OS X Mavericks 10.9 GM bootable USB for Intel PCs
Re: OS X Mavericks 10.9 GM bootable USB for Intel PCs
Postby djabbas » 03 Mar 2015, 14:19
I am confused. My hardware requires Chameleon bootloader as per tonymacx forums. How do i use Chameleon instead of clover?
well i tried using clover itself but the screes gets stuck at "system uptime [long numeric value]"
djabbas
CPU: NA
Motherboard: NA
GPU: NA
Postby artur-pt » 03 Mar 2015, 15:05
viewtopic.php?f=28&t=4650
and stop talking about that " beast " thing or go out there
here is olarila.com no " beast".com
if u start reading u will see the info in the forum
artur-pt
Staff
Postby rphydra » 13 Mar 2015, 14:57
HP DV6 6033
Chipset HM65 Express
I5 2410M
HD3000
I installed Mavericks and everything was perfect only needed the flag cpus = 1 and all USB including USB3 worked
To resolve the cpus=1 problem I used patch Lapic Kernel V7 (10.9) but UBS crashed
Now everything works fine unless the USB
Even using AppleUSBXHCI or GenericUSBXHCI I can not get USB
Can someone help me
Advance grateful
rphydra
Postby elSantosh » 17 Apr 2015, 15:36
I'm using Acer aspire 4738z ... It is continuously turning off at installer (after showing 16 min to complete the installation... ) ...please suggest solution.. Thank you
elSantosh
CPU: Intel P6100
Motherboard: dont know
GPU: dont know
Postby z3rito » 21 Apr 2015, 11:26
my system:
proc: dual core e5200
motherboard: P43DE
gpu: ati hd 7850
ram: 4 gb kingston
SSD 120 Gb
system: snow leopard 10.6.8
With Snow Leopard only works me with GraphicsEnabler = No because there is no support for my graphics
I have tried every option (verbose, safe mode, without cache, whitout injected kexts ....) all options restarted my computer, without the installation menu appears.
no error message, load drivers and reboot, any suggestion?
z3rito
CPU: dual core e5200
Motherboard: P43DE
GPU: ati hd 7850
Postby artur-pt » 21 Apr 2015, 12:37
try to boot with chameleon
hit 1 to get chameleon screen
is all in guide
and should boot with GE=No
artur-pt
Staff
Postby z3rito » 21 Apr 2015, 12:52
I tested with chameleon but the same result. when finished reading the files, restarts, fails to show anything
z3rito
Motherboard: P43DE
GPU: ati hd 7850
Postby artur-pt » 21 Apr 2015, 13:28
with that info .. only guessing
see ur bios sets
and the smbios u use
https://support.apple.com/en-us/HT201364
artur-pt
Staff
Postby z3rito » 21 Apr 2015, 14:01
the bios is fine, I started mac os x 10.6.8 smoothly,Image
the problem is that after reading the files from usb not charge anything and directly restarts, show no mistake
i tried several options, (-x -f -v GraphicsEnabler=No PCIRootUID=1 npci=0x2000)
I've also tried the usb Yosemite and I happen the same
z3rito
Motherboard: P43DE
GPU: ati hd 7850
Postby pernacabeluda » 21 Apr 2015, 14:48
Enable NX bit in BIOS setup
viewtopic.php?f=2&t=1804
pernacabeluda
Senior
PreviousNext
Return to Mavericks (10.9)
