending/missing kexts :/
Lorenzo
vaguinho
Post by vaguinho » 10 Nov 2019, 03:18
09 Nov 2019, 22:49
agradeço desde ja maldon se tiver alguma coisa para mudar me avise
Post by MaLd0n » 10 Nov 2019, 05:32
vaguinho, essa opção efi tem o que?
vaguinho
Post by vaguinho » 10 Nov 2019, 05:52
10 Nov 2019, 05:32
efi
not-efi
auto
sao as 3
Post by MaLd0n » 10 Nov 2019, 06:16
vaguinho, faz um teste
lorenzolamasse
Post by lorenzolamasse » 10 Nov 2019, 12:03
Now I've updated BIOS to latest version, no change alas, nothing happens forever latest message about AppleGraphicsDevicePolicy exiting with code 1 (just a warning though)... Any link to an issue with Iris graphics driver ?
10 Nov 2019, 02:37
Lorenzo
vaguinho
Post by vaguinho » 10 Nov 2019, 13:14
10 Nov 2019, 06:16
com cada uma non-efi > efi > auto
instalar dinivo vou tentar
vaguinho
Post by vaguinho » 10 Nov 2019, 14:26
10 Nov 2019, 06:16
maldon ja fiz um teste mas o hd nao aparece ainda
oque fazere ?tem mais alguma coisa ou desisto?
Post by MaLd0n » 10 Nov 2019, 14:42
lorenzolamasse, use a catalina Olarila, i'll check what happens with Mojave image
Added in 49 seconds:
vaguinho, não faço idéia
vc pode tentar um injector
AHCIPortInjector.kext.zip
vaguinho
Post by vaguinho » 11 Nov 2019, 15:10
10 Nov 2019, 14:43
Maldon e como fazer ? Ponho essa kets na pasta do efi e como colocar pq no windows nao abre o pendrive para achar a pasta tem algum programa?
lorenzolamasse
Post by lorenzolamasse » 11 Nov 2019, 19:12
Dear Maldon,
No better luck with Catalina, I managed to finish install even though sometimes it does not boot at all, but at login, as soon I type in my password and press enter the system reboots as if I had askded for shutdown, this is weird indeed...
10 Nov 2019, 14:43
Post by MaLd0n » 11 Nov 2019, 20:05
lorenzolamasse, the problem is not normal, is a very strange problem
lmgentil
CPU: i7 8700
Motherboard: Z390 M Gigabyte Gaming
GPU: RX 580 8GB
Post by lmgentil » 12 Nov 2019, 04:43
Hi, i am trying install Mac OS high Sierra, olarila image, but I had this problem in first boot!
I7 8700
Z390 gigabyte gaming
Nvidia 1060 gtx - I choose high sierra because this..
Anyone can help me? Please
nithinxjohnson
CPU: Intel
Motherboard: G31
GPU: Nvidia GT 710
Post by nithinxjohnson » 12 Nov 2019, 07:02
@MaLd0n
I have an old ATI Raedon 5450 1gb graphics card lying around. So I swapped it with my old nvidia card and installed macos mojave. But in this Mac I can see that only 5MB. I have selected inject ATI in config.plist and still no luck. Is there any workaround to fix it.?
Shine18
CPU: AMD Ryzen 5 3600
Motherboard: Asus Rog Strix X470-F Gaming
GPU: Gigabyte RTX 2060 PRO 6GB
Post by Shine18 » 12 Nov 2019, 10:24
28 Jan 2019, 13:03
Select Boot MacOS Install from Olarila Image
Hi,
I'm getting error when booting from flash drive:
AMF: Only 168/256 slide values are usable
Valid slides: 88-255
+++++++++++++++++++++++++++++++++++++++++++++_
I also tried following amd vanilla tutorial, but it also leads me to this error
Any help would be appreciated!
fabipm
CPU: i9
Motherboard: Asus Z390
GPU: 2080
Post by fabipm » 12 Nov 2019, 14:10
Bom dia,
Estou tentando a dias e ainda não consegui.
Segui certinho todos os passos até o boot com o pen drive. Ela chega a dar o boot, mas para na tela preta.
Alguem poderia me ajudar, por favor?
Já li milhares de coisas aqui no forum, mas nada deu certo.
Obrigada
Post by MaLd0n » 12 Nov 2019, 15:41
Shine18, try with opencore
Added in 31 seconds:
fabipm, nvidia 2080? se for não funciona em nenhum sistema
nithinxjohnson
CPU: Intel
Motherboard: G31
GPU: Nvidia GT 710
Post by nithinxjohnson » 12 Nov 2019, 16:07
@MaLd0n
I planning to install macos high sierra 10.13.6 in an old intel dh55Tc motherboard with i3 530 and 4gb ram. I searched about the board the audio codec is ALC 888S. My doubt is what type of dsdt patches I should use Hdas to Hdef or Azal to Hdef...or some other.. Thanks for the answers for the previous queries...and hoping for more solutions from you... :D
