macOS Sierra 10.12 bootable USB for Intel PCs (16A323)
Re: macOS Sierra 10.12 bootable USB for Intel PCs (16A323)
Postby pernacabeluda » 03 Jan 2017, 20:41
Check if you have NX bit in BIOS options and enable it
viewtopic.php?f=2&t=1804
pernacabeluda
Senior
Postby xelalieneilalex » 28 Feb 2017, 02:33
Managed to boot via Enoch with boot flags -v -x cpus=1
But Sierra cannot be installed to an MBR primary partition (even if formatted to Mac Journalised)
Laptop model: HP 14-d004TX
Processor: 2.4 GHz Intel Core i3-3110M with Intel HD Graphics 4000
GPU: NVIDIA GeForce 820M
RAM: 2 GB 1600 MHz DDR3L SDRAM (1 x 2 GB)
xelalieneilalex
CPU: Intel Core i3-3110M
Motherboard: Intel HM76 Express
Postby pernacabeluda » 28 Feb 2017, 03:14
For what reason? Post the error message.
pernacabeluda
Senior
Postby xelalieneilalex » 28 Feb 2017, 03:33
pernacabeluda wrote:For what reason? Post the error message.
Can't seem to find any significant error on verbose boot, but upon reaching the install screen, graphics are not laggy, keyboard & touchpad are working.
Here I successfully created the partition for installation:
Primary MBR (disk0s3):
Then this error:
BIOS settings are OK (Legacy mode ON, Secre Boot OFF, USB boot priority)
MD5 sum of raw file already checked and matched;
So I am still wondering if my laptop is not supported for Sierra install...
xelalieneilalex
Postby pernacabeluda » 28 Feb 2017, 15:55
Try to change SMBIOS settings, save this as /Extra/smbios.plist
http://olarila.com/files/SMBIOS/MacBookPro9.2.plist
pernacabeluda
Senior
Postby zloduh » 13 Mar 2017, 15:02
Hi guys
i have managed to install it on Elitebook 8460p. But it only boots from usb.
I have downloaded the latest cloverefi and installed it on my hard but it still not booting.
I am missing lan wifi and sound drivers... i have kexts installed but they do not activate as i am booting from usb.
I dont have efi enabled it didnt need to boot from usb i think i dont need to boot from hard.
Can anyone assist me a bit please. Let me know if you need more info
zloduh
CPU: I5 2520M
Motherboard: HP Intel qm67
GPU: Intel HD3000
Postby NaniBot » 13 Mar 2017, 22:45
Hi, I am currently stuck with a kernel panic : DSMOS : SMC returned incorrect key. I've tried changing smbios to macpro but it didn't work. I've also changed the fakesmc kext (both kexts : 1 located in the Extra directory and the other located inside the EFI/Extra folder). But even that didn't work.
I own a HP laptop that has a insyde bios. I'm booting in legacy mode(not UEFI). I am using the "Kernel Pmpatch" and "Kernel Lapic Patch" selected in the Binaries Patching option in clover menu.
I've tried hard to search for this kernel panic online but with no luck. Please help.
NaniBot
CPU: i3 5005u
Motherboard: HP with insyde
GPU: Intel HD Graphics 5500
Postby Dekill93 » 05 Apr 2017, 01:23
i will try, first my action to install
Dekill93
CPU: Intel Core i3 2310M
Motherboard: Asus K43SV
GPU: Nvidia 540M
Postby kobiandy » 10 Apr 2017, 10:59
Hello guys. I have been using your bootable images successffully for a while now I must say you guys are the best. I know how frustrating hackintosh can be and you have somehow simplified it for many. My issue here is with a new laptop I recently purchased. Aspire E5-574G(i5 6200U gtx920M intel hd 520). I boot from clover and it just gives me the usual quick rush of texts and panics at screen shown. Please if anyone has an idea of how to solve this as I cannot enter installer. Thanks in advance
kobiandy
CPU: i7 2700k
Motherboard: H61 Asrock
GPU: HD 7950
Postby failax » 02 May 2017, 08:53
I have a motherboard MSI x99a SLI plus and intel 5820k, installation doesn't begin, do I have to change something?
failax
CPU: i7 920 2.67GHZ
Motherboard: Dell Studio XPS 435MT MotherBo
GPU: ATI RADEON 6570 HD
PreviousNext
Return to Sierra (10.12)
