How to write a raw image to USB in OS X
pernacabeluda
Post by pernacabeluda »
--First Option / Terminal
Open a terminal and do the following
diskutil list ... /dev/disk2 #: TYPE NAME SIZE IDENTIFIER 0: FDisk_partition_scheme *16.0 GB disk2 1: DOS_FAT_32 SANDISK 16.0 GB disk2s1 ...
Find your USB stick in the output
diskutil unmountDisk /dev/disk2 Unmount of all volumes on disk2 was successful sudo dd if=[drag and drop the raw file in terminal] of=/dev/rdisk2 bs=1m sudo dd if=/Volumes/Dados/Mac\ OS\ X\ 10.8.5\ Install\ USB.raw of=/dev/rdisk2 bs=1m 5371+1 records in 5371+1 records out 5632020480 bytes transferred in 1454.529910 secs (3872055 bytes/sec)
To check progress press Ctrl + T
Finally, before you pull it out
diskutil eject /dev/disk2
--Second Option / .app
PimentelX86
Veteran
Veteran
CPU: i7 2600
Motherboard: IPMH61R1
GPU: GT 610
Re: How to write a raw image to USB in OS X
Post by PimentelX86 »
Hi
Programs no more, only terminal command.
Great guide.
uzmi
CPU: I5 9600K
Motherboard: Ga Z390M Gaming
GPU: Sapphire Radeon RX 580 4Gb
Post by uzmi »
¡Nice! ¡Really nice!
Muito obrigado.
Un saludo.
I5 9600K - Ga Z390M Gaming -Shappire RX 580 4Gb - DDR4 16gB- NVM2 250 Gb- Catalina 10.15.2
PangOS
CPU: i7 3770
Motherboard: MSI H61M-E33/W8
GPU: Geforce GTX650
Post by PangOS »
Umm, how about:
Change .raw extension to .dmg
Mount image with Disk Utility -> Restore to Flash Drive.
pernacabeluda
PangOS wrote:Umm, how about:
It won't restore EFI partition and boot sectors (drive won't be bootable on hackintosh).
meda
CPU: İntel i5 2410M
Motherboard: Quanta SWH
GPU: İntel,Nvidia
Post by meda »
thanks very useful knowledge
kidimon
CPU: i3 2120
Motherboard: p8-h61 m/le
GPU: gtx650 ti
Post by kidimon »
Am I only one who is having problems to make bootable usb? I write ''% diskutil list'' in terminal and it comes up as no such job.
Is there a fix for that? what am i doing wrong?
Thanks in advance
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt »
the # is the prompt line command
just write the command
diskutil list
[External Link Removed for Guests] - join me at irc.freenode.net/##Olarila
garcia de moura
Geek
Geek
Post by garcia de moura »
Saudações!
Uma pergunta "estúpida": essa imagem raw é para PC Intel apenas ou serve para notebooks também?
Se sim, é só instalar as kexts necessárias para touchpad etc?
Obrigado.
Gigabyte GA-B75M-D3H UEFI
Corsair 1X4 Gb 1600 Mhz Vengeance
Intel i3 3240
Fonte Corsair CX 600
EVGA NVidia GT 630 2Gb
Storage SSD Corsair Force GT 120 Gb
Samsung Syncmaster P2370
OS X macOS Sierra 10.12.6 Olarila Version
MacBook Pro 2008, sim: 2008!
pernacabeluda
Ela instala apenas o sistema original, sem modificações. Você precisa instalar as kexts necessárias para o seu hardware, independente de ser laptop ou desktop. As kexts e boot loader incluídas na imagem servem apenas para o boot do instalador e boot inicial do sistema através do pen drive.
smithassignment1
CPU: Intel Core 2 Duo
Motherboard: Z170X-Gaming 7 (U3E1)
GPU: 6 MSI GeForce GTX 1070 GAMING
Post by smithassignment1 »
Thanks for the code and information.
Jonathan Smith
Best [External Link Removed for Guests] in uk.
royorlev
CPU: core 2 duo
Motherboard: apple
GPU: ati
Post by royorlev »
Hello,
Does anybody know how do i burn the .raw image (that i wrote to USB successfully thanks to this guide) back to DVD?
Tnx
erroruser
CPU: AMD Ryzen 7 3700X
GPU: Sapphire rx 5700 XT
Post by erroruser »
royorlev, just store your usb in a safe place
:superman :superman
royorlev
CPU: core 2 duo
Motherboard: apple
GPU: ati
Post by royorlev »
Is it possible to write the .raw image back to cd/dvd?
MichaelStewart
CPU: Core i7
Motherboard: Y700
GPU: Geforce GTX
Post by MichaelStewart »
Is there a way for me to be able to tell when the process is finished, will it prompt me in Terminal or do I just have to keep checking with Control+T until it stops?
erroruser
Post by erroruser »
MichaelStewart, make on usb an use either win32diskimager or etcher
:superman :superman
