macOS Sierra 10.12 bootable USB for Intel PCs (16A323)
Re: macOS Sierra 10.12 bootable USB for Intel PCs (16A323)
Postby pernacabeluda » 26 Oct 2016, 01:23
I believe Realtek network never had native support on Mac, you need to install the respective kext.
Try this one
http://www.insanelymac.com/forum/files/ ... 11-binary/
pernacabeluda
Senior
Postby xShift » 07 Nov 2016, 15:40
Installation process fails at 3 min remaining on Lenovo z50-70(Clover latest; i5 cpu; HD 4600; GeForce 840M) ... Can you help me?
Update: After the third attempt a system was installed but clover(-v) says about kernel cache loading error. Log says about dyld cache cant be created because process crashes.
Have any body ideas how to fix it?
xShift
CPU: i5
Motherboard: 8 Series
GPU: HD4400
Postby failax » 08 Nov 2016, 13:26
Hello, i'm trying to install Sierra on the second partition of my main ssd, right after windows 10.Disc utility doesn't see my hard disk, I read on another forum with a different guide to have hackintosh, that I must insert in the usb IOATAFamily.kext to AHCI_3rdParty_SATA.kext, AHCI_3rdParty_eSATA.kext and JMicron36xATA.kext.
In what folder I must put them?
failax
CPU: i7 920 2.67GHZ
Motherboard: Dell Studio XPS 435MT MotherBo
GPU: ATI RADEON 6570 HD
Postby pernacabeluda » 08 Nov 2016, 13:53
EFI/CLOVER/kexts/Other in EFI partition.
pernacabeluda
Senior
Postby failax » 08 Nov 2016, 14:30
pernacabeluda wrote:EFI/CLOVER/kexts/Other in EFI partition.
Thanks, I try later..Actually i have grub as bootloader, because I have installed Ubuntu in another hard disk.Can I keep it also with Sierra, or I must overwrite it with the new one?
failax
CPU: i7 920 2.67GHZ
Postby pernacabeluda » 08 Nov 2016, 14:42
You need Clover or Enoch to boot Sierra, but you can chain load it from GRUB
viewtopic.php?f=3&t=68
pernacabeluda
Senior
Postby failax » 08 Nov 2016, 17:47
I added those kexts but hard disk are not shown, even doing this:"Try also FakeID for SATA as 0x9C838086 (under PCI devices)" and this:"fix SATA and add DTGP under ACPI patching/DSDT fix mask (0x00000401)"
My log is attached
failax
CPU: i7 920 2.67GHZ
Postby pernacabeluda » 08 Nov 2016, 18:02
Try putting AHCIPortInjector in EFI/CLOVER/kexts/Other
download/file.php?id=7748
pernacabeluda
Senior
Postby failax » 08 Nov 2016, 19:59
pernacabeluda wrote:Try putting AHCIPortInjector in EFI/CLOVER/kexts/Other
It worked, thanks!!Installation completed!Now I must fight with drivers...pc is mute and with no internet connection..we hear later..:-)
failax
CPU: i7 920 2.67GHZ
Postby failax » 08 Nov 2016, 21:30
My audio card Realtek ALC1200 Is not recognized, can you show me a package to install?Thanks
I tried with no success multibeast driver..
failax
CPU: i7 920 2.67GHZ
PreviousNext
Return to Sierra (10.12)
