Mavericks scrambled screen
Re: Mavericks scrambled screen
Postby matuskela » 08 Aug 2015, 15:04
Hi Mendietinha!
I'm using the flag IGPlatformID = 01660003 would it? 1080p HDMI port works but the notebook screen is with artifacts , if I change from 1080p to 720p both work without the artifacts but at 720p , but for this to work I have to go there in the display settings , putting 1080p and return 720p as soon linking it comes with independent video configuration artifacts. Remembering that I am using the original kext AppleIntelFramebufferCapri unedited in Yousemite .
matuskela
CPU: I7
Motherboard: Lenovo
GPU: HD 4000
Postby mendietinha » 08 Aug 2015, 17:49
no need edits. you have what you have with fb=3. artifacts. must deal with it if you need hdmi.
mendietinha
Staff
CPU: i5 750
Motherboard: Intel
GPU: GTX760
Postby matuskela » 08 Aug 2015, 20:06
mendietinha wrote:no need edits. you have what you have with fb=3. artifacts. must deal with it if you need hdmi.
When you say "FB = 3" means a specific flag ? Do these artifacts may damage the video or the board over time ?
matuskela
CPU: I7
Motherboard: Lenovo
GPU: HD 4000
Postby MarceloMustaine » 08 Aug 2015, 21:57
He means IntelCapriFB=3 for the HD4k on chameleon...
MarceloMustaine
Geek
CPU: Intel(R) Core(TM) i3-4130 CPU
Motherboard: Gigabyte GA-H81M-H
GPU: Nvidia GTX750
Postby matuskela » 14 Aug 2015, 15:56
There is a problem of damaging the graphics card in notebook using with the artifacts ? For the hdmi port will not be with the artifacts and the notebook screen I'll close and work with only the TV to HDMI . It can damage something the being with artifacts on display closed ?
matuskela
CPU: I7
Motherboard: Lenovo
GPU: HD 4000
Previous
Return to Mavericks (10.9)
