macOS Sierra 10.12 bootable USB for Intel PCs (16A323)
Re: macOS Sierra 10.12 bootable USB for Intel PCs (16A323)
Postby failax » 09 Nov 2016, 11:33
I try this afternoon thanks.Booting from Clover on usb, other O.S. are shown, but if I try to select them the pc reboots but don't open nor Windows nor Ubuntu, only Sierra goes ahead if selected.
failax
CPU: i7 920 2.67GHZ
Motherboard: Dell Studio XPS 435MT MotherBo
GPU: ATI RADEON 6570 HD
Postby pernacabeluda » 09 Nov 2016, 15:50
I have not tested but I believe other OS will only boot if installed in the same mode as Clover (UEFI or legacy).
pernacabeluda
Senior
Postby failax » 09 Nov 2016, 18:59
I tried the first and the third link with no success, I haven't understood how to try second one..sorry I'm new to Apple...
failax
CPU: i7 920 2.67GHZ
Postby pernacabeluda » 09 Nov 2016, 19:06
Read detailed instructions on the links, you need to inject layout-id to get patched AppleHDA working, there are several ways to do it.
pernacabeluda
Senior
Postby failax » 09 Nov 2016, 20:31
pernacabeluda wrote:Read detailed instructions on the links, you need to inject layout-id to get patched AppleHDA working, there are several ways to do it.
My Realtek Alc1200 isn't listed, it arrives to ALC1150, i tried this last kext with Multibeast but it doesn't work.VoodoHDA doesn't work too.Maybe some kext are patched now.It's there a way to insert the right kext in clover usb boot?
failax
CPU: i7 920 2.67GHZ
Postby pernacabeluda » 09 Nov 2016, 20:45
It's listed in https://github.com/vit9696/AppleALC/wik ... ted-codecs
I believe audio kexts don't work from Clover folder because of dependencies.
You can try this
viewtopic.php?f=40&t=5844
pernacabeluda
Senior
Postby vFever » 09 Dec 2016, 06:21
Hi,
Does anyone have the full instructions in a list on what to do with the .raw file? Tbh I'm so confused
vFever
CPU: Intel Core i7 5870k
Motherboard: Asus X99 Deluxe II
GPU: Nvidia 980
Postby richardyusan » 03 Jan 2017, 15:06
i've enabled Kernel PM patch in binary patching as instruction for haswell/broadwell processor
but still facing auto reboot
richardyusan
CPU: I7 5500U
Motherboard: 1168bga
GPU: IHD 5500/nv 940m
PreviousNext
Return to Sierra (10.12)
