OS X Mavericks 10.9 GM bootable USB for Intel PCs
Re: OS X Mavericks 10.9 GM bootable USB for Intel PCs
Postby z3rito » 21 Apr 2015, 15:40
i change options in bios at cpu and it its working yeahh, thanks to all
z3rito
CPU: dual core e5200
Motherboard: P43DE
GPU: ati hd 7850
Postby blazure78 » 22 Apr 2015, 18:26
Hi guys! I got a similar problem too with reaching the installation menu.
As I couldn't boot with Clover (didn't work don't ask me why, it just froze with a non-blinking underscore in the top left conrner, but whatever), I tried with Chameleon and it worked just fine, although i still cannot access the installation GUI and stuff. I'm stuck with a couple of errors such as "DSMOS has arrived" and a couple of other things (see the last 5-10 lines of the screenshot but please don't take in consideration the "unable to enumerate usb device" error-type that was really seldom).
I'm aware it should be somewhat dealing with my GPU but, I have already checked out the manipulations in the first post (stuff like moving .kext into backup folder etc...) but it didn't work. Same thing with flags : i have already tested -v -x GraphicsEnabler=No KernelCache=No but it wasn't really effective huh. My PC is a PACKARD BELL BV IMEDIA J9610 with a PACKARD BELL BV GA-T671MG mobo (I know, that's antiquity stuff), with an Intel Core 2 Duo, and 3GB of RAM, my GPU -if you could ever call it that way- is an AMD ATi MSI Radeon R5450 in PCIExpress (and I had already turned it back to "PCI" in my BIOS).
If someone could help pleaaaase x).
blazure78
CPU: Intel Core 2 Duo
Motherboard: PACKARD BELL BV GA-T671MG
GPU: AMD ATI Radeon HD 5450 MSi
Postby pernacabeluda » 22 Apr 2015, 19:48
You should run
Code: Select all
mv AMDRadeon* ATI* /kext_backup
Then boot with -f (if using Chameleon).
pernacabeluda
Senior
Postby blazure78 » 22 Apr 2015, 20:06
Still not working and I don't even have any AMDRadeon or ATI kext file in /S/L/E :\
blazure78
Postby pernacabeluda » 22 Apr 2015, 20:29
Try dart=0
pernacabeluda
Senior
Postby blazure78 » 22 Apr 2015, 21:46
Not working either, but that was to be expected, my computer doesn't even handle virtualization x) I think it might be something dealing with SMC since it has prompted "ACPI_SMC_PatformPlugin::start - waitForService(resourceMatching(AppleIntelCPUPowerManagement) timed out". But I don't get what I'm suppose to do to prevent that :/
blazure78
Problem with USBMSC
Postby syahradzi » 20 Aug 2016, 16:28
Guys, i have problem with my installation. i already post my problem viewtopic.php?f=31&t=5788 , can anybody help me? don't intended to spam, but i really hope somebody can help me :cry:
syahradzi
CPU: Intel Core i5-2410M
Motherboard: Sony Vaio
GPU: nVIDIA GeForce 410M
Postby kayoo7 » 23 Jun 2017, 14:27
Im hving problem with the installation
Code: Select all
14 May 12 11:51:40 localhost OSInstaller[328]: Can not connect to /var/run/systemkeychaincheck.socket: No such file or directory
15 May 12 11:51:53 localhost OSInstaller[328]: PackageKit: ----- Begin Install -----
16 May 12 11:52:34 localhost OSInstaller[328]: PackageKit: Got copier error 5 extracting to path /./system/Library/Framewroks/AppKit.framework/Versions/c/Resources/cs.lrpoj: Input/output error
17 May 12 11:54:18 localhost OSInstaller[328]: PackageKit: Install Failed: Error Domain=PKInstallErrorDomain Code=110 "An error occurred while extracting files from the package "Essentials.pkg"." UserInfo=0x7f8f65a850b0 {NSLocalizedDescription=An Error occurred while extracting files from the package "Essentials.pkg"., NSFilesPath=/Volumes/Untitled 1/.OSInstallSandbox-tmp/Root, NSURL=Essentials.pkg -- files:// localhost/System/Installation/Packages/OSInstall.mpkg, PKInstallPackageIdentifier=com.apple.pkg.Essentials, NSUnderlyingError=0x7f8f6759f520 "The file couldn't be opened because it isn't in the correct format."} {
18 May 12 11:54:19 localhost OSInstaller[328] Install failed: The installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
19 May 12 11:54:20 localhost OSInstaller[328]: No system on disk Untitled 1 to revert bless
20 May 12 11:54:20 localhost OSInstaller[328]: Unable to revert bless to target or imgsrc.
It says like this and asks for restart i tried different HDD formatted to mac hfs+
but still no sucess
Mobo: ASUS PQ5PL-AM
Processor- Intel dual core
Ram - 3 GB
HDD- First Hitachi 320 GB
Second - Seagate 120 GB
kayoo7
CPU: Dual core
Motherboard: P5QPL-AM
GPU: Intel
Previous
Return to Mavericks (10.9)
