Post install
crusher
CPU: Intel i9 9900K
Motherboard: GA-Z390-M Gaming
GPU: RX 580 8GB
Re: Post install
Post by crusher »
koske wrote:I need a little help
Firstly, why when I reset OS X 10.8.5 reset and BIOS. Do we need a kekt?
Secondly, where can I find drivers for NVidia GeForce 9800 GT 1024MB. Or does anyone have.
Thank you.
No you do not need a kext,if you already have adequate.
From your graphic card use OSX86 Tool apps and use a strings from your card!
From this link:[External Link Removed for Guests]
PimentelX86
Veteran
Veteran
CPU: i7 2600
Motherboard: IPMH61R1
GPU: GT 610
Re: Post install
Post by PimentelX86 »
Hello
Only to fix some things.
koske wrote:Firstly, why when I reset OS X 10.8.5 reset and BIOS. Do we need a kekt?
You need patch your DSDT with Reset CMOS patch, will be fix this problem.
koske wrote:Secondly, where can I find drivers for NVidia GeForce 9800 GT 1024MB. Or does anyone have.
All kext are in OSX inside S/L/E folder.
You need active it. GraphicsEnabler=Yes in org.chameleon... manually or with Chameleon Wizard app.
koske
Re: Post install
Post by koske »
can you describe to me the process step by step.
15-20 times I installed and surely wrong somewhere in the bootloader, will not even boot when you remove the USB drive and let it boot from the HD. I have a 19'' monitor resolution is 1440x900, my current resolution is 1024x768, and I have the option to choose.
My spec is as follows
gaep45-DS4
8gb kingston
9800gt 1024mb ddr3
quad ćore2@2.4ghz
thanks in advance. :D
PimentelX86
Veteran
Veteran
CPU: i7 2600
GPU: GT 610
Re: Post install
Hello.
1st - You need install the bootloader in your HDD
To beginners i always recommend Chameleon.
Oficial donwload: [External Link Removed for Guests]
2nd - You need adjust OSX to work 100% in your hardware.
All things that you need know, you can find here.
Read carefully and understand.
labeebahmad32
CPU: Intel core i3 2.4 GHz
Motherboard: hp 1854
GPU: Intel HD 3000
Re: Post install
Post by labeebahmad32 »
i have hp 1000 1140TU core i3 2.39 GHz. Intel HD 3000. I cannot manage grafics. After i install kext from Olarila's kexts, my installation get corrupted or i don't know what to say. I have to boot from usb again and install os x again. mavericks. I installed audio and ethernet kexts successfully but cannot install graphics kexts. display is 1366x768.
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Re: Post install
Post by artur-pt »
the kext for hd 3000 are in system...
have u try to install they from the original image...
maybe be corrupted in installation
[External Link Removed for Guests] - join me at irc.freenode.net/##Olarila
grml4d
CPU: I5 430M
Motherboard: IMPIP-M5
GPU: GT 230M
Re: Post install
Post by grml4d »
i did the first steps :
i installed latest clover using bootdisk utility under windows onto a usb stick
by now i use it to boot my hackintosh with the option nv_disable=1
i also installed latest HWSensors.6.18.1394.pkg [ with all files ] and NullCPUPowerManagement.kext
then rebooted and pc is still loading osx
i tried to use SystemInfo but as i have no internet , i tried DPCIManager_ML that worked well .
i made screen captures about my hardware .
waiting your post , i ll try to install jre for systeminfowin and hope it will get needed files
