Mavericks on Vaio Vpceb3m1e
Re: Missing bluetooth controller
Postby Giatuareg » 14 Dec 2013, 16:17
Wonderful now after made the org.chameleon.boot.plist with
-v -f
Restart fix
Npci=0x2000
Usb fix
And the Smbios.plist with the closer mac spec ( do i have to manual insert infos about cpu?)
I can boot to desktop :)
The verbose says that the SMC module cant used and Falls back to older one (?)
Now can i go further kexts? Actually graphic res is wrong, wifi doesnt work, ethernet no audio no, touchpad no
Ty pimentelx86
Giatuareg
CPU: I3 370m
Motherboard: Hm55
GPU: Ati Mobility Radeon 5650
Re: Mavericks on Vaio Vpceb3m1e
Postby PimentelX86 » 14 Dec 2013, 17:09
Hello
Ok.
Infos about CPU will be management by bootloader. You need choose correct SMbios to your CPU, if not power management won't work.
Look for a most compatible mac computer model.
First thing: You need adjust your power management.
You'll need create a SSDT to generate P and C states, patch AICPUPM and active DropSSDT. Know how do it: viewtopic.php?f=18&t=1703
Your graphic card was recognized? If not, read the guide, there are all thing you need.
PimentelX86
Veteran
CPU: i7 2600
Motherboard: IPMH61R1
GPU: GT 610
Postby Giatuareg » 14 Dec 2013, 21:48
Hi there and hi Pimentelx86.
Thanks for the help u made me, i was close to give up everything and reinstall Debian after a week of loops and bad luck, but with the infos u gave me now things starting to get right and the satisfaction is incredible.
THANKS AGAIN!
I promise i'll made a complete and up to date guide for complete installing on the Vaio VPCEB3M1E ( i have 6 of these machines ).
I've read the last link u posted about the Power Management, and had to install first the Wifi drivers to download the script.
The wifi kext is working like a charm :)
steps i made till now:
-Olarila's usb intel MAV image installed otb
- chameleon 2.2 svn installed otb (no options, only boot loader + theme)
- FAKESMC installed
- Atheros KEXT installed (wifi)
- created the org.chameleon.plist with these flags:
-v
-f
-USBFIX
-npci=0x2000
-Restart Fix
Now I tried the script u linked but it's not working with older CPUs than Sandy Bridge.
I've read around and seen that it SHOULD be enough to specify on chameleon.plist the following flags:
-generate P-States
-generate C-states
- Drop SSDT
Seems working but i don't know for sure. Also i don't know which SMBIOS choose cause there is no arrandale official mac configs :/
At the moment i'm triing to install the ATi Mobility 5650 kexts.
I've read here that i should need 3-4 kexts but googling i only found 1 kext provided by another VPCEb3M1E owner (ATY_Init.kext), any hint to proceed?
thanks in advance
Giatuareg
CPU: I3 370m
Motherboard: Hm55
Postby PimentelX86 » 14 Dec 2013, 23:28
Hello
Giatuareg wrote:Now I tried the script u linked but it's not working with older CPUs than Sandy Bridge.
Excuse me, I thought you had Sandy Bridger, but you have Nehalem/Arrandele
So you only need do:
*Generate C States
*Generate P States
*DropSSDT=No
Isn't necessary patch AICPUPM or have SSDT to your CPU
Use Chameleon Wizard to facilitate your configuration.
This guide will teach everything about AMD graphic: viewtopic.php?f=18&t=736
You don't need install nothing, only active.
Good Luck!
PimentelX86
Veteran
CPU: i7 2600
GPU: GT 610
Postby Giatuareg » 15 Dec 2013, 01:20
Perfect, i'm tiring to study the ati guide but really don't understand where i have to put my id and vendor code, which kexts i mean :oops:
Giatuareg
CPU: I3 370m
Motherboard: Hm55
Postby PimentelX86 » 15 Dec 2013, 01:30
Hello
Click in right mouse and select option of open the kext...
Inside it, has info.plist, you'll need put your Dev and VendID in this one.
I don't use ATI card and never used, but i edited my Nvidia card.
artur-pt have more knowledger about ATI card.
PimentelX86
Veteran
CPU: i7 2600
GPU: GT 610
Postby artur-pt » 15 Dec 2013, 10:09
u graphics use
amd5000controller and amdradeonx3000
read the post carefully and u understand.. maybe also u try the forced edid
artur-pt
Staff
Postby Giatuareg » 15 Dec 2013, 13:41
goodmorning forum, UPDATE:
i got trackpad and keyboard working with RehabPS2, very good :)
Now I'm focusing on the QE/CI
getting really crazy about it, i've modified the device ID and vendor ID in x3000 and ati5000, also in controller as well but no luck.. i'll keep on
Giatuareg
CPU: I3 370m
Motherboard: Hm55
Postby Giatuareg » 25 Dec 2013, 15:02
At the moment the system is 100% working, tried several stress tests and it's perfect under 10.9.1
Im writing a pdf guide to help any vpceb3m1e owner to have a perfect sister running. Hold on some days ;)
Thanks to everybody helped
Giatuareg
CPU: I3 370m
Motherboard: Hm55
Postby AlexLinux » 10 Aug 2015, 14:45
Hallo Giatuareg,
I'll install OS X system on my notebook (mavericks is good). Mine is exactly like your (VPCEB3M1E).
Could you help me? Did You wrote that PDF guide or... write a tutorial for me?
THANX :D
AlexLinux
CPU: i3
Motherboard: sony vaio
GPU: ATI HD 5650
Previous
Return to Mavericks (10.9)
