Harshkumar07
CPU: Intel Core i5 4690
Motherboard: Gigabyte B85M Gaming 3
GPU: Nvidia GT 730 2GB GDDR5
Post by Harshkumar07 » 29 Sep 2019, 17:03
I need to disable Intel HD for installation of what? And if I have to enable Intel HD, then what is the point in getting the GT 730 ?
Post by MaLd0n » 29 Sep 2019, 19:08
Harshkumar07, just disable at system installation, after it just enable again and configure
Harshkumar07
Post by Harshkumar07 » 29 Sep 2019, 19:23
Do I have to reinstall mojave now? See, my main query is, how do I know if apps like Final Cut Pro, videoproc....etc are using my GT 730 for hardware acceleration?
binhnv
CPU: I5 9400F
Motherboard: Asus ROG Strix B360-G
GPU: Asus ROG Strix RX570 4GB
Post by binhnv » 30 Sep 2019, 02:13
29 Sep 2019, 13:56
Added in 2 minutes 54 seconds:
binhnv,
Thank you for nice supported, now i can install MacOS successfully
But now after Creating SSDT Using Pike's Script, when run Intel Power Gadget app, my PC crash and turn off immediately. Do you have any ideal for this problem?
Other information, my geekbend4 score as same as target processor, so I think may be ssdt is correct.
Post by MaLd0n » 30 Sep 2019, 02:50
binhnv, u dont need ssdt, my dsdt have a plugin type=1
binhnv
CPU: I5 9400F
Post by binhnv » 30 Sep 2019, 03:00
30 Sep 2019, 02:50
This mean in Mac I just use only your DSDT? right
Post by MaLd0n » 30 Sep 2019, 03:20
binhnv, yes
gregorio1970
CPU: i5 9600k
Motherboard: aorus z 370 gaming 7
GPU: radeon rx 590
Post by gregorio1970 » 30 Sep 2019, 16:31
Hi there
i have a problem with my z370 aorus gaming 7 when i try install olarilla mojave its stuck every time after VoodooPS2Mouse: Version 1.9.2 strting on OS X Darvin 18. 2
Do you have any idea why and how can i fix this problem?
Thanks for help
Post by MaLd0n » 30 Sep 2019, 19:12
gregorio1970, u need a full dsdt patch
Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here!
Raqha
CPU: Dell Inspiron 15 7500
Motherboard: Asus Zenrock z370
GPU: GT750
Post by Raqha » 01 Oct 2019, 09:31
Hi again MaLd0n, I got to install the Mojave in my laptop, followed all the steps of the tutorial, but I'm still not able to boot the Laptop by it's own.
I think the problem is the clover, the first time I installed it, I installed it with the default options, the legacy mode.
I erased all the HDD and reinstalled Mac, but I think the Clover installation didn't get erased as the clover booting options remained in the bios.
I'm not sure if this is the problem to the no booting or is something else. I've already patched the DSDT you send me but I attach you once more the runme file.
Send me Inakis-MacBook-Pro.zip
Im looking forward to get the laptop working and I'll donate for sure if I get to it.
Thanks for your hard work.
qola
CPU: I5 4200U @ 1.6Ghz
Motherboard: Lenovo x240 Thinkpad
GPU: HD4400
Post by qola » 01 Oct 2019, 14:21
Hi MaLd0n! I’m installing Mojave 10.14.6 on a Lenovo x240 Thinkpad with HD4400 Haswell
Tried every memfix available and memory mapping but always ends up in randomseed with plus signs. I tried downgrading the bios and tried your olarila image(installer) with config2 but still always end the same.
Post by MaLd0n » 01 Oct 2019, 14:25
Raqha, first boot without dsdt, only with clover folder, if work put dsdt
post one photo here at screen problem
Raqha
GPU: GT750
Post by Raqha » 01 Oct 2019, 15:23
MaLd0n, doesnt work, just black screen with the phrase not booteable device. F1 for retry and F2 to enter setup.
Post by MaLd0n » 01 Oct 2019, 16:11
Raqha, install clover with correct config
Raqha
GPU: GT750
Post by Raqha » 01 Oct 2019, 18:30
01 Oct 2019, 16:11
I've instaled and reinstaled it like 5-6 times already.
pdevonie
Geek
Geek
CPU: i7 8700
Motherboard: B360M
GPU: GT 710 2GB
Post by pdevonie » 01 Oct 2019, 20:37
Estou com um probleminha, será que consegue me ajudar? Estou com i7 7700k, 1080 TI, na BIOS está definida com overclocking no mais alto, quando deixo ele no mais baixo possível, ele simplesmente não entra no Mac, não entendo pq com o mais ele entra e o mais baixo não.
qola
GPU: HD4400
Post by qola » 02 Oct 2019, 00:17
Hi MaLd0n, any help with the previous post I posted regarding with the end randomseed?
Post by MaLd0n » 02 Oct 2019, 00:44
qola, no idea, need test other uefi driver
hoangtuau
CPU: i5 9400
Motherboard: gigabyte b360m aorus pro
GPU: gtx 1050
Post by hoangtuau » 02 Oct 2019, 16:47
Please help me,
My computer:
Main: GA B360 b360m aorus pro
CPU: i5 9400
RAM: 16GB
Not have VGA
I'm use olarila image for setup hackintosk, but my have a black screen when setup loaded
Post by MaLd0n » 02 Oct 2019, 18:47
hoangtuau, use a hackintool for create a video patch
