olarila.com
Mac OS X x86 - Hackintosh
It is currently 24 May 2013, 14:22
Forum rules
Este fórum é apenas para guias e tutoriais. Se quiser postar um novo guia ou tutorial, crie o tópico em outra seção e ele será movido para cá.
Post new topic Reply to topic  [ 373 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 38  Next
Author Message
PostPosted: 16 Jun 2011, 02:05
GeekInTraining
OK, lo que pasa es que logre darle una imagen al pendrive con lion, luego renicio y ando mi pc con el pendrive para correr la instalación de lion, pero no puedo. en chameleon me dice elejir disco duro o pendrive como opción entoncs elijo pendrive (que es la instalación de lion), y carga todo y entra a la instalación en l momento de elegir el idioma . pero no me pesca usb. ese es mi gran problema.
Top
 Profile
PostPosted: 16 Jun 2011, 02:14
Staff
Did you put the file dsdt.aml generated by Auto-Patcher in the /Extra folder inside the pen drive? Please attach this file here.
Also try typing "USBBusFix=yes -v" in Chameleon screen, after selecting the pen drive, before pressing enter. It's case sensitive, so "UsbBusFix=yes" will not work.
If it makes no difference, try "USBLegacyOff=yes -v".
Did you need any special procedure to have USB working in Snow Leopard?
Top
 Profile
PostPosted: 16 Jun 2011, 02:40
GeekInTraining
lo que no te entendi, es eso del patch, que va en el /extra. que extra? no entiendo me puedes ayudar con un apoyo de imagen?
pd: cuando trato de escribir ese comando no puedo porque se queda pegado.
Top
 Profile
PostPosted: 16 Jun 2011, 03:16
Staff
When you install Extra Lion.pkg to the pen drive, it creates a folder named "Extra". You have to put the dsdt.aml inside that folder.
If you can use the arrow keys to navigate in the Chameleon screen, you should be able to type the parameters. Where it appears in the screen depends on the theme you are using.
Top
 Profile
PostPosted: 16 Jun 2011, 03:55
GeekInTraining
que pasa si instalo en extralion4dp y no el extralion.?
Top
 Profile
PostPosted: 16 Jun 2011, 04:04
Staff
The same thing, except it also installs the DP4 kernel to the root of the pen drive.
You still have to copy the dsdt.aml to the Extra folder in the pen drive.
Top
 Profile
PostPosted: 16 Jun 2011, 04:19
GeekInTraining
pero que cosa del dsdt pongo en la carpeta extra?
porque bajo el .zip lo descomprimo y me sale un archivo, lo abro y me dice extraer, obviamente elijo mi placa que es la H55M-S2H pero tu me hablas del dsdt.aml pero donde está eso?
Top
 Profile
PostPosted: 16 Jun 2011, 04:24
Staff
Look
When you click "apply" it creates a dsdt.aml file on your desktop. Just copy this file to the Extra folder in the pen drive.
Top
 Profile
PostPosted: 16 Jun 2011, 06:03
GeekInTraining
ok, listo, me pasa lo siguiente renicio el pc con el pendrive puesto y no me carga se queda pegado hay, no carga disco duro ni bios....
saco el pendrive renicio y me funciona con normalidad. que pasa hay?
Top
 Profile
PostPosted: 16 Jun 2011, 06:22
Staff
This happens only when you copy dsdt.aml to pen drive?
I don't understand, a few posts ago you said you could get to the language selection screen
Top
 Profile
Search for:
Jump to:
