hoangtuau
CPU: i5 9400
Motherboard: gigabyte b360m aorus pro
GPU: gtx 1050
Post by hoangtuau » 03 Oct 2019, 02:26
I'm unkown use hackintool for create a video patch, you could tell me detail?
rositaott
Donator
Donator
CPU: Intel(R) Core(TM) i3-8100
Motherboard: Asus Prime H310M-D R2.0
GPU: Intel HD 630 BuiltIn
Post by rositaott » 04 Oct 2019, 00:07
Hi MaLd0n, tried to Install Catalina on my previous build but can't pass through as shown from the image, can you help me again?
By the way I'm trying to install it on my notebook, CPU i3-5005U, intel HD 5500 Graphics.
EDIT: I got installed with proper config :whistle
Can I use the same DSDT file that you patched from High Sierra? :guitar
NoteBook | Acer E5-473G | i5-5200U | IntelHD5500
corebits99
CPU: i5
Motherboard: OEM
GPU: Intel HD
Post by corebits99 » 04 Oct 2019, 11:50
Anyone knows how to get this working on Yoga 500 14ibd??
Post by MaLd0n » 04 Oct 2019, 14:09
rositaott, yes
corebits99, just install
rositaott
Donator
Donator
Post by rositaott » 04 Oct 2019, 23:55
04 Oct 2019, 14:09
rositaott, yes
:cap
EDIT:
Hi MaLd0n, sending you my send_me file, can you take a look, because after copying on ACPI/Patch, still nothing on my PCI Devices, thanks :guitar
Post by MaLd0n » 05 Oct 2019, 04:26
rositaott,
iolarila
CPU: I9-9900k
Motherboard: ASUS PRIME Z390-P
GPU: Sapphire Radeon VII
Post by iolarila » 05 Oct 2019, 11:31
Ok, so I tried to install Mojave with olarila image from link in first page. I'm on a ASUS PRIME-Z390-P. I have windows 10 already installed on a Corsair MP510 M.2 NVME and popped in another one for my mojave install. The latter one (unformatted) is recognized in bios but obviously not in windows 10.
Now, when i boot from the olarila usb disk, I get the welcome screen and some verbose output, but it gets stuck a few lines after :
AppleNVME Assert failed
What is this error and how can I overcome it ?
Post by MaLd0n » 05 Oct 2019, 14:34
iolarila, is a common problem in z390 chipset, u need a full dsdt patched
iolarila
CPU: I9-9900k
Post by iolarila » 05 Oct 2019, 14:50
ok this sounds like Chinese to me. And how must I proceed to do that ?
Post by MaLd0n » 05 Oct 2019, 15:03
iolarila, Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here!
iolarila
CPU: I9-9900k
Post by iolarila » 05 Oct 2019, 15:42
Thanks for the feedback, but you're dealing with a total noob here !
So I booted on olarila usb with F8 key, but then what ? When I press F4 on first screen arriving, nothing happens. Don't find anything in boot options. When mounting usb on regular Mac, don't find Clover/Acpi/origin...
Could you please make a step-by-step description ? Sorry and thanks !
Post by MaLd0n » 05 Oct 2019, 16:04
iolarila, in clover/Olarila boot screen, press f4, go to efi from ur usb stick, clover/acpi/patched
luizorlandi
CPU: Samsung Ultrabook S5
Motherboard: Samsung NP530U3C-K2BR
GPU: Intel HD 3000
Post by luizorlandi » 06 Oct 2019, 19:09
Galera, boa tarde;
Consegui instalar o High Sierra no meu i5 6400 com placa Gigabyte H110M-DDR3-CF, porém estou tendo problemas para desligar e reiniciar o computador, ele trava e sou obrigado sempre a forçar no botão de energia. Rodei um SSDT Automator, coloquei o arquivo gerado em patched, depois no Clover habilitei o DROP_OEM, e no próximo boot a máquina apresentou um sinal de proibido, reiniciei e removi a SSDT, será que estou fazendo algo errado ??
Gigabyte GA-H110M-H DDR3
i5 6400
Memória Corsair Vegeance 1600mhz.
Obrigado.
i5 6400 / Mobo Gigabyte GA-H110M-H DDR3 / 16GB DDR3 Corsair Vegeance @ 1600mhz / HD Graphics 530 / SSD 240GB / HDD 2TB
Post by MaLd0n » 06 Oct 2019, 20:49
luizorlandi, vc não precisa de ssdt, somente um dsdt full patched
luizorlandi
GPU: Intel HD 3000
Post by luizorlandi » 07 Oct 2019, 00:41
vou ver o que fazer com relação à DSDT, outra questão éa atualização do sistema, está indicando a sua conta lá Mald0n porém, mesmo colocando a minha fala que a atualização não está mais disponível, ou foi comprada por uma conta diferente (atualização do High Sierra), de outros ítens, com a minha conta dá certinho.
Post by MaLd0n » 07 Oct 2019, 00:58
luizorlandi, deve ser algum app da appstore que eu fiz o download, só vai funcionar pra mim
luizorlandi
GPU: Intel HD 3000
Post by luizorlandi » 07 Oct 2019, 01:15
São as atualizações de sistema. essas que não estou conseguindo baixar.
Post by MaLd0n » 07 Oct 2019, 01:38
luizorlandi, vc deve ter algum app baixado em meu nome na pasta applications, algumas imagens olarila eu esqueci de remover
atualizações do sistema não tem como
luizorlandi
GPU: Intel HD 3000
Post by luizorlandi » 07 Oct 2019, 01:49
MaLd0n, Era um programa chamado OpenGL Viewer, já removi e deu tudo certo, consegue me ajudar com a DSDT ??
Added in 6 minutes 18 seconds:
Estou anexando a original. Se puder, for favor me ajude nesse detalhe, a máquina está ótima mesmo sem placa de vídeo. Uma GTX680 no High Sierra é possível de usar ??
Post by MaLd0n » 07 Oct 2019, 02:20
luizorlandi,
