MSI GE70 PE "Apache Pro"
Postby nasondas » 19 Oct 2016, 09:56
Hi,
I'm looking for help to operate the sound and wifi with my laptop.
I do not know how to patch my dsdt for "ALC892" and wifi "AzureWare AW-CE123H BCM4352."
If someone with the same configuration could help me ....
Thank you in advance.
nasondas
Re: MSI GE70 PE "Apache Pro"
Postby pernacabeluda » 19 Oct 2016, 10:54
Take a look here
https://github.com/RehabMan/OS-X-BrcmPatchRAM
For audio try this
https://github.com/vit9696/AppleALC
You don't need to patch DSDT, use Clover to inject layout-id
https://clover-wiki.zetam.org/Configura ... dio-inject
Or use this, it doesn't need layout-id
http://www.insanelymac.com/forum/topic/ ... oohda-289/
pernacabeluda
Senior
Postby nasondas » 19 Oct 2016, 13:33
Thank you so much for your help,
I will try to translate the guides (my english is bad).
nasondas
Postby artur-pt » 19 Oct 2016, 14:31
for the wifi u need this
http://www.insanelymac.com/forum/topic/ ... 532z-wifi/
this patch for clover
and also
Originally created for BCM94352Z, this particular application of FakePCIID.kext is used to emulate an authentic Apple Airport Extreme, when using a variety of supported Broadcom WiFi devices.
https://bitbucket.org/RehabMan/os-x-fake-pci-id
2 kext
fakepciid
FakePCIID_Broadcom_WiFi
artur-pt
Staff
Postby nasondas » 20 Oct 2016, 20:37
artur-pt wrote:hello
and also
2 kext
fakepciid
Boas Artur-pt, imagino que deves ser Portugues..se for o caso e se tiveres um pouco de tempo para uma ajudinha agradecia-te.
eu fiz install dos 2 kexts com o "kext helper" mais nao esta a funcionar, tenho muita dificuldade a traduzir os guides..e ainda pior quando eles sao varios e sempre de maneira differente.
Deixo aqui un link do meu dsdt "feito com aida64" e screen da placa wifi et son, se puderes fazer algo. https://www.dropbox.com/s/r6mscwdutwclhx6/MSI%20GE70%202PE.rar?dl=0
Obrigado.
nasondas
Postby artur-pt » 23 Oct 2016, 16:14
follow forum section .. here is english .. if u go post in portuguese .. post in portuguese section.
this is ur dsdt .. windows pictures no good for nothing .. use ioregisterexplorer need to know where is located ur wifi in dsdt
http://olarila.com/files/Utils/IORegistryExplorer.zip
man use google translator to translate the post i link to u
artur-pt
Staff
Return to Sierra (10.12)
