OS X Mavericks 10.9 GM bootable USB for Intel PCs
Re: OS X Mavericks 10.9 GM bootable USB for Intel PCs
Postby artur-pt » 17 Dec 2014, 21:01
see minimum options in ur bios
viewtopic.php?f=28&t=4084
and that nvidia .. go give u problems
artur-pt
Staff
Postby QueenOfHearts » 17 Dec 2014, 21:28
I already followed the settings provided in that post for bios but it's still the same error :/
QueenOfHearts
CPU: i7-4790k
Motherboard: Asus Z97-A
GPU: GTX 750Ti
Postby artur-pt » 18 Dec 2014, 00:34
try remove from installer
GenericUSBXHCI.kext
u boot from clover
so must access efi folder
clover/kext
artur-pt
Staff
Postby QueenOfHearts » 19 Dec 2014, 03:37
I'm trying to use Transmac to remove the kext from my USB but Transmac cannot see my USB. I tried it on two different USB and it still cannot see the Install USB in Windows 7. Any solutions to this?
**EDIT**
Okay I was able to get Transmac to read the install USB but I can't find the EFI/Clover folder :(
This is the Olarila bootable USB image.
QueenOfHearts
CPU: i7-4790k
GPU: GTX 750Ti
Postby pernacabeluda » 19 Dec 2014, 12:48
Use the EFI shell.
Code: Select all
fs0:
cd EFI\CLOVER\kexts\10.10
rm -r GenericUSBXHCI.kext
pernacabeluda
Senior
Postby QueenOfHearts » 19 Dec 2014, 15:31
Thanks! I was able to remove the kext but still doesn't boot. I'm still getting stuck at the same screen :/
QueenOfHearts
CPU: i7-4790k
GPU: GTX 750Ti
Postby malik22 » 24 Dec 2014, 12:58
Hello guys im trying to install threw usb and get this error all the time.
malik22
CPU: 4770k
Motherboard: asus maximus hero
GPU: 290x
Postby omisayeee » 17 Jan 2015, 23:45
Hi all this tutorial's looks simple to me but when i tried it, is another thing all together.
First : i downloaded image-writer and used it to copy OS x to my 62g flash. i tried to dual boot my hp pavilion dv6, selected my 62g flash i copied OS x ,press space bar in Clover and selected booting in single user mode...
when the clover tried to proceed to installer i got this error nanoseconds 121212183311......
please if you wouldn't mind could you help me to get away from this challenge, this have kept me from learning how to develop OS App for two good months now.thank for your help.
omisayeee
CPU: intel core i3 370m
Motherboard: hewllet-packard 144a
GPU: intel graphics
Postby J_Marley » 18 Feb 2015, 04:33
Okay, I apologize ahead of time as I'm betting this has been answered before, but I am a complete noob when it comes to anything hackintosh related. I have usually had either a Mac or a PC and this is my first system build trying to run both off the same machine. I am able to boot from the USB drive into Clover, but when I select to Boot the Mac OSX from the USB to install I get a terminal screen (or DOS like screen) that starts rattling through a bunch of language I don't understand, shows a few errors, and then I get a large white circle with a line through it in the middle of the page before the text on the screen all starts to merge together. I am completely lost as to what to do and how to install the OSX onto the secondary HDD I have installed in the computer.
Current Computer specs from Everest:
Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
ASUS MAXIMUS VI HERO Motherboard
NVIDIA GeForce GTX 750 Ti (2048 MB)
WDC WD10EZEX-00BN5A0 (931 GB) x2 (one for Windows 8.1 and the other hopefully for OS X)
16GB DDR3 1600 (8GBx2)
J_Marley
CPU: Intel i7 4.0GHz
Motherboard: ASUS Maximus Hero VI
GPU: NVidia Geforce GTX 750 Ti
PreviousNext
Return to Mavericks (10.9)
