HP WORKSTATION ELITEBOOK 8570W
Postby darkstaring » 18 Nov 2016, 17:43
Hello everyone...
I have HP WORKSTATION ELITEBOOK 8570W with:
* Intel(R) Core(TM) i7-3720QM (with sse4_1 sse4_2 istruction set)
* Nvidia Quadro K1000M
* 16GB ram
* Network controller: Intel Corporation Centrino Ultimate-N 6300 (rev 3e)
during boot press f9 to select boot devices but the pendrive previously created with (win32diskimager or imagewriter-Linux) It is not in the list of devices.
what can I do? ... the PC is supported?
In my hard drive i have 2 linux and windows. Clover can create bootloader for all?
darkstaring
CPU: i7-3720QM
Motherboard: HP ELITEBOOK 8570W
GPU: Quadro K1000M
Re: HP WORKSTATION ELITEBOOK 8570W
Postby darkstaring » 18 Nov 2016, 18:09
Sorry.. i understan how to start the OS, but have a kernel panic
i try append "nv_disable=1" in config but not start
this is the video
https://drive.google.com/file/d/0B3jUoK ... sp=sharing
any ideas?
Thank you
darkstaring
CPU: i7-3720QM
GPU: Quadro K1000M
Postby darkstaring » 19 Nov 2016, 02:19
I try all' options aviable with space_bar but not start.... Incompatibile?
darkstaring
CPU: i7-3720QM
GPU: Quadro K1000M
Postby artur-pt » 19 Nov 2016, 09:24
u are getting problems with fakesmc .. try another version of the kext
is that why u get KP
this is not a step by step .. so read and get ideas
http://www.insanelymac.com/forum/topic/ ... ootloader/
artur-pt
Staff
Postby darkstaring » 19 Nov 2016, 23:34
Hello
I installed the os But the installer haven't create the bootloader in mbr and i not Remember the options that i set :D ...
I Will write the options and post here..
Thank you
darkstaring
CPU: i7-3720QM
GPU: Quadro K1000M
Postby artur-pt » 20 Nov 2016, 01:15
by now u should know .. OS X is not YES or NO .. NEXT or CANCEL .. options .. this is not windows or linux .. so write to remember what u choose .. is not a Lottery
artur-pt
Staff
Postby darkstaring » 21 Nov 2016, 14:21
With
Code: Select all
-v kext-dev-mode=1 rootless=0 nv_disable=1 Dart=0 GraphicsEnabler=No PCIRootUID=1
start :D ....but the graphics is terrible and the network not work.
How to fix?
darkstaring
CPU: i7-3720QM
GPU: Quadro K1000M
Postby artur-pt » 21 Nov 2016, 16:09
reading
viewtopic.php?f=28&t=1716
and hopping u have compatible hardware
artur-pt
Staff
Postby darkstaring » 21 Nov 2016, 21:37
How to download xcode without Apple store?
darkstaring
CPU: i7-3720QM
GPU: Quadro K1000M
Postby artur-pt » 22 Nov 2016, 10:15
u can't
what u go do with xcode ?
u have several problems with ur config .. video .. ethernet connection .. first u must solve all the problems .. then u download xcode ..
artur-pt
Staff
Next
Return to Sierra (10.12)
