Post by MaLd0n » 06 Nov 2019, 13:44
djuby, check about sata, in some cases this old notebooks have sata mode ide or raid, use raid and SATA-unsupported.kext
jamshad
CPU: i5
Motherboard: intel
GPU: 620u
Post by jamshad » 06 Nov 2019, 15:10
Yesterday i bought new laptop HP Pavilion x360 - 15-cr0088cl laptop which having 1 TB 5400 rpm SATA+16gb ssd optane. I already had old hp pavilion with hackintosh istalled and it is having 2tb ssd with multi boot windows 10 and catalina.I replaced new hdd with this ssd. i am able to boot windows,But mac is getting kernel panic that i expected because its using patched dsdt of my old laptop. Then i made a new bootable usb of catalina.But when i tried to boot from usb i am able to reach installation screen. But no hard disk is not showing in disk utilities. i selected show all drives still it's not showing. I am in a big trouble. i don't know what to do. the only reason i bought this laptop is to learn ios development. Please help me to fix this isssue. I searched AHCI Settings in bios but couldn't find it. below is detailed information which i took from cpuz using windows 10.
Drive 0
Name Samsung SSD 860 EVO 2TB
Revision RVT02B6Q
Serial S3YUNB0KB05085Z
Capacity 1863.0 GB
Type Fixed, SSD
Bus Type RAID (8)
Features SMART, TRIM
Volume c:\, 249.1 GBytes (38.4 percent available)
Volume d:\, 1374.4 GBytes (11.6 percent available).
please help me to solve this issue.
Post by MaLd0n » 06 Nov 2019, 15:17
jamshad, u need poost a kp photo
djuby
Donator
Donator
CPU: Intel Core i7 – 5600U @ 2.6 GH
Motherboard: Dell Latitude E5450
GPU: Intel HD5500
Post by djuby » 06 Nov 2019, 15:29
06 Nov 2019, 13:44
SATA is in AHCI mode.
jamshad
CPU: i5
Motherboard: intel
GPU: 620u
Post by jamshad » 06 Nov 2019, 15:40
06 Nov 2019, 15:17
No kernel panic, my ssd is not showing in disk utility of Mac os Catalina set up screen.
Post by MaLd0n » 06 Nov 2019, 15:43
djuby, idk what happens, is a strange error
jamshad, u can try with SATA-unsupported.kext for raid mode
jamshad
CPU: i5
Motherboard: intel
GPU: 620u
Post by jamshad » 06 Nov 2019, 16:25
I don't have Mac. How to mount efi folder of USB using windows 10. I just need to copy the kexts to others directory right?
Post by MaLd0n » 06 Nov 2019, 17:13
jamshad, check in google about it
djuby
Donator
Donator
GPU: Intel HD5500
Post by djuby » 06 Nov 2019, 17:39
06 Nov 2019, 15:43
What do you mean?
Post by MaLd0n » 06 Nov 2019, 19:04
djuby, i don't know what happens
bernardo415
CPU: Intel core i3
Motherboard: Asus X540la
GPU: Intel HD 5500
Post by bernardo415 » 07 Nov 2019, 03:15
good friends.
I am new to this community and I have installed macos on my asus X540LA on several occasions, but for the confidence of always doing clean installations I deleted the entire SSD and now I cannot install macos in the X540la, I will show you the errors I get when I believe The USB as described by Apple on its official website and with the image here I can not pass formatting of the SSD and the laptop restarts. For no apparent reason, I have the configuration in bios and hardware exactly the same as when I was mojave macos.
Post by MaLd0n » 07 Nov 2019, 03:32
bernardo415, burn Olarila image and change things if u need
frozenade
CPU: i7
Motherboard: Intel
GPU: Intel
Post by frozenade » 07 Nov 2019, 10:45
The newest clover is Release v2.5k-5098 - [External Link Removed for Guests]\
and the customize items are not the same as guide. Please help.
Sampath007
CPU: i7-8550u
Motherboard: Acer Nitro 515-31
GPU: UHD 620/NV MX150
Post by Sampath007 » 07 Nov 2019, 12:37
frozenade few things only changed see correct name then choose correctly :work: if u have uefi boot just replace usb efi then reboot no need install bootloader
anchore
CPU: i7-7700HQ
Motherboard: unknown
GPU: GTX-1050
Post by anchore » 07 Nov 2019, 13:30
step by step,olarila mojave upgrade to olarila catalina,no config2.plist there :help
frozenade
CPU: i7
Motherboard: Intel
GPU: Intel
Post by frozenade » 08 Nov 2019, 02:40
07 Nov 2019, 12:37
few things only changed see correct name then choose correctly if u have uefi boot just replace usb efi then reboot no need install bootloader
I can sort all items except HFSPlus and AppleImageLoader, I just can't find them.
Then after running RunMe.app I got these infinity message:
Increased delay x2 for IOREG dump. This will take a while...(33 sec)
IOREG dump failed. Retrying
dhanang95
CPU: I5-6500
Motherboard: HM-110
GPU: Galax 1060
Post by dhanang95 » 08 Nov 2019, 03:43
I cant boot to GUI Installer, I've choose config2.plist on my HP 840 G2.
Where I can find Clover or EFI Folder? I have burn Olarila RAW image to USB FD.
Post by MaLd0n » 08 Nov 2019, 03:59
dhanang95, burn image and use boot key for select ur usb stick
dhanang95
CPU: I5-6500
Motherboard: HM-110
GPU: Galax 1060
Post by dhanang95 » 08 Nov 2019, 04:13
MaLd0n, I'm sorry. I actually got kernel panic about AGPM things. My installer is stuck at kernel panic. I cant find config.plist in the directory
Tazorro
CPU: I3 2130
Motherboard: P8H61-M LE/USB3
GPU: GT 8800
Post by Tazorro » 08 Nov 2019, 11:21
Hi everyone, I installed Mojave perfectly worked with formatting in apfs, as I already had the intention to upgrade to Catalina. At the end of the download when I select the disk it says that it is not possible to install on this system. Tips?
